Taco Lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 3X4X4, Mar 18, 2018.
  1. Mar 18, 2018 at 8:14 AM
    3X4X4
    3X4X4 [OP] Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    My truck, a 2006 TRD O/R, from day one never sat correctly. It was always seemingly lower than other Tacomas and it leaned. Despite the several TSBs for the leaf pack, it still sat low and leaned.
    So, now it sits on a Toytec Ultimate lift (adjustable coil overs) with the AL rear and of course it still leaned. But I gained exactly 2 inches rear and 3 inches plus on front on each side. After letting the suspension settle a little I adjusted the driver front down .5 inches, the passenger front down 3/8 inch (I wanted to drop overall height too, adjustments are a 2:1 ratio, 1/4 inch coil over = 1/2 inch of lift)) and then I added a steel 1/2 inch shim on the driver rear leaf pack.
    I may let the fronts settle some more if they do and drop the front a skosh more just to reduce overall lift to 2.5 inches because the front is still proud of 2.5 inches lift.
    On another topic, what good are the removed front coil overs? Are the TRD O/R springs worth saving for a buddy or something?
    J
    Tacomamike mike likes this.
  2. Mar 18, 2018 at 8:22 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Ok pictures of said lifted truck are mandatory! Old suspension is worth a couple hundred bucks ...or donate them.
    And I’m just leaving Lawerence for Las Vegas.
