Taco Lean, top plate spacer necessary with 5100s?
Discussion in 'Suspension' started by STLTaco09, Jun 26, 2009.
  1. Jun 26, 2009 at 8:55 PM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    So I've searched, and I've read threads that say the 5100s lifted to .85, 1.75, or 2.5 will negate the need for the top plate spacer to fix the taco lean. Then I've also read threads that say lifts above 3 inches will correct the taco lean.
    So whats the verdict? If I lift to 1.75" or so, will that correct the taco lean? Or should I still opt for the spacer for the driver side?
  2. Jun 26, 2009 at 9:25 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    My taco has the taco lean. Both sides are set to 2.5 but the driver side seems to be acting like its at 1.75. Get the spacer to correct it. The lean sucks.
  3. Jun 26, 2009 at 9:36 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    It leans like a cholo! So the spacer would be only for one side i.e. Driver's side or Passanger side? :notsure:
  4. Jun 26, 2009 at 9:37 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    Driver side.
  5. Jun 27, 2009 at 5:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The 5100's are adjustable......
    Adjust the low side to correct the lean. No spacers needed.
    If you have the 5100's adjusted to its highest setting, then you'll need a spacer.
  6. Jun 27, 2009 at 6:01 AM
    STLTaco09
    I think I'd rather use the top plate spacer than adjusting the 5100s to a different setting on each side...
  7. Jun 27, 2009 at 6:29 AM
    Janster
    Jandy
    Lancaster, PA
    I'd do some research.... How big of a top plate spacer are you thinking of using?
    You really shouldn't go any higher than a 1/4" thick spacer (= 1/2" lift).
  8. Jun 27, 2009 at 6:43 AM
    STLTaco09
    Yep, its just the 1/4" top spacer plate for the drivers side to level it out with the passenger side. I think toytec sells it as a 5mm trim packer.
  9. Jun 27, 2009 at 6:54 AM
    Brunes
    Brunes abides.
    Rotorhead
    The 5mm trim packers only work with OME springs/shocks. Toytec makes a 10mm/ .25inch top plate spacer that they sell in sets of one I think
  10. Jun 27, 2009 at 8:01 AM
    Janster
    Jandy
    Lancaster, PA
    That's because the trim packer installs at the bottom of the coil seat?
    (if I'm thinking correctly?)
  11. Jun 27, 2009 at 8:27 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yes...That's exactally it.
  12. Jun 29, 2009 at 7:36 AM
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    I literally just had this scenario over the weekend, I went to a 4WP shop and had 5100s and an add a leaf put in. I bought the spacer from ToyTec and took it in to be installed with the billys even though I measured out the passenger side to be the same as the driver side before I made the purchase. I figured with adjustable shocks the lean would eventually happen(truck had 40000 on it and no lean yet) so I wanted it put in as a 'preventative'
    4WP would not install the spacer since both sides were spec, so maybe I have avoided the Taco Lean altogether :confused: We'll see...
    I also somehow avoided any shudder at low MPH without shims or a carrier drop using the Toytec 2" AAL (non TSB) -whatever that means, whacky how much that varies truck to truck
    ( I went 1.85 on the front billys)
  13. Jun 29, 2009 at 7:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    10mm is .40 inch, and would give just over 3/4" lift. :)
    I dont have any left right now, and am kinda booked on the next batch. Also, FWIW, I dont think I can fix any lean over 2/3".....thats thicker than I want to go for a "Shim". :eek:
  14. Jun 29, 2009 at 8:08 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    :popcorn: Im curious about this as well, as I am very close to pulling the trigger on some 5100s.
  15. Jun 29, 2009 at 8:10 AM
    STLTaco09
    I measured my lean to be right at .5". I think the toytec spacer will be plenty sufficient at 1/4" spacer giving and extra 1/2" to the drivers side.
  16. Jun 29, 2009 at 12:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should work perfectly. :)
  17. Jun 29, 2009 at 1:06 PM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    i noticed my rear driver tire wearing more on the outside. then i noticed my front passenger side is up a little higher than the front driver side. i have the billys set at 1.85. could this be caused by the lean you guys are talking about?
  18. Jun 29, 2009 at 1:06 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I had .5 lower on the passenger side with oem tokicos. I went with 5100s set on 2.5 with TRD springs & the Toytec .25 top plate leveling spacer on the driver's side. Nuts on strut still threaded all the way on & magically (or not) the front is now level.
  19. Jun 29, 2009 at 2:03 PM
    STLTaco09
    Excellent, thanks for the info everyone. Looks like the 5100s do absolutely nothing to help the lean.
    Funny thing is, if it weren't for the tape measure, I wouldn't have even known it was there...
  20. Jun 29, 2009 at 3:37 PM
    Janster
    Jandy
    Lancaster, PA
    Whatta ya mean by that?
    For anyone who's installed the 5100's - are you running stock coils?
    Are you making sure the coils are on the proper side? The 1st gen trucks - the coils were side specific.
    Have you tried swapping the coil assemblies from side to side?
    And lastly, again...the 5100's are adjustable. You can adjust them to correct for the lean. Or, get a 1/4" thick spacer ontop the assembly.
