Taco lean 1/2" leaf shim
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Aug 7, 2016.
  1. Aug 7, 2016 at 1:17 AM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I'm looking to correct the rear Taco lean and this is the only remedy I have found. It's basically a 1/2" lift block. Do any of you have experience with this or some insight? Hopefully I won't have to be the guinea pig with this! :bananadead:
  2. Aug 7, 2016 at 2:28 AM
    NordidiroN
    NordidiroN Well-Known Member
    Ron
    Georgia
    '15 DCSB SR5 4x4
    Retrax MX Pro bedcover, Avid bumper gaurd, Predator step rails, Aux D rings, Door sill protectors
    Also interested in hearing about anyone's experience with these. I've got the lean front and back on driver's side.
    Anyone use them on BOTH sides for a small lift. :crapstorm:
    (and if you did, would you need longer shocks than stock?)
    ChadsPride and ManBeast like this.
  3. Aug 7, 2016 at 6:02 AM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    I have been trying to address my rear lean for a while now. It was 3/4 low on the left side with a full gas tank. Here is what I've done.
    After the recall and the 4 leaf pack was added, I tried that 1/2" shim on my left side only and saw almost no change in height. Because the brand new 4 leaf pack is still flat under just the weight of the truck, my theory is the 1/2" shim just provided more up force on the middle of the spring pack and it just deformed downward more because it wasn't strong enough to overcome the frame flex perhaps. After I added the 3 leaf progressive AAL, my pack had more arch under load, so I tried this shim again. This time it provided a little lift and evened me out to within 1/4. I still didn't like having a "block" in there and thought it might stress the pack over time, so yesterday I went to the local salvage, bought a used spring pack, took one leaf out and trimmed it to length, and replaced my middle leaf from the AAL with the "new" custom leaf, which had more arch than the removed leaf. This accomplished the same thing and I am very happy with the result. I'm within 1/4" left to right in the rear with a full gas tank. It's more work, but after having done both, I would recommend going the route of swapping out a single leaf with more arch into your pack. It's kind of trial and error, but you get really fast at swapping out leaves after a couple go arounds.
  4. Aug 7, 2016 at 6:03 AM
    jibski
    Josh
    Arvada, CO
    I would think this would be perfectly fine as it's only 1/2", and I doubt you'd need new shocks unless you went any higher in the rear.
    ChadsPride likes this.
  5. Aug 7, 2016 at 11:42 AM
    03f5sp
    Bill
    Wisconsin
    @jibski that's the other option I was thinking of, replacing a leaf. I have 2 OEM leafs + 1 Wheelers AAL + 1 over load leaf. My thought was to replace my 1.5" AAL with a 2". I'll have to ask Wheelers if they'd be willing to sell just 1 leaf.
    Semi unrelated, with the crappy 2+1 OEM pack + these AALs I'm expecting only 1" of lift over stock (it's a dcsb). Does that sound about right?
  6. Aug 8, 2016 at 3:26 PM
    03f5sp
    Bill
    Wisconsin
    I went ahead and ordered one 2" leaf and 2 pins for $40 shipped.
    Does the 1" of lift sound about right given the sacked out 2+1 pack and double cab after settling?
  7. Aug 8, 2016 at 3:27 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    I have them on both sides for a .5" lift. No issues at all.
    NordidiroN[QUOTED] likes this.
  8. Aug 12, 2016 at 12:42 PM
    O906
    O906 Well-Known Member
    I just installed that exact 1/2" shim. It's a waste of time really no change in my lean at all. I'm going to try replacing all the body mounts next as some people say they wear faster on the drivers side.
    I'm running brand new OME leafs with less than 1k miles on them and have 3/4" of lean to the drivers side.
    mx355 likes this.
  9. Aug 12, 2016 at 8:00 PM
    mx355
    mx355 Well-Known Member
    Trent
    TX
    2020 Trd Pro
    Kings, Method 316, Nitto Ridge Grappler
    Interested in these body mount bushings also, thought about the shim to fix my lean on my '14 but looks to not be a fix. When do you plan on doing the body mounts?
  10. Aug 12, 2016 at 8:35 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Search my name, you should be able to find a thread I created a few months back covering a similar topic
  11. Aug 13, 2016 at 5:11 AM
    O906
    No idea they are just on my "to do" list for the truck.
  12. Aug 13, 2016 at 5:15 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  13. Aug 13, 2016 at 7:11 PM
    jibski
    Josh
    Arvada, CO
    Swapping out body mounts won't do anything for rear lean. If you have 3/4" difference right to left, I would consider swapping out a single leaf from the left pack with a leaf with more arch. Or even just add another single leaf to the left. That should have more effect than using the 1/2" shim. But something doesn't seem right if you have that big of a discrepancy with brand new leaf packs. Have you verified you indeed have the right and left specific packs and they are on the correct sides?
  14. Aug 13, 2016 at 8:17 PM
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    2015 MGM DCLB TRD Sport 4x4
    Not an overbrander.
    Hey all, I've got that shim on my driver side and it corrected the driver side lean perfectly with no noticeable change in the ride.
