Taco PRO Owners: Interested in a spring upgrade for front?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryan at Eibach, Dec 17, 2019.
  1. Mar 26, 2021 at 8:38 PM
    #921
    Acrock81
    Acrock81 Member
    Western NC
    2017 TRD Pro
    The Pro should handle some pretty good rock crawling with either these Eibach springs or a Westcott lift and bigger tires. Can’t wait to find out, Eibach. I’ve done alot of the moderate trails at Windrock & Uwarrhie and the stock fox’s with 31” duratrac tires have handled great! The clearance sucks, I’ve added full armour because of it, and I just try to avoid the tougher sections until I can fix my lift.
    mark@eibach likes this.
  2. Mar 26, 2021 at 8:44 PM
    #922
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    Has anyone put 295/75/16 tires on the Pro wheels? Just wondering if they'll fit. Also, does anyone know the offset of the Pro wheels?
  3. Mar 27, 2021 at 12:56 AM
    #923
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    Tacoma Pro – 16x7 +13MM Offset
    4Runner Pro – 17x7 +4MM Offset
  4. Mar 27, 2021 at 4:23 AM
    #924
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Much appreciated. I assume you mean negative offset i.e. the tires stick out 13 mm?
  5. Mar 27, 2021 at 5:46 AM
    #925
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    No, + is positive. A negative sign (-) would indicate negative offset.
    Rainoffire likes this.
  6. Mar 27, 2021 at 5:55 AM
    #926
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Negative offset usually means a tire will stick out the fender, and positive offset will give a flush look. Generalizing, but negative if you want to clear the upper control arm for bigger tires, risk wheel well rub. Positive to clear wheel well rub, but risk hitting the UCA.
    mark@eibach and 79CHKCHK like this.
  7. Mar 27, 2021 at 8:25 AM
    #927
    savethewheels
    Nashville, TN
    truck
    Definitely a generalization. I only mention this because wheel fitment is not usually this simple. I've seen negative offset wheels that won't even clear the calipers, and positive offset wheels that poke past the fender. Suffice it to say that there are more variables to consider than offset alone.
    This is getting off topic though. :thumbsup: I'd recommend some reading in the wheels and tires forum, or here: https://m.tirerack.com/tires/tiretech/techpage.jsp?techid=101
  8. Mar 27, 2021 at 8:58 AM
    #928
    79CHKCHK
    SoCal no mo
    @Mojo Jojo the numbers I posted are correct. The Pro wheels stick out about .5" further because they have less positive offset then the rest of the OEM wheels.
    Tacoma OR - 16X7 +25mm Offset
    Tacoma Pro - 16x7 +13MM Offset
    4Runner Pro - 17x7 +4MM Offset
    I like this website to visualize the changes as I shop for wheels and tires: If a set of wheels had negative offset, they would stick out further then the Pro wheels.
  9. Mar 27, 2021 at 9:06 AM
    #929
    Acrock81
    Acrock81 Member
    Western NC
    2017 TRD Pro
    I was wondering the fitment of 295/75/16s too Mojo. Wanting something a little taller than 285s.
    https://www.tacomaworld.com/threads/295-75r16-295-70r17-photo-thread.589799/
    Looked through this thread and no clear answer, but I suspect tire clearance at the UCA may be a bit close for a Pro unless running wheel spacers. I ended up getting some barely used 34/10.50/16 bias ply Swampers until I decide on a tire with better road manners.
    Mojo Jojo and 79CHKCHK like this.
  10. Mar 27, 2021 at 11:17 AM
    #930
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Thanks for the clarification, I didnt realize they had a positive offset. Thinking about going extended travel in the rear but I'm learning it requires a 2" offset to clear the relocated shock mount. I'm assuming that's 2" of offset from an OR wheel, which in absolute terms would be -25mm of offset.
    :confused: I have so much to learn....
  11. Mar 27, 2021 at 1:04 PM
    #931
    savethewheels
    Nashville, TN
    truck
    @Mojo Jojo There are specific sub-forums where there's probably more info available.
    My assumption would be that it's 2" (approx. 50mm) from 0 offset though.
  12. Mar 27, 2021 at 1:26 PM
    #932
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Personally, I probably wouldn't even put 285's on a 7" rim, much less a 295.
    eurowner and savethewheels like this.
  13. Apr 1, 2021 at 6:36 AM
    #933
    PitCh0w
    PitCh0w Well-Known Member
    Derek
    Boston, MA
    2020 TRD Pro - Army Green
    71tattooguy and RobP62 like this.
  14. Apr 1, 2021 at 7:21 AM
    #934
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    With the Tacoma, anything is possible.
    Mojo Jojo likes this.
  15. Apr 1, 2021 at 7:23 AM
    #935
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    WTF?!
  16. Apr 1, 2021 at 11:28 AM
    #936
    mark@eibach
    mark@eibach Well-Known Member Vendor
    see above.
    2014 DCSB TRD OR
    Eibach Pro-Truck Coilover 2.5 w/ Resi Dirtking UCAs Magnuson Supercharger HP Tuners MVI2 Pelferybilt Front / Rear Armor DeMello Sliders Fifteen52 Tarmac HD Nitto Ridge Grappler 265/75/16
    A quick lesson on how supply chains work will clear this up. The team at Toyota reaches out to Fox and says "hey, we would love to partner on this project." Fox, being a damper manufacturer, says "we're in". Fox then says to Eibach (their trusted spring partner for many years now) "Hey we've got this great project with Toyota, you in?" we say "yup" and then we all work on the project together. We're considered a Tier 2 partner in this scenario, therefore the part numbers match Fox's nomenclature as it is technically a part on a Fox assembly.
    For this TRD PRO - Lift Spring project we retained factory rates, but the discrepancy in question is in reference to the 20' spring. Our 17-19 spring does in fact also share the 650lbin. rate that the OE 17-19 spring has.
  17. Apr 1, 2021 at 11:35 AM
    #937
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Interesting, this may be why it seems impossible to find an OEM Toyota part number for just the spring. They likely have a P/N for the assembled coilover, but I didn't even see a part number for that (but I didn't look too hard, was mainly looking for a spring part number).
    So, based on this info, it seems the main difference in this spring and the stock one is just the length.
  18. Apr 2, 2021 at 7:27 AM
    #938
    TurboFire10
    TurboFire10 Well-Known Member
    Erik
    2018 TRD Pro
    ARE Revo, RCI rock sliders
    I’ve been running the Revtek preload spacer lift for a couple years now and haven’t had any issues either on nor off road. Other than mud getting inside the spacer and causing a horrible squeaking noise at lower speeds..
    I’d really like to purchase these springs before next winter Eibach. So I can eliminate the issue I’m having, as well as soften the ride on the trails back to the original feeling. Thank you.
    TacomaGuy7878 likes this.
  19. Apr 4, 2021 at 7:56 PM
    #939
    79CHKCHK
    SoCal no mo
    Thanks for the clarification Mark. :thumbsup: Makes sense and glad to know the details of these springs.
    Spent the last 4 days rolling through Anza Borrego Desert State Park and Ocotillo Wells. New suspension worked great. I really like the new ride with these springs, both on road and off road. From narrow mountain passes to high speed desert washes, worked a treat. Still need to upgrade the tires, I'm still running the stock GY Wranglers. Could have used an extra inch or so, got high centered on the diff on a rock I should not have...Poor driving on my part.
  20. Apr 5, 2021 at 5:19 PM
    #940
    TacomaGuy7878
    TacomaGuy7878 Mmmm....Tacos
    CO Mountains
    2020 AG Pro
    So these won’t be out until mid summer or early fall:pout: A man can only wait so longo_O
