Taco lean
Discussion in 'Suspension' started by Snake~, Aug 4, 2011.
  1. Aug 4, 2011 at 7:58 AM
    Snake~
    Snake~ [OP] Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Correct me if I'm wrong: You only need the to 1/4" spacer if 1) your stock drivers side spring is sagging or 2) you're not using stock springs, right? The stock drivers side spring is a little longer or stiffer than the passenger side spring isn't it?
  2. Aug 4, 2011 at 9:33 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I would like the answer to this as well.
  3. Aug 4, 2011 at 9:46 PM
    Umrunner
    Umrunner Caltanian
    Bay area, and Missoula, mt
    '11 DC OR Timberland Mica. 6 speed.
    Leer 100xr with adventure package, bfg at's, weathertech's, demello sliders, billie 5100's all around, URD short shifter, Diff breather mod. BDF lightbar. Grillcraft grill. PIAA 520 severe weather driving lights. Other random stuff as well.
    i put 5100's in all around, and had the TSB done. Also set the fronts at .85 to level it off (have a topper).
    Still had some of a lean and wanted to get rid of it.
    Put the spacer on it, and no more lean, no more issues. Its worth it, and gets rid of the lean (more or less).
  4. Aug 5, 2011 at 6:39 AM
    Snake~
    Blake
    DFW
    2010 DCSB TRD Sport
    Are you using the stock front springs?
  5. Aug 6, 2011 at 1:27 AM
    Umrunner
    Umrunner Caltanian
    i am using stock front springs.
  6. Aug 6, 2011 at 1:29 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    correct....the 1/4 top plate will eliminate the taco lean...I'm running one. You can get one from Toytec for 20-25 bucks
  7. Aug 8, 2011 at 7:29 AM
    Snake~
    Blake
    DFW
    2010 DCSB TRD Sport
    OK, good to know. I thought I remembered reading that the stock front springs were side specific to compensate for the lean, but it sounds like that's not the case. Thanks guys.
