Taco lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Luimtz, Oct 22, 2019.
  1. Oct 22, 2019 at 3:27 PM
    Luimtz
    Luimtz [OP] New Member
    Luis
    Toyota Tacoma 08
    I have an 08 Tacoma. the problem I’m having is that it’s leaning more towards the drives side. About 1.5 inches. What size disc would I need to add to the front?
  2. Oct 22, 2019 at 3:31 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    1/2 inch spacer installed will raise that drivers side by 1 inch and you should be good.
    Do you have an aftermarket lift? If you know the details we can help you better
  3. Oct 22, 2019 at 4:07 PM
    Luimtz
    Luis
    Toyota Tacoma 08
    Tbh I have no idea. I just recently bought this truck. All I know for the rear is that it has stock leaf springs with the 3inch lift kit. Would I have to switch out the rear left block to compensate?
