Taco Lean Adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Jan 16, 2022.
  1. Jan 16, 2022 at 6:21 PM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just got adjustable coilovers up front... truck sits lower by 1/2" on driver side. Coilovers are set at 2" height. I'd rather not go any higher up front... can you fix the lean by adjusting the passenger side down instead of going up on the driver side?
  2. Jan 16, 2022 at 6:26 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Driver side will need to be set to be set with 1/4 - 1/2" more preload depending on weight. Not much other way around it. Can do a lean spacer up top if you have adequate threads showing, but easier just to add preload. Doesn't effect ride quality a noticeable amount.
    Start by adjusting one side 3 rotations on the adjustment perch and see how it sits (either up or down depending on side). Adjust 1 at a time after until it's sitting perfect.
    On my third gen, my driver side is at 21 threads showing. Passenger side 17 threads.
    OffroadToy[OP] likes this.
  3. Jan 17, 2022 at 7:07 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Yes, there's no difference between bringing one side up vs the other side down. As long as you have the adjustability in the coilovers (which it appears that you do) then the truck doesn't care. You could also do have on one side half on the other.
  4. Jan 22, 2022 at 7:47 PM
    Skratch&sniff
    Skratch&sniff Well-Known Member
    I literally just noticed this on the front of my truck today and it’s driving me crazy. I thought Taco lean was just a rear end thing. I guess not.
    I have Elka 2.5s. I suppose I’ll need to remove the passenger side shock and compress the coil before making adjustments?
  5. Jan 22, 2022 at 7:48 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Yah just adjust the side you need up or down. Good to go
