Taco is officially tostada! Diagnosis revealed! Never would of thunk it. Not on this bottom end.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stetson12DCLB, Jan 28, 2024.
  1. Feb 3, 2024 at 8:55 AM
    Stetson12DCLB
    Stetson12DCLB [OP] Member
    Silver 12DCLB 272k
    Icon add a leafs 1-1/2", Icon upper and lowers 2-1/2“ Bilstein 5100's all four corners.
    Thank you I am aware. But for now it is better than zero!!:thumbsup:\
  2. Feb 24, 2024 at 4:32 PM
    Stetson12DCLB
    Silver 12DCLB 272k
    Well quick update. It's been awhile I do apologize. During leak down testing of the cylinders a strange occurrence has come along. The Crank shaft is locking up. Stops, I go 360 in reverse and stops? So I tore it down pulled the timing cover and chains to see if it was the heads I just had machined but nope. Put it in neutral think maybe the tranny was doin it but that didn't work. Getting frustrated. Bout ready to pull the motor and go through the whole thing and while I'm at giving it nice rebuild with some Darton sleeves and OEM internals. I do appreciate the feedback I got from all you and thank you.
    billybop90 likes this.
  3. Feb 25, 2024 at 3:10 PM
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    I just have one question, you said you drained the oil and there was no metal shavings, so how could a rod bearing(s) be so bad that it sounds like the motor is going to come apart but you didn’t have an metal shaving in the oil?
  4. Feb 25, 2024 at 5:31 PM
    Mytrucklife
    Mytrucklife Well-Known Member
    2009 TRD Sport DCLB
    Sounds like flywheel bolt backed out.
  5. Feb 26, 2024 at 11:43 AM
    Stetson12DCLB
    Silver 12DCLB 272k
    I even put a magnet next to the oil while it was draining and nothing.
  6. Feb 26, 2024 at 11:48 AM
    Stetson12DCLB
    Silver 12DCLB 272k
    Transmission has never been pulled from the motor, you really think all of a sudden a bolt backed out? I mean that sounds like a great idea and I am going to definitely look into it. Just never would have thought a OEM bolt would decide to back out after all these years but I'm not mechanic! Thanks for the feedback!
  7. Feb 27, 2024 at 10:52 AM
    Derk33
    Derek
    Pennylvania
    Do you still have the oil filter to cut open? That’s a lot less work than pulling the oil pan off!
  8. Jun 26, 2024 at 7:31 PM
    Stetson12DCLB
    Silver 12DCLB 272k
    Well sorry it's taken so long but life has a way of screwing shit up sometimes! Update!! Rolled me a crank bearing! From what I've read it's nearly impossible to do. I mean I never missed an oil change, even changed it every 5k instead of 10k running royal purple in her... I never let maintenance go. Always the best for this little taquito. Anyone else experience this? And does anyone know where I can get a quality short block or should I just be buying from Toyota? Already found a junkyard motor for 2800 but have no idea how it's been treated. Would rather put my newly machined heads on a new or quality rebuilt short block. I'd rebuild the one that's in it but I kinda want it as a back up because I don't plan on being any easier on the new motor than I was on the old. Call me crazy but it's the only to drive these nachos! Like you stole it!
    Leomania likes this.
  9. Jun 26, 2024 at 7:47 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Can you elaborate a bit on "..hauling a bunch of weight and not letting up.."?
    What's "a bunch of weight" in lbs, approximately?
    What's your idea of "not letting up"? What kind of rpms & gear selection, on what kind of slopes and distances up hill?
  10. Jun 27, 2024 at 8:12 AM
    Brandon###
    Brandon### Well-Known Member
    A brand new short block from Toyota is about $3k. Choosing between an unknown junkyard engine and the brand new short block was the same choice i was faced with.
    I ended up with the new short block. Having a fresh set of heads makes the decision even easier IMO.
    goforbroke123 and Steves104x4 like this.
  11. Jun 27, 2024 at 8:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Yes. Do it once…
    goforbroke123 likes this.
