Taco lean.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crf69, Sep 11, 2010.
  1. Sep 11, 2010 at 5:49 PM
    crf69
    crf69 [OP] scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    mine is....indeed leaning towards the driver's side....it showed up two days after my 5100 install.....my question is.....because i took it to get aligned 30 minutes after i installed the billie's "NO Lean" has my alignment now been affected after the "lean" arrised? By the way the lean dont bother me at all....unless of course the alignment went out....just real particular about shit that's all thanks
  2. Sep 11, 2010 at 5:52 PM
    Call0043
    Call0043 just cant leave anything stock !
    Chesapeake Va.
    baby seat, BHLM, satoshi, stubbs sliders, full OME suspension with extra leaf,black fog light mod , debagged,
    mine has the lean also on stock suspension had the lean both before and after the rear spring TSB
  3. Sep 11, 2010 at 6:00 PM
    jakoons86
    jakoons86 Active Member
    jason
    calera, alabama
    07 tacoma dbl cab pre
    na
    mine was leaning to the driverside then when lifted it started leaning to the passenger side very weird
  4. Sep 11, 2010 at 6:11 PM
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    it sounds like it just settled a little bit after having a load finally put onto the shocks, if they are adjustable you can just adjust them to being even, i wouldnt think it would affect your alignment very much, minimal at best, most of the alignment is from the UCA unless im wrong but i had a lean on the driver side and all i did was just adjust the coilover up higher, hope this helps
  5. Oct 30, 2010 at 5:44 PM
    crf69
    Ohio
    ummm yeah
    so you have one side adjusted on the 5100 higher than the other? ehh ehh i ain't doin it
  6. Nov 1, 2010 at 7:09 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I measured mine before I installed the 5100s and my passenger side was 1" higher than the driver's side. I installed the 5100s and put a 1/4" spacer on the driver's side and now there is only 1/4" difference, but isn't noticeable with the naked eye.
  7. Nov 1, 2010 at 7:37 AM
    Range 44
    Range 44 Well-Known Member
    Georgia
    2008 FJ TTE
    I think the gas tank is on that side, the difference prob varies?
  8. Nov 1, 2010 at 7:42 AM
    crf69
    Ohio
    ummm yeah
    mine is very visible...i dig it really:cool:
  9. Sep 17, 2011 at 12:17 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    He is talking about a coilover with a threaded collar, like this:
