Taco Lean Poll.... Theory 1
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sierrahsky, May 12, 2011.
If you have taco lean please explain your set up.
Poll closed Jun 11, 2011.
  1. + sway bar, + stock suspension
    6 vote(s)
    35.3%
  2. - sway bar, + stock suspension
    1 vote(s)
    5.9%
  3. + sway bar, + aftermarket suspension (explain)
    8 vote(s)
    47.1%
  4. - sway bar, + aftermarket suspension (explain)
    2 vote(s)
    11.8%
  1. May 12, 2011 at 5:42 PM
    sierrahsky
    sierrahsky [OP] Expedition Style
    Josh
    Reno
    09 TRD Tacoma V6 Ex Cab | Extreme Sierra
    Theory: Those who do not run the sway bar will experience taco lean when upgrading to a non adjustable suspension.
    Research: In the last year I have gone through about 8 different variations of my suspension set ups if not more. So I now have a theory on taco lean and want to see if its accurate. I have done countless changes to see if I can get the weight distribution as close to be exactly the same on both sides of the truck, and did not change to avoid skewing the results. This is what I have found:
    My set ups & Leans:
    Set up 1:
    Front: 3" Truxx Lift Level Kit (top plate spacer) w/stock shocks & Sway Bar
    Rear: Stock LEaf pack non tsb with 1.5" blocks w/stock shocks
    Lean: None
    Set Up 2:
    Front: 885 Coils with 1/4 top place spacer, Billies 5100's @ 0 + Sway Bar
    Rear: TSB Leaf Pack (4) + 2" AAL + Rear Billies 5100's
    Lean: None
    Set Up 3:
    Same as above but without sway bar
    Lean: 1/4" drivers side
    Set Up 4: (Without Front Bumper & Winch)
    Front: 886 Coils with 1/4 Top Plate spacer, billies 5100 @0 - sway bar
    Rear: Dakar HD Leaf Pack, 5100 Billies
    Lean: 2" (after 2 weeks reduced to 1.5")
    Set Up 5:
    Same as above - top plate spacer on drivers side + sway bar
    Lean: None
    Set Up 6: (With front bumper and winch)
    Front: 886 Coils, 1/4 Top Plates, OME 9000's, - Sway Bar
    Lean: .5"
    Set Up 7: (With front bumper and winch)
    Front: 886 Coils, 1/4 Top Plates, OME 9000's, + Sway Bar
    Lean: None
  2. May 12, 2011 at 5:51 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Taco Lean- prior to and after adding the TSB springs and 5100's all around fronts set at 1.75".
  3. May 12, 2011 at 5:54 PM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    x2
  4. May 12, 2011 at 5:55 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Did you guys add the 1/4" driver's side spacer ?
  5. May 12, 2011 at 5:55 PM
    durf4694
    durf4694 giggity giggity
    ny
    06 tacoma sport
    K&N cold air kit, Kenwood double din with dvd player, navigation, rear cam. hook up with One JL 12" sub powered by a 800 watt pioneer amp, Sirius/XM satellite radio, TRD Neoprene Seat covers, Tinted windows all around, Trifecta Tonneau Cover, Billies at 1.75 and a 1.5 block in the back
    no stock lean for this guy . lucky i suppose
  6. May 12, 2011 at 6:05 PM
    Largefarva
    Largefarva Well-Known Member
    Fox Lake, IL
    '08 Double Cab TRD Off Road 4x4
    X 3
    And yes, I have the 1/4" driver side spacer.
  7. May 12, 2011 at 6:08 PM
    RLDTACO
    Bob
    Houston Tx.
    I have 5100's set at 0 and Eibachs with 1/4" spacer on driver side rear TSB. There is only about 1/4" difference.
  8. May 12, 2011 at 6:10 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Good timing on this one Josh. I put my diff drop back on today and may be raising my front up from .85 to 1.75 tomorrow, but I noticed my lean had increased in the last year (since I put the 5100s on). The lean is now very noticeable from the front with a 3/4 inch difference up front and 1/4 in the rear. I started thinking about the spacer, but then people here are saying that it didn't fix it. I also wondered (maybe someone here can tell me) whether adding the 1/4 inch spacer throws off the alignment? Trying to decide whether to get the spacer and wait on raising the front, or whether to raise the front tomorrow and deal with the spacer later.
    5100s all 4 corners, no tsb, AAL, sway bar, original springs
  9. May 12, 2011 at 6:28 PM
    RLDTACO
    Bob
    Houston Tx.
    The shop that installed my 5100's and Eibachs said that I would need the 1/4" driver side spacer to keep things level. They said the OEM front coils on the newer trucks are side specific to help with the Taco lean. The Eibachs are not side specific so more lean. My truck stayed about the same, about a 1/4" difference.
  10. May 12, 2011 at 6:29 PM
    KEG'sTACO
    KEG'sTACO FJ Cruiser
    Kurt
    Auburn, AL
    '08 FJ Cruiser
    Leveled, 33" BFG A/Ts, Demello Offroad front flat-top bumper, Demello Offroad rear 3-piece bumper, 17" Liquid Metal Gatlins, Pioneer audio upgrade, custom mounted 10" subwoofer, offroad interior
    Stage 1 6" Procomp Suspension lift with stock leafs (no TSB) and Procomp MX900 rear shocks. Stock Billies up front. Noticeble taco lean.
    EDIT: No swaybar
  11. May 12, 2011 at 6:35 PM
    DCW
    DCW Well-Known Member
    David
    Reno, Nevada
    2011 TRD DC Off Road
    TRD exhaust, front skidplate,5100s@1.75
    No taco lean here untill I get into the truck, I need to loose some weight:D The truck lean goes away when my dad rides with me we both weight 285.
  12. May 12, 2011 at 7:32 PM
    sierrahsky
    Josh
    Reno
    Reno.... When are you going to come wheeling?
  13. May 12, 2011 at 8:34 PM
    DCW
    David
    Reno, Nevada
    Let me know when and where? I am usually open on the weekends.
    Hit me up with a pm.
  14. May 12, 2011 at 8:39 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    Set up:
    Front: AP bumper/winch, 885's, 5100's at .85, 1/4" top plate spacer, no sway bar
    Rear: Stock LEaf pack with 2" AAL, 5100's
    Lean: 1/2" to PASSENGER side (wtf)
    Possibles: Stock leafs are soft (almost 6 years old) and also have a 60" Hi-Lift mounted on the passenger side of the inside of the bed. I was sitting dead level after the lift and bumper went on, but after my first trail run hitting some hard bumps, I had the lean to the passenger side. I think my leafs are too soft now.
    Will report when I upgrade the leaf pack with aftermarkets.
  15. May 12, 2011 at 9:39 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Wouldn't the differances in the amount of gas in the tank throw off the measuments?
  16. May 12, 2011 at 9:43 PM
    OZ-T
    Peter North
    British Columbia
    Front : OME 885x no spacer , OME 90000 shocks
    Rear : OME Dakar leaf pack , OME N182 shocks
    Stock front and rear bumpers , OME trim packer on driver's side , sway bar installed
    No lean
  17. May 12, 2011 at 10:20 PM
    sierrahsky
    Josh
    Reno
    I should point out that all my coil sets were x series.
    Will do , as soon as my back heals.
    No, Running a full tank would not drop you that much. If its doing that you really really really need new springs.
    I know that on the 08,09+ the engine bay is a different layout.
  18. May 13, 2011 at 5:23 PM
    DCW
    David
    Reno, Nevada
  19. May 13, 2011 at 5:26 PM
    sierrahsky
    Josh
    Reno
  20. May 13, 2011 at 5:49 PM
    DCW
    David
    Reno, Nevada
