Taco lean and Top Plate Spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacked Burton, Jun 26, 2020.
  1. Jun 26, 2020 at 9:20 AM
    Jacked Burton
    Jacked Burton [OP] Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Recently I replaced my stock coils with OME 887s to go with my Bilstien 5100s.
    I used a 1/4 top plate spacer on the Drivers side but i still have a 1/2" difference in level from side to side.
    I'm just about to pull the trigger on a 1/2" top plate spacer from Wheelers but was wondering if I will be needing longer studs to accomidate it.
    This is what its currently looking like
    Thanks Tacoworld!
  2. Jun 26, 2020 at 9:24 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    You need the longer studs.
    Jacked Burton[OP] likes this.
  3. Jun 26, 2020 at 9:26 AM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    Looks like you have more than .25" of thread free, but do you have .25" plus 3 threads?
    Are you doing the rear also?
  4. Jun 26, 2020 at 9:37 AM
    Jacked Burton
    I'm assuming these would be them?
    No the rear is fine.
    Just need another 1/2" (total) on the driver side to match the level of the passenger side(no spacer).
  5. Jun 26, 2020 at 9:38 AM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Yep those are the ones, you’ll need a BFH or a press
  6. Jun 26, 2020 at 11:52 AM
    cwadej
    Right Here
    2011 Access Cab 4x4
    oh, so you want a total of 3/4" spacer? yes, new studs needed
  7. Jun 26, 2020 at 8:07 PM
    Jacked Burton
    No, I'm just switching from a 1/4" spacer to a 1/2" spacer to level it.The 1/4"wasn't enough after putting the 887s on.
  8. Dec 18, 2023 at 6:20 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Thread reserection:
    Hopefully the OP chims in on the below.
    I recently installed an OME lift on my 2012 and have about 1/2" of lean on my driver's side.
    I'm curious if the spacer corrected the lean you had? How hard was it removing the original top plate studs and replacing with longer ones, did you need a press or did you hammer them out? Did you go with an aluminum or urethane spacer?
    Thanks in advance.
