Taco Lean no I don't have it
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pablo8, Oct 22, 2019.
  1. Aug 12, 2022 at 7:36 PM
    #41
    22TCLB
    22TCLB Well-Known Member
    Tim
    2022 tacoma lb
    It depends on how bad your OCD is.
  2. Aug 12, 2022 at 7:40 PM
    #42
    Arcticdc5
    Arcticdc5 Well-Known Member
    If it was a 1/2" - 1" difference, then yeah I'd def get a spacer. But for 1/16" - 1/8", not worth it. Guess I'll find out long term what the extra weight of the fuel tank and battery will do. But im not a fat a$$ either as I frequent the gym and watch what I eat.
  3. Aug 12, 2022 at 7:40 PM
    #43
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The lean appears after you lift it. Two factors affect this:
    1- the lift exaggerates any minor lean you already have.
    2- the OEM Toyota springs are different rates left-to-right (side specific). When you put in aftermarket OME springs etc, they are both the same rate, hence even more lean.
    My truck was level stock, but needed 1/4” lean spacer to sit level with OME 288 springs and 5100s set identical.
    Rock Lobster likes this.
  4. Aug 12, 2022 at 7:54 PM
    #44
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Taco lean is cool. Now get over it.
  5. Aug 12, 2022 at 7:55 PM
    #45
    Stocklocker
    17TRDORDCSBAT
    I think you are confused with Carolina Squat.
    Mully[QUOTED] likes this.
  6. Aug 13, 2022 at 6:11 AM
    #46
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Neither does mine. Been over 2 1/2 years hasn't started leaning yet.
  7. Aug 13, 2022 at 6:18 AM
    #47
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I haven't noticed the lean. :anonymous: Probably because I'm inside the truck when it's leaning. :anonymous::anonymous:
    I still installed my Bilsteins to compensate for it. I don't notice any change in that either.
  8. Aug 13, 2022 at 6:36 AM
    #48
    Bishop84
    Bishop84 Well-Known Member
    New tundra has tank on right, but fill neck on left.
    Battery on right. Exhaust on left.
    They mixed it up a bit. Expect it with the next gen tacoma.
  9. Aug 13, 2022 at 7:15 AM
    #49
    Arcticdc5
    Ok makes sense with adding aftermarket lift springs which both have the same rates. In order to account for this, could I put the spring perch on the second notch up on the Bilstein 5100 and leave the passenger side at the lowest spring perch setting? Or just get the $30 taco lean spacer and call it a day?
    Trying to do a 2" lift this weekend and reading about this gave me some disappointment that I don't have all the parts needed just yet.
  10. Aug 13, 2022 at 12:29 PM
    #50
    Stocklocker
    17TRDORDCSBAT
    I believe the spacer is the better option and they pretty much are calibrated for the exact amount needed. The 5100 settings are more coarse than on the 6112s which can be fine tuned for the lean.
  11. Aug 18, 2022 at 3:57 PM
    #51
    snowshine
    snowshine Well-Known Member
    My 2019 DCLB doesn't seem to lean.
    Pablo8[OP] likes this.
  12. Aug 18, 2022 at 4:10 PM
    #52
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Mine sits a 1/2" lower on driver side but it doesn't bother me enough to adjust the coilovers differently.
