Taco PRO Owners: Interested in a spring upgrade for front?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryan at Eibach, Dec 17, 2019.
  1. Jan 7, 2023 at 8:10 AM
    #2141
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This spacer is not really needed for the pro suspension (at least not for 2017-2019, 2020+ might of changed when they updated the spring design). The pro suspension has built in taco lean fixes.
    Notice the shock on the right side has the spring perch about 1/4 inch higher than the other one. Thats the driver side shock that compensates for the battery, gas tank, and drivers weight.
    You can put a 1/4 inch spacer on both sides if you want to add even more lift though.
  2. Jan 7, 2023 at 9:21 AM
    #2142
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Anyone know the unspung spring height for the ‘20 and newer? I’ve gathered that they are 620 # rate and 2.5ID.
  3. Jan 7, 2023 at 10:24 AM
    #2143
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    i put a 1/4 in. spacer on both sides with the eibach springs on my 17 Pro,, with 2 in tapered block in rear,, truck is level......
    Sparky66 likes this.
  4. Jan 7, 2023 at 10:46 AM
    #2144
    5nahalf
    Erik
    Minnesota
    Neat? I didnt say you cant.
    doublethebass likes this.
  5. Jan 9, 2023 at 9:04 AM
    #2145
    mark@eibach
    mark@eibach Well-Known Member Vendor
    see above.
    2014 DCSB TRD OR
    Eibach Pro-Truck Coilover 2.5 w/ Resi Dirtking UCAs Magnuson Supercharger HP Tuners MVI2 Pelferybilt Front / Rear Armor DeMello Sliders Fifteen52 Tarmac HD Nitto Ridge Grappler 265/75/16
    None of the TRD Pro springs 17 - 22 are 2.5" ID. They have all been approximately 3.0" ID
    OE Static length is 13.3"
    What are you trying to accomplish?
  6. Jan 9, 2023 at 9:24 AM
    #2146
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Thanks for responding!
    I’ve been looking into possibility of changing out the springs on my Ironman Foam cells and there are only a few springs that can be used. They need to be larger than 2.5” ID, flat top and rounded bottom. The IM springs are about 15.3 free height, so the those new springs would be too short for comfort having on there. The main issue is the smallest rate is 720#. It can make some of the ride stiffer than I’d like. I’m not unhappy with the ride just like seeing what I might be able to do.
    Sorry about my confusion on that, I did mean 3.0.
  7. Jan 9, 2023 at 9:30 AM
    #2147
    mark@eibach
    see above.
    2014 DCSB TRD OR
    No problem, I just wanted to get ahead of the misinformation so people don't accidentally read the incorrect measurements and get the wrong ideas.
    Our spring is a little longer than OE but only about a half inch. Not the 2" you need. Sounds like you have high rate, plus a lot of preload on that setup. Are they threaded body and adjustable?
    EDIT: just took a quick look at the google machine and it looks threaded. I would call them see if they offer a FLAT (non helical rise) spring perch that you can screw on (I'm fairly certain that will be available). Once you have a flat perch you can start looking at our off-the shelf race springs which are flat ground top and bottom. Easy peasy.
    https://eibach.com/us/c-102-motorsport-springs-accessories-off-road-springs-ero.html
    hyrule_trd[QUOTED] likes this.
  8. Jan 9, 2023 at 9:43 AM
    #2148
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    :rofl:
    Thanks again Mark, I appreciate the help. I spent a lot of time on google trying to find something that would work as a flat perch, along with the idea of letting the spring sit on the top 2 of the lock nuts without the rounded perch. That’s when I had the higher # springs on. I decided I don’t have enough information to make an educated decision on a flat perch that could work. I considered trying to find one of the other manufacturers threaded perches but the chances of being the same thread and pitch I felt was too low.
    Thanks again!
  9. Jan 9, 2023 at 9:57 AM
    #2149
    mark@eibach
    see above.
    2014 DCSB TRD OR
    Is the actual perch itself threaded, or is it a slip fit? Looks like there are two locking nuts below it, but KINDA looks like it could be slip fit. Which would be very cheap for a machine shop to whip up.
  10. Jan 9, 2023 at 10:12 AM
    #2150
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    the perch is a slip fit on there then the 2 locking nuts. Great advice on having a shop make a perch, I bet I could find someone on TW that is into that type of thing too.
    Thanks again!
  11. Jan 9, 2023 at 10:18 AM
    #2151
    mark@eibach
    see above.
    2014 DCSB TRD OR
    Boom, there you go! Definitely think you could find someone here with a lathe!
  12. Jan 13, 2023 at 3:25 AM
    #2152
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    Heads up to those who went the refund route. Mark and Tanner from Eibach were super helpful over the holidays and expedited my refund for the springs and returning my truck to stock. Shout out to Eibach for the excellent customer service!
  13. Jan 13, 2023 at 4:52 PM
    #2153
    TacomaYankee21
    TacomaYankee21 Member
    SYV
    22 TRD PRO M/T
    I'm wondering Would this be a better option for my 2022 with the revised spring vs wescott kit?
    TheWeatherman likes this.
  14. Jan 13, 2023 at 5:20 PM
    #2154
    th3clara
    th3clara Well-Known Member
    Trevor
    Portland, OR
    2020 TRD Pro - Army Green
    RIDE Shocks 255/85r16
    I personally think it depends on what you are trying to achieve. Westcott would be better for fitting 285/75r16 due to the top hat spacer, which moves the wheel’s full compression position 1/2” lower.
    Eibach kit is only a spring, and therefore only changes resting ride height by increasing preload. Since the Eibach kit does not have a top spacer, wheel travel is identical to stock (probably why Eibach doesn’t advertise it as a method for clearing 285/75r16, whereas Westcott does)
    I chose the Eibach kit because it has less pieces for the front (1 vs 3), and my goal is to gain back some ride height that I lost due to adding steel skids. I’m not trying to fit 285/75r16, so a simpler kit made more sense.
    Your 2022 model likely already has a taller spring than the 2020-2021 models, which is how it sits .5” front and rear compared to earlier models. This Eibach kit would probably only get you .7” of lift in the front, whereas the Westcott would get you 1.5”. Id say go Westcott if you are also willing to get UCA and the ECGS bushing installed at the same time.
  15. Jan 13, 2023 at 5:54 PM
    #2155
    TacomaYankee21
    SYV
    22 TRD PRO M/T
    That cleared up a lot for me, thank you for your help.
  16. Jan 13, 2023 at 7:04 PM
    #2156
    5nahalf
    Erik
    Minnesota
    2022 might be a little difficult in my opinion due to the increase in stock height. The eibach kit will only give you a tiny increase, but the westcott kit might over extend you causing driveline issues that might result in you needing a diff drop.
    If it was my truck, I would go with the westcott kit, but not use the top spacers. Or get the eibach kit and get a 1/4 inch top spacer.
    th3clara likes this.
  17. Jan 16, 2023 at 8:17 AM
    #2157
    mark@eibach
    see above.
    2014 DCSB TRD OR
    We have not test fit a 22' for heights yet, so depending on where in SoCal you're located we may be able to help with your decision! PM if you're interested in coming in for test fit.
    hyrule_trd likes this.
  18. Jan 19, 2023 at 6:07 PM
    #2158
    th3clara
    Trevor
    Portland, OR
    2020+ Eibach springs going on tomorrow. I’ll post some before and after measurements once installed.
  19. Jan 19, 2023 at 6:11 PM
    #2159
    5nahalf
    Erik
    Minnesota
    Look at you all squared away with the correct stuff for the job.
  20. Jan 19, 2023 at 6:14 PM
    #2160
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Was going to say, just slapped some basic 650lb 14" springs on my 17-19 pros. Fit fine, but I do coil bind them so going to chop them to around 13.5"/machine the chopped side flat again.
