Taco Man in HD's Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Taco Man in HD, Dec 12, 2011.
  1. Nov 25, 2013 at 1:22 PM
    #141
    Taco Man in HD
    Taco Man in HD [OP] DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
    No problem, this is the one I bought... http://www.rdmoffroad.com/RDM-3-Way-Spare-Tire-Strap.aspx
    Thanks, I appreciate it. :thumbsup:
  2. Dec 16, 2013 at 8:15 PM
    #142
    Taco Man in HD
    Ohio
    Did some late night shopping a few days ago and finally bought some one-piece "spyder" headlights. Tested the led's today and will be sure to seal them before I install...
    AD32C5E8-E571-40AF-B743-55F459E0E2CD_zps_51a1d2d3f15f7c2c3fc67f259a46169709ebe4a6.jpg
    ...my current headlights and corners will be for sale soon. :cool:
    I also welded some tabs for two OKLEDLIGHTBARS 6-LED pods with Amber Covers I had around to use through the stock bumper lower valance since I have it on for winter...
  3. Dec 16, 2013 at 9:09 PM
    #143
    PreRunning
    PreRunning Well-Known Member
    Clayton
    Missouri
    01 Lunar Mist Prerunner SR5
    Window Vents, Westin Bull Bars, Kenwood Deck, Kicker and Kenwood Door and rear Speakers, Alpine 660 RMS Amp, Twin Kicker 12 inch CompVR Series Subs, 265/75/16 Wrangler ArmorTrac Tires, Uhaul Towing package, removed mud flaps, Flowmaster 40, Cold Air.
    Can't wait for the pictures of those installed and the led pods! Are you going to put them where the turn signals are now?
  4. Dec 19, 2013 at 4:24 PM
    #144
    Taco Man in HD
    Ohio
    Here you go! I've tried to mount pods or 6" bars in the turn signal area before, but they never fit right or filled enough of the hole, so I just welded tabs to the support behind the valance.
    Here's what the one-piece lights look like after being installed and wired into the running lights. The led strip color is as white as the led pods, just looks weird in the pictures. The headlights definitely fit into the fiberglass better than the old corners...and I think it'll look better once the road salt stops and I put the front bumper back on. :thumbsup:
    3DF3EBDA-B2FF-4280-9923-7BF90D7289B7_zps_611ef9cf5387ad4004fdcec79c1f985b34476624.jpg
    ...shortly after this picture, the headlights passed their first automatic car wash test without seeing any condensation inside of them. (I sealed them before I installed.)
  5. Dec 19, 2013 at 8:32 PM
    #145
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Can you describe what steps you took to seal them?
  6. Dec 19, 2013 at 9:01 PM
    #146
    Taco Man in HD
    Ohio
    Sure, it might be unnecessary but after seeing some threads on here where people had water leaks, I basically covered every spot on them where the clear lens meets the black housing with a thin bead of clear silicone. Just enough to fill the tiny gaps and I also filled the holes where the led wires come out.
    I did the same process on my old headlights that were from eBay and they never had water issues, so hopefully it works again.
  7. Dec 20, 2013 at 9:05 AM
    #147
    PreRunning
    Clayton
    Missouri
    Those look killer! I really want to find an alternative for those unused turn signals on my truck. Did you take any pictures of the leds in those spots?
  8. Dec 20, 2013 at 9:24 AM
    #148
    Box Rocket
    Adam
    Syracuse, Utah
    Thanks
  9. Dec 21, 2013 at 9:49 PM
    #149
    Taco Man in HD
    Ohio
    I don't have any pictures of them in the holes, but I've seen somewhere on TW where someone put 8" single row bars in the bumper holes with some dremel-ing. I'll pm you if I can find anything helpful.
  10. Dec 22, 2013 at 7:25 AM
    #150
    PreRunning
    Clayton
    Missouri
    Ok thanks!
  11. Jan 31, 2014 at 1:25 PM
    #151
    cbassd
    cbassd Member
    sebastian
    Nor cal Davis
    02 tacoma
    tc uca, 2.5 icon coilovers with resis, trd supercharger,flow master,u-bolt flip kit,,, all-pro standard pack leaf springs,10 inch travel 2.0 fox shocks with remote resis,21inch led bar,ham and cb radio,4xinnovation sliders, custom from bumper, prp bucket seats and deist 5-point harness
    You drilled threw the roof to mount the lab rak brackets??? Have you had any trouble with them after mounting them
  12. Jan 31, 2014 at 6:00 PM
    #152
    Taco Man in HD
    Ohio
    Yeah, I drilled through the roof. It's just a few small holes, and never had any leaking using silicone with the mounting bolts that went above the headliner. I'm looking to sell the labrak mounts if interested. :thumbsup:
    I removed the mounts and sold my lightbar recently and put some rubber plugs in with some silicone and you can't even tell the holes were there unless you are looking down on the roof. I hope to get a new lightbar and fab some new mounts in the spring. :D
  13. Jan 31, 2014 at 8:51 PM
    #153
    cbassd
    cbassd Member
    sebastian
    Nor cal Davis
    02 tacoma
    Alright sounds good damn it I just ordered the mounts like 3 hours ago haha,,
  14. Feb 19, 2014 at 2:11 PM
    #154
    Taco Man in HD
    Ohio
    Well, I was wrong about leak-proofing the headlights..haha. Just like most others, I noticed my one-piece headlights started to have small amounts of misty water inside the lens, so I'm in this process now...
    It's my first attempt at a retrofit, so we'll see how it turns out. I should be finished tomorrow, and will post some finished pictures. :cool:
    71DE03AD-1D10-486A-B662-42F2A16F0FAC_zps_385e2055cd6651ba3eb3d3970f68ab3deafeb07f.jpg
  15. Feb 21, 2014 at 7:03 PM
    #155
    Taco Man in HD
    Ohio
    Finished and installed the retrofitted headlights! Fun project, most difficult part was definitely getting the lenses off. :mad:
    I painted the entire housing flat black to match the other parts of the truck. I'm looking forward to see it all come together when I put the front bumper back on soon, which I took off to avoid the Ohio road salt. :eek:
    Thanks to toendanger and Rubio92 for the help and write-up! :thumbsup:
    58B9E357-B745-4A5F-AD2E-9CF3A026DF4C_zps_6994db7d607e5b71dd17458832437e59e644d28d.jpg
  16. Feb 22, 2014 at 6:31 AM
    #156
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    Daaaamn those look good!
  17. Feb 22, 2014 at 8:11 AM
    #157
    Box Rocket
    Adam
    Syracuse, Utah
    Lights look great. Any chance you can post a photo of your truck straight from the front? I'm interested to see how the fenders look without long travel suspension. Do you know what the BS is on your wheels?
  18. Feb 22, 2014 at 1:21 PM
    #158
    Robby655
    Robby655 Well-Known Member
    Robby
    Alaskuhhh
    White TuRD
    Peep the build
    daaammnnn those lights look sick man! I think this may be my next mod? and how have i not seen your truck before? dcab prerunner :) SUBBED!
  19. Feb 24, 2014 at 1:43 AM
    #159
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    What happened to the roof mounted light bar? Haha
  20. Feb 24, 2014 at 5:11 AM
    #160
    02 TRD Tacoma
    02 TRD Tacoma Well-Known Member
    Nathan
    Lenoir NC
    02 Tacoma DC TRD
    Bilstein 5100 front and rear, dakar leaf pack, fuel hostage wheels, 285/70/17 Trail Grapplers M/T, color match shell, rola rack, hi -lift, dual cb antenna's with 520 XL cb, sandblasted bumpers an brush guard to paint black, color match grill, blacked out badges, and much more.
    SUBBED!!!! Those lights look damn good on ur truck Evan!!!! I've been looking at them ones for a while and been thinking bout ordering some? The flat black is awesome how it looks with the projectors.
