Taco lean questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zoster57, Dec 20, 2022.
  1. Dec 20, 2022 at 10:59 AM
    Zoster57
    Zoster57 [OP] Member
    2004 Red Tacoma
    None
    My 2004 Tacoma 4WD has a noticeable driver’s side lean. (Common I know). I have searched the forum a bunch but I have questions for those more knowledgeable.
    1) what spacers do you recommend. Motofabs look reasonable. I’m not opposed to self-fabrication but would need detailed advice.
    2) How doable is this for someone who has some mechanical ability but more often defers to professionals.
    3) are there any links available for “how to do”. I’ve searched YouTube to no avail.
    Thanks in advance.
  2. Dec 20, 2022 at 12:40 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Any brand should be fine. I'm sure they're all just a chunk of aluminum. Haven't run one in a while but I believe the most common is 1/4" .
    Zoster57[OP] and Taco critter like this.
  3. Dec 20, 2022 at 1:21 PM
    seabeegt
    seabeegt Well-Known Member
    Greg
    03 Tacoma 3.4L V6
    4” Lift, Exhaust Pipe
    I put a 1/2” spacer on mine to combat the “Taco Lean” and it gave me a 1”rise in total. Worked out perfectly. The only sketchy part was using the spring compression tool I rented from Autozone… there’s a whole lotta pressure on the assembly when u tighten it down, be careful. Definitely use gloves and eyepro. I ended up snapping one of the compression tools and it gave way with a tremendous amount of force. It’s a total DIY project, but just be wary of what you’re doing and watch some videos on it first. Good luck
    Zoster57[OP] likes this.
  4. Dec 20, 2022 at 1:58 PM
    Lucky_Gargoyle
    Lucky_Gargoyle Well-Known Member
    96 DLX 2.7 4x4 5spd
    Toytec coil-overs, SPC upper, OME CS019 leafs w/ 5110 bilstein, LCE header
    NEVER use aluminum as it is a pliable metal. Steel only, unless you want future troubles.
  5. Dec 20, 2022 at 2:12 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Hmm, I had Toytec on mine previously which were aluminum and didn't notice any issues. Had them on for about 6 years. Looks like Icon uses steel. So if it's a concern for someone, I guess they'll have to choose based on their research.
  6. Dec 20, 2022 at 2:18 PM
    Zoster57
    2004 Red Tacoma
    None
    I appreciate the advice. Anyone have a link to some videos?
    Thanks
  7. Dec 20, 2022 at 2:24 PM
    Lucky_Gargoyle
    96 DLX 2.7 4x4 5spd
    I have toytec Aluma coil-overs sure but any spacer I used was steel.
    Here are my 2.5 degree shims to fix pinion angle. They are steel shims
  8. Dec 20, 2022 at 2:28 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    I can't remember what my shims were. They may have been steel. I was referring to the front spacer. I assumed that's what was in question from the OP.
  9. Dec 20, 2022 at 3:01 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
  10. Dec 20, 2022 at 3:01 PM
    Lucky_Gargoyle
    96 DLX 2.7 4x4 5spd
    That is what I read front spacer for lean.
    i.e. steel
    https://www.offroadwarehouse.com/product/14-lean-plate-spacer-2005-2020-tacoma-4runner/Default.aspx
    https://tacomabeast.com/products/su...-2002-2005-2021-toyota-tacoma-0-5-lean-spacer
    My toytecs are adjustable so I didn't need any spacers but if I did it would not be aluminum. Lots of jolting around down there and hard metals better than soft. Just my two bits
    Also I use my + OME leaf on driver side and the - on passenger. Still a tad taller on passenger side but not by so much it would make any difference. I put my heavier tools passenger side.
