Taco Lean + Coilovers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by swaggy veet, Dec 16, 2016.
  1. Dec 16, 2016 at 3:51 PM
    swaggy veet
    swaggy veet [OP] Well-Known Member
    OC, CA
    2017 Toyota 4Runner TRD PRO
    Hey all,
    I ordered extended travel King Coilovers and King rear shocks from DSM today
    For the notorious Taco lean, I have seen people remedy that with the little spacer on the driver side only.
    I am looking to crank the Kings up to get 3" of lift. I have 2 questions:
    How many threads/rings do you guys crank it up to to get 3" of lift?
    And how much higher should I crank the driver side to remedy the taco lean?
    Thanks all!
  2. Dec 16, 2016 at 4:02 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Adjust. Check height. Repeat.
  3. Dec 16, 2016 at 4:03 PM
    swaggy veet
    OC, CA
    Thing is I don't want to install, then have to keep taking them out, putting it together etc. I want to do it the first time so that I don't have to go through the hassle of it.
  4. Dec 16, 2016 at 4:09 PM
    ctfriel
    ctfriel @Overland_NC
    Winston-Salem, North Carolina
    2017 TRD OR AT (@overland_nc)
    Basic overland stuff...
    Maybe coilovers will be different but my issue (lean) was even more pronounced with the swaybar off. Same for my brothers 4Runner. His set perfectly level before lift and 1/2" lean (passenger high) after lift and swaybar removal. Just a thought, if you plan to pull the swaybar... i'd set it initially 3/4-7/8" High driver.
  5. Dec 16, 2016 at 4:10 PM
    swaggy veet
    OC, CA
    Yeah my sway bar is gonna stay there. I think the trim packer people usually get lifts it an extra 1/2 inch if I'm not mistaken?
  6. Dec 16, 2016 at 4:12 PM
    ctfriel
    Trim packer is approx. 1/4-1/2". Curious, why go King coilovers and run a swaybar? High speed stuff? Unfortunately our trails are way to tight and winding for running them with speed.
  7. Dec 16, 2016 at 4:13 PM
    swaggy veet
    OC, CA
    I don't know how that lift height translates into how many threads extra I need lol.
    Yeah I am not gonna go crazy high speed all the time, just here and there. More for bling factor and the nice ride lol.
  8. Dec 16, 2016 at 4:16 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I adjusted my icons 3 times before I was satisfied with it.
  9. Dec 16, 2016 at 4:18 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    Adjust them on the truck like everybody else?
    Loosen set screw, adjust up or down with spanner wrench, retighten set screw, drive and let settle. Then measure and adjust if needed.
    c4lvinnn likes this.
  10. Dec 16, 2016 at 4:19 PM
    Longboard1110
    San Jose
    A few things
    also don't forget to get it aligned AFTER you have settled on your ride height.
    dYL0n likes this.
  11. Dec 16, 2016 at 4:20 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Jack it up by the frame first
  12. Dec 16, 2016 at 4:20 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    If I'm not mistaken you should have to take them off to adjust. Just jack the side up you need to adjust and turn the ring, no?
    dYL0n likes this.
  13. Dec 16, 2016 at 4:20 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    I have king ext travel, skid and no armor. They came with 600# coils, I added preload and a 1/4" spacer to the drivers side... (if you add the spacer don't tell anyone on TW or they will reem you a new ass. Trust me). Anyway,I ended up doing a 650# eibach coil on the drivers side, same preload both sides, rides great and finally took care of the taco lean. I hate the taco lean! I also run no swaybar on the front, it corners like a dream now, before with the 600# coils on both and more preload on the drivers side it still felt uneasy. Just my 2c.
  14. Dec 16, 2016 at 4:22 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    I CANT BELIEVE YOU ADDED A SPACER WOW HERES A NEW ASS :fingerscrossed:
    Kadenm and DustStorm4x4 like this.
  15. Dec 16, 2016 at 4:22 PM
    swaggy veet
    OC, CA
    Yeah you do have to take them off to adjust the height. That's why I am asking if anyone has any pics to show how many threads for a 3" lift and how many more to get an extra 1/2 inch for the taco lean
  16. Dec 16, 2016 at 4:23 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    No more!!! FTW!
    dYL0n[QUOTED] likes this.
  17. Dec 16, 2016 at 4:24 PM
    Longboard1110
    San Jose
    A few things
    Why do you have to take them off?
    dYL0n likes this.
  18. Dec 16, 2016 at 4:24 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    I've adjusted mine 3 times. Never removed them.
    Jack it up, adjust, lower, then ride around.
  19. Dec 16, 2016 at 4:25 PM
    swaggy veet
    OC, CA
    Don't you have to take them off to adjust since the hose will get all tangled when you're jacking them up?
    That's what a guy at a local shop told me when I had my kings installed/adjusted on my Tundra last year.
  20. Dec 16, 2016 at 4:26 PM
    Longboard1110
    San Jose
    A few things
    That guy is a retard
    TacoRD16 and 90yota like this.
