Taco parking brake.....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Discokiller, Sep 19, 2022.
  1. Sep 19, 2022 at 11:49 AM
    #41
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Oooooo, forgot about that. People unable to disengage during freezing temps...not a good time to wait to thaw out the drums.
  2. Sep 19, 2022 at 12:01 PM
    #42
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    LOL, I haven't had rear drums on any vehicle since the late 1990s, and yet I still run into the same issue with disc brakes.
  3. Sep 19, 2022 at 12:07 PM
    #43
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I can't remember the last time I used mine. The only time I would use it would be if I was parking in an unusually steep place.
  4. Sep 19, 2022 at 12:09 PM
    #44
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    I use mine every couple of months to keep the cable rust free.
  5. Sep 19, 2022 at 12:11 PM
    #45
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I use mine
  6. Sep 19, 2022 at 12:23 PM
    #46
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    i have never in my life heard of a pawl ever wearing out
  7. Sep 19, 2022 at 12:27 PM
    #47
    Horseshoez
    Dale
    Maryland
    They don't necessarily "wear out"; it's more like they snap off and start rattling around in the transmission.
  8. Sep 19, 2022 at 12:37 PM
    #48
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    2021 ATX Tacoma - I almost always park with the parking brake engaged. Other car is MTX and it's a hard habit to break. Plus this feels nicer than having the trans violently pop into park when the pawl gets engaged.
  9. Sep 19, 2022 at 12:50 PM
    #49
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Someone mentioned or started a thread where they had gone through a car wash and engaged their parking brake for the night--next morning, no moving allowed!
    I think it was suggested to get a blow dryer of heat gun and thaw them out!
    Quite dangerous with the fuel tank on the one side...
  10. Sep 19, 2022 at 12:50 PM
    #50
    pwgunny
    pwgunny Well-Known Member
    Patrick
    Charleston, SC
    2021 TRD PRO LR, 2020 T4R SR5, 2004 T4R Sport V6( Sold)
    I only use it at the boat ramp.
  11. Sep 19, 2022 at 12:53 PM
    #51
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Always
  12. Sep 19, 2022 at 12:54 PM
    #52
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    I use mine often...not sure of the mechanics of using it, however I assume it should be used occasionally just for the purpose of keeping it functional. I rarely used it on my Tundra and the one time I did, later in my 16 years of ownership, it didn't work. Not sure it was due to lack of use but that is why I use it more now in the Taco.
  13. Sep 19, 2022 at 1:00 PM
    #53
    saint277
    saint277 Vigilo Confido
    For me it depends on weather or not the parking brake's integrity is known. Using the parking brake from day one every time you stop stops the system from seizing up due to corrosion buildup. If you don't know if the parking brake is good don't use it, you run the risk of it getting stuck on and then you will be in trouble. I live in the rust belt and a parking brake can seize in just a few days if its not used.
  14. Sep 19, 2022 at 1:05 PM
    #54
    Horseshoez
    Dale
    Maryland
    Both of our current cars have 4-Wheel disc brakes, both got washed one very cold day in a bay near our (then) home, and the next day, neither car would move. Yes, both parking brakes were set (both cars are 6MT), but when the cars broke free the "CRACK!" of the breaking of the ice, and primarily from the front of both cars.
  15. Sep 19, 2022 at 1:07 PM
    #55
    Horseshoez
    Dale
    Maryland
    I would argue just the opposite; if one doesn't know the state of the parking brake system, start using it in a controlled environment so one can evaluate how effective it is; then once confidence is built up, use it regularly.
    DingleTower likes this.
  16. Sep 19, 2022 at 1:10 PM
    #56
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I seem to remember 60s - 70s Ford's having the pawl getting worn and wedging in place if regularly parked on hills.
    You needed to get another vehicle to push and relieve the weight to get them out of park.
  17. Sep 19, 2022 at 1:10 PM
    #57
    Clidarv
    Clidarv Well-Known Member
    Clinton
    2020 OR DCLB white
    Bed mat
    Rarely with my manual Jeep and even less with my auto taco.
  18. Sep 19, 2022 at 1:11 PM
    #58
    RIX TUX
    might be the shifter wearing out on those
  19. Sep 19, 2022 at 1:13 PM
    #59
    saint277
    issue is if it gets stuck on your stuck, you can't even get the drum off to service it if its stuck on. I would only use an unknown parking brake if I went trough the whole system an replaced any thing the looked suspect first, and on an automatic its just not worth the time and effort to do that when I could just use park.
  20. Sep 19, 2022 at 1:13 PM
    #60
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Shifter wouldn't move until the weight was off the pawl.
