Taco Newcomer questions
Discussion in 'New Members' started by PascoTaco69, Dec 12, 2022.
  1. Dec 12, 2022 at 9:23 AM
    PascoTaco69
    PascoTaco69 [OP] Member
    Adrian
    Brooksville, FL
    2023 Blue Crush Metallic OR MT
    Hello my name is Adrian and I am out the the Bay Area in Florida. I plan on being new to the Taco world but I am not new to trucks or 4x4’s. I have had the original power strokes and a Suzuki samurai before.
    I have used this forum for great info and research. I really want a stick shift but need the long bed for work. I would like to get the off road model. One of my first mods would be the OVT tune on the latest programmer everyone is using. Suspensions wise I would like to do 2-3 inches and run skinny 32’s and try to keep cutting to a minimum or none at all. I don’t plan on crazy off roading but I don’t ever want to get stuck hence the off road model whenever I go camping or trailer my atv/utv toys. I would like to be able to go on trail riding but not to the point where I need long travel suspension.
    I am going to test drive this truck here that I found on auto trader.
    http://atcm.co/S2PVDP/2795201C. It’s hard to tell but it looks like it may have UCA done in top of the suspension. What do you all think for price and lift on this? Any feedback would be appreciated.
    Thanks for letting me join!
  2. Dec 12, 2022 at 9:31 AM
    drtyrtn
    drtyrtn Member
    '19 SR5 3.5 AT 4x4 Taco
    Looks like that already has a DB lift on it and 33s..
    YF_Ryan likes this.
  3. Dec 12, 2022 at 9:50 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Yeah, agreeing with @drtyrtn , that truck appears to have a drop bracket lift. Not a big fan of those. They cut part of the frame out on a Taco to install these, so much tougher to go back to stock or a more quality lift.
  4. Dec 12, 2022 at 10:07 AM
    PascoTaco69
    Adrian
    Brooksville, FL
    Yeah I called the dealership and they say it’s a 4 inch rough country lift I believe. They tried saying it was lifted right so I asked him what extended axles they used and uca. He said he will get back to me. From what I have read, don’t go with anything rough country. I think I would go with icon or fox based on the research I have done so far. I want to avoid getting extended axles which is why I don’t want to go higher than 3 inch light and 32’s. I am not trying to do long travel right off the bat but a good mid travel setup. Thanks for the replies. I may test drive it though just tip get the feel for it. I have rode in Taco’s but never driven one, well third gen at least.
  5. Dec 12, 2022 at 10:21 AM
    YF_Ryan
    Kent, WA
    a drop bracket lift simply takes most of the OEM components and moves them downwards. The upper control arms look OEM. The spindle would be replaced to bridge the gap between the upper control arm, and the now LOWER, lower control arm. The front shocks would be moved lower with a large spacer lift.
    Extended axles are not necessary with a drop bracket, only with Long Travel.
    Also, 32s fit with no lift whatsoever.
    If you like the look of the truck with the Drop Bracket, and don't plan to do any serious offroading it would be fine for you. If you do want to upgrade the suspension in the future, it will be difficult since you will need a shop that can weld in a new piece of frame when removing the drop bracket.
  6. Dec 12, 2022 at 10:35 AM
    PascoTaco69
    Adrian
    Brooksville, FL
    I plan on off-roading at some point but not sure if Florida has a lot of offer outside of mud holes which I want no part of in a daily driver. I know a 2.5 inch proper coil and spring lift will perform better than that 4 inch bracket lift. I want to do it the right way the first time. Maybe I will go to skinny 33’s then.
    YF_Ryan likes this.
  7. Dec 12, 2022 at 10:39 AM
    gvfs
    gvfs Well-Known Member
    43° North
    2023 Black TRD Sport AC 6MT 4x4
    I think this is driving some to get TRD Sports, which can be had in 6MT ACLB, and then make some changes to attempt to offroad-ize them, sans locker and electrically-boosted braking.
    Good luck with that truck.
  8. Dec 12, 2022 at 11:06 AM
    PascoTaco69
    Adrian
    Brooksville, FL
    Thanks. I need the crew cab though. I think I am better off going new or stock at this point and get the lift that I want. I appreciate all the replies
    buckhuntin-tacoma and YF_Ryan like this.
  9. Dec 12, 2022 at 12:24 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW! For what it’s worth, I’ve had a 4 inch D/B lift on my truck for 5 years now and have had absolutely no issues. I haven’t had to replace anything, no u-joints, wheel bearings, cv axels not even a cv axle boot. The purpose of a D/B lift is to keep all of your angles at factory specifications. I did replace the shocks with Fox 2.0 and am happy with the way it rides. I don’t do any hardcore wheeling but I do a lot of hunting and drive through a lot of fields and mud. I went with the 4 inch lift mainly for the stance, I like the way it looks and it serves my purposes well.
    Black DOG Lila likes this.
  10. Dec 12, 2022 at 2:31 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    buckhuntin-tacoma likes this.
  11. Dec 26, 2022 at 3:55 AM
    PascoTaco69
    Adrian
    Brooksville, FL
    Well I finally got to drive my first 3rd gen. Granted it was just a base model 2 door with a little can area 2wd. I had to go to Puerto Rico for work and that’s all they had left to rent. But the truck was still nice overall considering it was the base model and 4 cylinder. I know the truck I want will drive completely different but I was impressed enough to know that I am on the right track on getting a Taco. I tell you what, Tacomas were everywhere in Puerto Rico. They definitely dominate the truck market there. I got to see all kinds while there so it was awesome to see that. I am going on vacation now but as soon I get back will be time to start shopping for my Taco!
  12. Dec 26, 2022 at 4:28 AM
    General Chaos
    General Chaos I like pie.
    Joe
    NC
    2022 MGM Tacoma OR TRD 6MT
    As for the used on you linked to…I bought my truck brand new for about that price. Mine is a 5’ bed and MT (so not what you want) but I have 4x4 off road and the XP package. The price of used ones are often within a few hundred dollars of a new one, which is why I got new. Not really a fan of buying new but this market just dictated that for my situation. If you are at 43k on your budget, look at new. As for doing lifts and big tires on a new truck, I’m not a fan. I think it kills resale because most people don’t want your mods. I’ve seen it on this forum. Most people take it back to stock to sell. If I was off roading, I’d buy a 2009 model and do whatever to it.
    Just my opinion…probably not a popular one here.
  13. Dec 26, 2022 at 10:42 AM
    Tacoma’20
    Tacoma’20 Well-Known Member
    Wincent
    Southern California
    2020 Silver Sky Metallic TRD O.R. 2wd
    Welcome to TacomaWorld, from SoCal!
  14. Jan 6, 2023 at 8:46 AM
    PascoTaco69
    Adrian
    Brooksville, FL
    Called the local dealership to find out about getting a new off-road. I am going double access short bed with MT or Auto double access with long bed auto. Must have technology package. Don’t want blue, white or black. Would prefer cement gray, desert sand or lunar but any type of gray or silver will do.
  15. Jan 6, 2023 at 8:58 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW
  16. Jan 6, 2023 at 10:05 AM
    PascoTaco69
    Adrian
    Brooksville, FL
    They have a blue crush metallic coming in 5 days MT. I looked at one and I do like the color so I put a deposit on it. I wish I had time to wait but I am upside down on my current car about 3k and it’s only going to get worse with the driving I do. Sounds like it will be about 52k out the door when it’s all said and done. So 49k if it was just without trade in. Does that sound about right? Looking at used with 20k miles on it I see around $40-43k. This is my first time buying brand new.
  17. Jan 7, 2023 at 3:27 PM
    PascoTaco69
    Adrian
    Brooksville, FL
    I pickup my blue crush metallic off road MT on Tuesday. It has the technology package, led package and got the dealer to throw in the predator running board since they wouldn’t budge on dealership fees. I saw a limited blue crush and just loved the color. It also helped looking at the blue crush metallic thread on here too. I definitely plan on blacking it out. Thanks for all the feedback and welcoming me here! Glad to finally be a part of TW.
  18. Jan 9, 2023 at 8:15 AM
    ahartzler
    ahartzler Member
    2019 Tacoma TSS Offroad Midnight Black
    TRD Pro Grille TRD Pro Shift Knob Entune Premium Passenger Sun Visor with Vanity Mirror and wiring Interior Bright White LED lights Blackout Badges
    Welcome to TW dude!
  19. Jan 10, 2023 at 12:12 PM
    PascoTaco69
    Adrian
    Brooksville, FL
    Thanks everyone. I am in love with this beauty MT beauty. I can’t wait to start modding her up.
