Taco lean
Discussion in '1st Gen. Tacomas (1995-2004)' started by quetzal, Oct 27, 2016.
  1. Oct 27, 2016 at 3:08 PM
    quetzal
    quetzal [OP] Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    I'm running King ext coilovers w/AP ucas and AP expo leaf pack. My question is regarding the taco lean and how to properly counter that by slightly raising (coilovers) the DRIVER side of the truck. When you guys are doing this, are you at all concerned about the gas tank being full, empty or half? Obviously with a full tank of gas the lean will be much more severe. Looking for opinions. Thanks guys.
    EDITED
  2. Oct 27, 2016 at 3:22 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    You raise drivers side not passenger.
  3. Oct 27, 2016 at 3:24 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I would first do a measurement 1/2 tank if your suspension is brand new, let it settle, then adjust accordingly. 18 gallon tank at 6lbs per gallon at 1/2 a tank that is approximately 54lbs +/- additional weight if you fill up the tank, I'm sure you won't notice a huge lean if you filled the tank up.
  4. Oct 27, 2016 at 3:25 PM
    quetzal
    Mario
    Long Beach, CA
    My bad - that's what I mean to say.
  5. Oct 27, 2016 at 3:43 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    The Taco lean is most always due to the settling of the suspension.
    Consumable suspension components are not for ever.
    battery, fuel&tank, driver weights are the cause.
    Well that ^ along with gravity and time.
    Adj. CO's can be pre-loaded for compensation.
    As well... the rear leaf spring can also be compensated
    by having more arch put into the driver's side.
    I had custom Deaver leaf spring made for mine.
    and those have an additional 1/2" arch added to the driver's side.
    This added leaf spring arch compensated very well...
    and both my Fr adj. CO's are pre-loaded equally.
    Another fix is... maybe try going on a diet ? Lol
  6. Oct 27, 2016 at 5:05 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    My OME suspension came with a washer on the drivers side strut to combat this.
  7. Oct 27, 2016 at 10:53 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    ...You typed washer as a description.
    But are you meaning: "a shim was placed in with the coil spring assembly"
    to increase pre-load on the driver's side ?
  8. Oct 27, 2016 at 10:57 PM
    eon_blue
    Azusa, CA
    Pretty sure he meant to say a spacer, I got the same 1/4" spacer with my kit and it looks like a giant washer lol.
  9. Oct 28, 2016 at 5:10 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Washer, shim, spacer....Blah! It still does the job.
    eon_blue likes this.
  10. Oct 28, 2016 at 12:32 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    a washer goes on a bolt
    a spacer usually stacks atop the CO externally (bad move)
    a shim is sandwiched inside along with the coil spring to increase coil pre-load.
    all three have different purposes and do not share a common nomenclature.
  11. Oct 28, 2016 at 1:03 PM
    devinzz1
    devin
    2023 aclb trd or mt
    its called a trim packer. it goes on drivers side for the taco lean.
    KdF likes this.
  12. Oct 28, 2016 at 2:30 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    where is that stated ? I don't see that reference used on the OME site.
    trim packer sounds more like a boat or plane thing to me.
    It's called a "pre-load shim" by most
    Purdy much the same deal as when some folks call a sunshade on there jeep's roll cage a...
    "bikini top" when in originality it was referred to as a "bi-mini top".
    probably forums like this one caused folk to start calling it something it wasn't originally labeled as.
  13. Oct 28, 2016 at 3:12 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    https://www.google.com/#q=old+man+emu+trim+packer
  14. Oct 28, 2016 at 3:35 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
