Taco Lean in the rear?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SailinTacos, Jan 3, 2024.
  1. Jan 3, 2024 at 4:18 PM
    findbrianhere
    findbrianhere Well-Known Member
    Brian
    Bloomington, IN
    2016 Tacoma TRD Off-Road
    2.5" Old Man EMU Lift Add a Leaf Old Man Upper Control Arms 18" Black Rhino Rims 33" Nitto Grapplers Wescott Designs Rock Sliders Uptop Overland Alpha Cab Warren Synthetic Winch in-bumper Borla Exhaust Nitro 5.29 gears Genesis dual battery Morimoto headlights/taillights Injen Cold Air Intake
    I would think it's not a bed issue. The bed seems in line with the cab. I'd guess suspension..
  2. Jan 3, 2024 at 4:18 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Note that “taco lean” is normal and nothing to worry about.
  3. Jan 3, 2024 at 4:19 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Looks like the shop forgot to remove something from the passenger rear.
  4. Jan 3, 2024 at 4:22 PM
    findbrianhere
    Brian
    Bloomington, IN
    Not meaning to be a jerk, but if all the things the people on this site says is "normal for a Taco" no one would've ever bought this truck. So I have to laugh internally a bit when I see that comment. If that was a troll attempt, well played. LOL
    Lawfarin likes this.
  5. Jan 3, 2024 at 4:25 PM
    SailinTacos
    SailinTacos [OP] Well-Known Member
    2018 Black Tacoma TRD Off-Road
    i just replaced the left side shock because i was told that was the reason it leaned and it is not fixed, and what should i look for to fix it?
  6. Jan 3, 2024 at 4:26 PM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    Did the shop install the leaf springs on a car lift? If they tightened the bolts with the wheels in the air then the bushings will bind and cause it to do that. You could try loosening the front bolt and both shackle bolts on both sides then bounce the truck and retighten them.
  7. Jan 3, 2024 at 4:26 PM
    SailinTacos
    what did they forget? if this isn’t a troll comment lol
  8. Jan 3, 2024 at 4:28 PM
    gudujarlson
    Minnesota
    Do you understand that springs compress a distance relative to how much force is applied to them and, because the truck’s weight is not evenly distributed, the 4 spring’s compression is not the same?
    You cannot any expect car to be 100 level (unless it has some sort of active suspension that automatically levels the car).
    Even if you managed to get your truck perfectly level, it would cease to be perfectly level once you got in the driver’s seat.
  9. Jan 3, 2024 at 4:28 PM
    SailinTacos
    i’m not sure what they installed them. can i loosen them without a jack? they are known for doing toyota suspension so i never thought it would be a suspension problem.
  10. Jan 3, 2024 at 4:29 PM
    SailinTacos
    I understand that and i know taco lean is real but this is just a tad bit excessive in my opinion. my bed had the ordinary tools and a gun and case but i have them evened out
  11. Jan 3, 2024 at 4:30 PM
    2013TuRD
    2013TuRD Well-Known Member
    Bruce
    SW BC
    TRD OFF ROAD
    Looks like a broken spring to me.
  12. Jan 3, 2024 at 4:31 PM
    SailinTacos
    like leaf? i just had these installed brand new less than 3 months ago
  13. Jan 3, 2024 at 4:32 PM
    Darty03
    Darty03 •‿•
    You can. If it was done recently I would take it back to them. The truck didn't lean before they put the springs right? If so this is warranty or a mistake on the installer. The RXT leafs have 3 or 4 different ways to set them up and if they didnt mach it left to right that could be the problem too. Count how many leafs are in the left and right leaf spring packs and make sure they match
    Could be an honest mistake, it happens. Maybe the new guy worked on your truck, you never know
    Superdave1.0 likes this.
  14. Jan 3, 2024 at 4:33 PM
    AM_Taco
    AM_Taco Well-Known Member
    2020 Tacoma TRD Off-Road
    It did with mine. If you think of frame/cab of the truck as a rigid rectangle, if you lift the front drivers side it theoretically should lower the passenger rear a little and also raise the driver rear a little and help flatten it all out. At least thats how I interpreted it but I also could be wrong. My driver side was about 1/2" lower than my passenger side so I had it raised that much and it seems to fixed the lean for the most part.
  15. Jan 3, 2024 at 4:35 PM
    #35
    SailinTacos
    Alright i’ll call them then, i never noticed or no one ever pointed the lean out before i got new springs, i replaced them because the ride was stiff and they were used for heavy hauling before i bought the teuck
  16. Jan 3, 2024 at 4:35 PM
    #36
    Darty03
    Darty03 •‿•
    His looks to be a few inches of lean though. I am wondering if they put one to many leafs in the passenger side of the RTX leafs.
    YF_Ryan likes this.
  17. Jan 3, 2024 at 4:36 PM
    #37
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'd be interested in photos of the leaf springs on both sides of the truck so we can compare them. Taco lean is definitely a thing, but I haven't seen one that bad.
    findbrianhere likes this.
  18. Jan 3, 2024 at 4:37 PM
    #38
    YF_Ryan
    Kent, WA
    Something like this would make sense. Or again, like i mentioned above, if one rear spring was heavier duty, or had an extra leaf to counter the lean, and it was placed on the wrong side.
    T Fades likes this.
  19. Jan 3, 2024 at 4:39 PM
    #39
    gudujarlson
    Minnesota
    Measure it and report back.
  20. Jan 3, 2024 at 4:41 PM
    #40
    SailinTacos
    they gave me my add a leafs back that came with them
