Taco no go
Discussion in '2nd Gen. Tacomas (2005-2015)' started by morphiend, Apr 3, 2010.
  1. Apr 3, 2010 at 7:24 PM
    morphiend
    morphiend [OP] Member
    I was driving and without warning my 2006 Taco 4x4 made a loud popping sound and shut off. I coast the truck to the side of the road. I restarted the truck no problem, however the truck will not go. Parked on a hill, in park, the truck rolls backwards. In 4x4 it doesn't roll backwards but it will only pull forward not actually roll forward. If you put it in reverse while in 4x4 its will go a small ways then put it in drive it goes forward a short distance before it stops moving abruptly. I think my rear axle is buggered. Any comments?
  2. Apr 3, 2010 at 7:29 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    probably your rear diff. how do your drive shafts look?
  3. Apr 3, 2010 at 10:23 PM
    morphiend
    the drive shaft looks fine. i don't really understand why I can reverse it a ways, then it will drive forward a short distance before "looking up." Does this sound like I'll have to replace my whole rear axle?
  4. Apr 4, 2010 at 3:25 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    My buddy had the same symptoms you described with his Dodge Ram; turned out to be his transfer case was shot.
  5. Apr 4, 2010 at 3:27 PM
    Nine Mile Style
    Nine Mile Style Big Cat
    PNW
    05 Tacoma trd offroad and an 85 4x4 pickup
    Flowmaster super 40 k&n cai
    sounds like your rear end is shot
  6. Apr 4, 2010 at 4:06 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Yep rear end or t-case. I would say its your transfer case where did the pop come from? right underneith you or farther back?
  7. Apr 4, 2010 at 4:12 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    sounds more like the x fer case than a rear end
  8. Apr 4, 2010 at 4:23 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Driving in 4x4 or 2Hi?
  9. Apr 4, 2010 at 4:31 PM
    tervanun
    tervanun Well-Known Member
    Dan
    Las Vegas
    "Shirley" - 06 DC 4x4 SR5
    Installed: 6in procomp, 17's, 35" BFG K02's, Stubbs HD-SKO sliders, Brute Force Fab front bumper, XRC Winch. Mods to come: Brute Force rear bumper, Fox Coilovers
    check ebrake lines, mine got snagged when one of the chains I had on came partly lose...
    Probably not your problem but I had the exact same symptoms even after I reset the chains. it would go backwards but not forward. we seemed to fix it with a host clamp since it was ripped from the original clamp to the drum.
    side note: my brake light and abs lights were on until I was able to completely release the line on that one side.
    Edit: I was in 4wd at the time
  10. Apr 4, 2010 at 5:30 PM
    morphiend
    Pretty sure its not the ebrake. I can apply the ebrake and release it. When the truck is in park it rolls unless the ebrake is on.
    I couldn't really say where the bang came from. It happened so suddenly and out of nowhere. I did feel it though.
    When it happened I was in 2wheel. I tried driving it in both 4hi and low with the same problem. I could reverse then go a short distance forward but then it would lock up and stop suddenly.
    It has about 80,000kms on it so I'm hoping it will fall under the 100,000kms warranty. Should find out tomorrow.
  11. Apr 4, 2010 at 5:34 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    good luck on the warranty fix... welcome to TW by the way
  12. Apr 4, 2010 at 9:55 PM
    tervanun
    Dan
    Las Vegas
    oooo if it rolls in park that flags a tranny problem to me :/
    Good luck though! and welcome :D
  13. Apr 4, 2010 at 10:01 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Good luck with the fix. What dealership are you taking it to?
    Your truck doesn't happen to be blue with a canopy on it does it?
    Saw one today parked on the side of the road in Port Moody, going up
    the mountain. Thought that might be yours.
  14. Apr 5, 2010 at 8:43 AM
    morphiend
    Thanks everyone for the welcomes! I called the dealership this morning and they say it falls within the 100,000km 5year drivetrain warranty IF it is a warrantably issue. Here's hoping.
    The tow truck driver said to me when he dropped it off at my house, "this is the first time I've ever towed one of these." lol I'm not sure whether to be impressed by that or feel self loathing.
    Canadianboy: nope that wasn't me. Mine is white and no canopy. I was heading up the hill heading east right after the portmann bridge. Luckily it didn't happen on the port mann.
  15. Apr 5, 2010 at 3:15 PM
    tervanun
    Dan
    Las Vegas
    lol well his comment sure makes me feel good :p
    but for you......unlucky?
  16. Apr 5, 2010 at 4:11 PM
    morphiend
    maybe a dud, maybe bad driving from the previous owner. I've only had the truck for about a month. No symptoms though, that's weird part.
  17. Apr 5, 2010 at 5:24 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Sound transmission related to me...
  18. Apr 5, 2010 at 7:56 PM
    rmb_crew
    Well its good everything should be taken care of under warranty. Keep us posted on what the dealer says.
