Taco has a hesitation!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MotoXXX, Oct 9, 2009.
  1. Oct 15, 2009 at 4:33 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Not always. In my case, it wasn't until the o2 actually crapped out that the CEL came on and in my buddy's case, he had no CEl at all but had very similar experiences as the OP and myself.
    To OP: Check your tailpipe and see if the inside is blacker than normal. A faulty o2 will result in unburned fuel going through the exhaust thus leaving soot in the tailpipe. Even if it isn't the actualy issue, at his mileage it is a good idea to swap out.
  2. Nov 16, 2009 at 9:37 PM
    MotoXXX
    MotoXXX [OP] Well-Known Member
    San Jose
    02 Pre-Runner
    Well I am at wits end :confused:, Update: New oem Denso plugs gapped to .42, new fuel filter, new plug wires, new throttle position sensor, new afe dry filter, new pcv valve, new front CO2 sensor, new battery, throttle body cleaned, Mass air sensor cleaned, 1/4 can of sea foam in vacum system, 3/4 can sea foam in tank, The truck seems to run fine but it will give a hickup when the throttle is chopped and re-aplied, like it hesitates on the kickdown shift? Sometimes when you get on it it kicksdown but hickups at the kickdown. The idle seems a little ruff as well. The only thing left to replace is the back CO2 sensor, and the Mass air flow sensor. The engine light has never come on. I tried the propane torch unlit trick to try and find a vacum leak but found nothing! WTF!!!!!
  3. Nov 16, 2009 at 10:19 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    when you get back on the throttle, or give it juice. Are you doing it kinda quick? (giving it alot).
    Bc I know that the automatics will hesitate for a sec. before downshifting or kicking down. its just how they are.
  4. Nov 17, 2009 at 7:21 PM
    MotoXXX
    San Jose
    02 Pre-Runner
    Not quick, maybe 1/4 throttle? It like stumbles/hickups when you let off the gas then re-apply the gas. Does the mass air sensor throw a code if its going bad?
  5. Nov 17, 2009 at 7:29 PM
    ETaco23
    Evan
    PNW
    Huh.... It should, but I know that sometimes it wont. Just like a bad o2. you could have the symtoms of a bad MAF or a bad o2 and no CEL. you know...
    But from reading it sure does sound like its a bad MAF sensor. sorry man!
    I know those things are spendy little bastards.
  6. Nov 18, 2009 at 5:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you clean the IAC when you did the throttle body?
  7. Nov 18, 2009 at 5:43 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    try doing the deckplate mod. my dads 3.4 hesitated, then we did the deckplate and added on a flowmaster muffler and it went away.
  8. Nov 18, 2009 at 5:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2?
  9. Nov 18, 2009 at 6:37 AM
    MotoXXX
    San Jose
    02 Pre-Runner
    I just pulled off the intake hose and used a crest electric tooth brush to clean the throttle body, should I remove the throttle body and do it again? Is that IAC the thing right under the TB? How do you clean the IAC? Did the deck plate mod awhile ago, no help.
  10. Nov 18, 2009 at 6:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, the IAC should be directly underneath (and attached) to the TB. It is held one by one or two bolts. Remove it (watch the gasket) and clean with some carb cleaner and and a toothbrush (like you did with the TB).
  11. Nov 18, 2009 at 7:35 PM
    MotoXXX
    San Jose
    02 Pre-Runner
    Thanks, will do it this weekend
