Taco noob and an idiot to boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beanereeno, Oct 17, 2023.
  1. Oct 17, 2023 at 8:24 PM
    Beanereeno
    Beanereeno [OP] What a long strange trip it’s been…
    Kevin
    Atascadero, California
    07 TRD Sport, a/c power-utility lights
    3”lift
    I finally got myself a 2nd gen. I found a 4x4 pre runner, with an extra cab and a 6ft bed. It’s an ex fleet vehicle of some sort- I’ve seen the Carfax and it’s been regularly serviced in a few different states, and it has utility lights, aside from being white.
    Anyhow, I got it at 198k and haven’t had any issues except I just changed out the front wheel bearings. Now the back ones need replacing too, figures as much.
    so, to the point, I thought I should do a transmission fluid swap and went in gung Ho- turns out, I’m reading in here I should just leave it be since the shavings and sludge are theoretically what’s keeping it a smooth operator… so new fluid is out. Ok fine, I saved the old fluid, but I drained into an oil pan then transferred to an empty oil jug… my question is, is that little bit of residual oil mixed in with the fluid I drained going to cause an issue If I go ahead and return it to whence it came? Thank you, and please Be nice, I’m sensitive.
  2. Oct 17, 2023 at 8:25 PM
    Bishop84
    Bishop84 Well-Known Member
    I'm a professional and I can tell you that anyone that thinks old fluid holds a trans together heard it from an origin that is long gone.
    Dump the oil, put new oil in, set the level, don't fret about things.
  3. Oct 17, 2023 at 8:32 PM
    Beanereeno
    Kevin
    3”lift
    Forgot to mention it’s at 230k now. So, you say just put new in and stop stressing?
  4. Oct 17, 2023 at 8:34 PM
    Bishop84
    If it had 500k I'd say put in fresh oil and stop stressing.
    Most people that report issues from flushes already had pre-existing issues and need something to blame.
    Ideally you'd do a pan drop on that truck to get the most out of it, but a spill and fill is a good idea, it also ensures the fluid level is correct.
    12TRDTacoma, 2WD, 50Buck and 3 others like this.
  5. Oct 17, 2023 at 9:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m with @Bishop84
    Change it.
    If you have a problem after changing it, you already had a problem.
    Or you did something wrong changing it. (Like not following the refill procedure exactly)
  6. Oct 17, 2023 at 9:12 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    welcome
    Pre Runners are 4x2 out of the factory. People do convert them to 4x4 but it does require a bit of work and usually a transmission swap to mate with the transfer case
    Not trying to bust your balls but just noting contradictory information that may relate to your transmission
    YF_Ryan and Dm93 like this.
  7. Oct 17, 2023 at 9:13 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I just did a full flush on my 4Runner transmission with 242k miles. Shifts way better than before… no issues.
    winkel and Beanereeno[OP] like this.
  8. Oct 17, 2023 at 9:16 PM
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    The last thing I'd do is put the old fluid back. You drained it out, it's done. Especially now that it's contaminated sitting in a used oil jug. You ripped the band-aid off, so just send it.
    Laxtoy, jaydeebee and Beanereeno[OP] like this.
  9. Oct 18, 2023 at 7:36 AM
    Beanereeno
    Kevin
    3”lift
    that’s what I thought until I found this one and did some research- turns out Toyota made a few 4x4 prerunners just because apparently.
  10. Oct 18, 2023 at 8:36 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Change it. You don’t keep old oil in your engine, so why should you do the same in the transmission?
    I have changed it in my 350,000 ride and runs fine.
  11. Oct 18, 2023 at 8:38 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No.
    It's either a 4x4 or a Prerunner.
    I hope you didn't buy a Prerunner for the price of a 4x4.
    ToyoTaco25, steveo27 and YF_Ryan like this.
  12. Oct 18, 2023 at 8:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    If you have a 4wd truck and a prerunner badge on the tailgate, my bet is you have a replacement tailgate.
    Conversions from prerunner to 4x4 are done, but usually by individuals and unlikely by a fleet owner
    Factory 4 x 4 prerunner? You'll have to bring stronger evidence.
  13. Oct 18, 2023 at 8:47 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    O.P. do you even know what you bought,look and see if you have axles going into your front tires,or a 4x4 switch next to your steering wheel on the lower right hand side.
  14. Oct 18, 2023 at 8:49 AM
    BluberryBCtaco
    BC Canada
    Hey OP when you have a moment send up some photos of your cool new ride!
    We are excited to see it, and to squish your Pre-runner 4x4 hybrid monster debate.
    YF_Ryan and EveryDayIsTacoTues like this.
  15. Oct 18, 2023 at 8:54 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    b_r_o likes this.
  16. Oct 18, 2023 at 9:08 AM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    :popcorn:It's only Weds.
    Serious though, congrats on the Taco regardless. I'm curious now to see if it's a 4x4 Base owned by a badge slappy happy fleet (which would be weird), evidence of a tailgate swap as mentioned, or just a standard 2WD Pre.
  17. Oct 18, 2023 at 11:16 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
  18. Oct 18, 2023 at 11:36 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    OP, I think your confusing a transmission flush and a drain and fill. Most will tell you to avoid flushing high milage transmissions for the reason you mentioned. However nothing wrong with doing a drain and fill with fresh fluid.
  19. Oct 18, 2023 at 12:05 PM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Someone mentioned it above... but when I had my high mileage 4runner transmission fully flushed I voiced the same concern to the shop owner (Dr.Trans in San Diego) and he said the same thing... usually issues are already there so people think flushing the fluid will solve whatever existing issue is there, but it doesn't. Again, different transmission (I think?) but I went ahead and did the full flush at 242k miles (unknown previous fluid change history) and all is working well. YMMV
    Beanereeno[OP] likes this.
  20. Oct 18, 2023 at 12:10 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'm here for pics of the 4x4 Pre-runner, cause they exist, but only cause someone made the mod. No 4x4 Pre-runners built by Toyota. Pre-runner was a 2wd package that had the look/size of a 4wd.
    ace96 likes this.
