Taco lean/Tire fit Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by horstm87, Mar 29, 2016.
  1. Mar 29, 2016 at 11:55 AM
    horstm87
    horstm87 [OP] Active Member
    I have a 2015 Sport dbl cab. Planning on getting Bilstein 5100s and setting them at .85. Do I need to account for the taco lean and get a spacer if I'm not changing the coils?
    Also plan on getting 265/70/17 Hankook Dynapro Atms with Pro comp 7031 wheels. Will I have any fitting issues such as rub?
    Thanks for the help!
  2. Mar 29, 2016 at 11:58 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    you should be good with the tire size. The taco lean i believe becomes more obvious with a lift.
  3. Mar 29, 2016 at 12:22 PM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    Stock springs already account for the lean. Make sure you put the drivers side spring back on the drivers side.
    You won't have any issues with the tires. Except maybe front mud flaps.
  4. Mar 29, 2016 at 12:24 PM
    horstm87
    Appreciate the info fellas!
