Taco lean
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vea, Apr 8, 2018.
  1. Apr 8, 2018 at 3:26 PM
    Vea
    Vea [OP] Well-Known Member
    2018 Tacoma or
    Trying to understand why lifted trucks have the lean and stock does not?
  2. Apr 8, 2018 at 3:28 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The search function (on TW and Google) is your friend. Stock Tacomas have lean too. Caused by gas tank, battery and driver all on one side. Jeep XJs have it too.
  3. Apr 8, 2018 at 3:37 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    I second this....
    *sidenote: install 1/4" spacer during lift on drivers side, viola! taco lean gone.
  4. Apr 8, 2018 at 3:49 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I think Taco lean gives our trucks a "sassy" look. It's got attitude. :rimshot:
    thomas3ford, Optimaltaco and Hawk45 like this.
  5. Apr 8, 2018 at 3:51 PM
    tcjacado
    tcjacado Well-Known Member
    Like walking with a limp cause your dick is to big?:yes:
  6. Apr 8, 2018 at 4:00 PM
    bangin4WV
    bangin4WV Well-Known Member
    Rocky
    WV.
    2016 SR5 2.7 MGM ACLB
    33s/sliders
    How does the 1/4'' spacer on the front fix this, does the rear not lean as well?
  7. Apr 8, 2018 at 4:02 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    They are separate.
  8. Apr 8, 2018 at 4:04 PM
    bangin4WV
    Rocky
    WV.
    33s/sliders
    :confused:
  9. Apr 8, 2018 at 4:41 PM
    Whitetail Assassin
    Tedric
    West Virginia
    The cab and bed are separate and react differently to the added weight or driver battery etc.
    AverageGuy likes this.
  10. Apr 8, 2018 at 5:44 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Toyota lean is the proper term. Otherwise my FJ also had a taco lean...
    Whitetail Assassin likes this.
  11. Apr 8, 2018 at 5:45 PM
    Lt. Dangle
    Ohio
    Stock trucks absolutely do have the lean as well.
  12. Apr 8, 2018 at 9:04 PM
    1998purplepickup
    1998purplepickup Well-Known Member
    St. Michaels, MD
    1998 4wd 2.7L Tacoma
    warn vr 8-s winch welded rack and canopy LED bars front and rear Front and rear diff breather ext. lift
    to my knowledge, if the truck leans to driver, and you add a spacer above the front coil, the lean will level out and disappear. I dont know how to explain why though. Perhaps it's the same principle as leveling a box for a kitchen cabinet installation. if you lift one corner, the opposite corner will drop.
    since the rear passenger is higher than the rear driver, lifting the front driver will force the rear passenger down, leveling the lean. Maybe i'm wrong.
  13. Apr 9, 2018 at 2:26 AM
    bangin4WV
    Rocky
    WV.
    33s/sliders
    That makes sense.
