taco grit
Discussion in 'Technical Chat' started by ericj, Oct 24, 2008.
  1. Oct 24, 2008 at 3:25 PM
    ericj
    ericj [OP] New Member
    bremen ga
    04 taco v6 4wd dblcab
    none yet, though it's only been two weeks since I bought it.
    Im new here, found this place on the google...glad to have found this place :D
    I just bought an 04 v6 last night for a real good price. I have a concern about what I seen under the oil cap, inside the valve cover. It has a good bit of black/carbon/grit/gunk built up on the visible parts inside the valve cover. The truck runs great, no smoke, unusual noise. It has 70k miles on the odo.
    Is this a common occurance with these motors? If not, what would cause it, and what is the reccomended fix, if it is needed?
    thanks
  2. Oct 24, 2008 at 3:26 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    HI there and welcome to TW, I have no Idea but I'm sure someone will be along who does.
    -Dan
  3. Oct 24, 2008 at 4:18 PM
    ericj
    bremen ga
    thanks
  4. Oct 24, 2008 at 4:23 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    All i can say is, clean in up and see if it comes back
  5. Oct 24, 2008 at 4:50 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    My 02 has the same thing. I have 127k miles so I havn't tried running anything through the engine to clean it. The truck runs fine. There is some stuff called Seafoam you can get. It's good for cleaning out the fuel system and you can add it to the oil too, but I've never tried it(in the oil).
  6. Oct 24, 2008 at 4:52 PM
    dually
    dually Low and slow
    Seafoam FTW!!!!!!!!!
  7. Oct 24, 2008 at 7:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!!!
    i agree with the seafoam. run a can of it.......brake booster line,gas tank and in the oil. you can also switch to some synthetic oil and see if that will clean the sludge out. there is a chance however that if you run synthetic, it can clean the seals in the motor too good and cause a small leak, but there is only the chance of it happening. if it were to make a seal leak, you can switch back to regular oil and it should be ok. just a heads up. but yeah....i'd seafoam first and see the difference it makes.
  8. Oct 24, 2008 at 7:42 PM
    ericj
    bremen ga
    I appreciate it. I will hit auto zone tommorrow and see if they have the seafoam. I was already thinking about switching to a full synthetic. Is their a particular synthetic that has more cleaning properties than another?
  9. Oct 24, 2008 at 7:45 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'd definately go w/ a high mileage synthetic...i think they actually have some w/ a protective agent for seals
  10. Oct 29, 2008 at 7:38 PM
    ericj
    bremen ga
    I appreciate it. I decided to try the mobil clean 5000. It was alot cheaper.
    I also discovered that what I was looking at in the valve cover was some kind of black plate that had buildup on it, (I guess from oil hitting it when changing it and no other circulation of oil). I could look down at the top of the pistons with a flashlight which looked brand new from what I could see.
    Bad news is I discovered a leak in my transfer case, which appears to be coming from the top of the case....:mad:
    thanks
  11. Oct 29, 2008 at 7:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try tightening the bolts around the transfer case....may be all you need to do........we can hope so anyway.:)
