Taco PRO Owners: Interested in a spring upgrade for front?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryan at Eibach, Dec 17, 2019.
  1. May 19, 2021 at 9:30 AM
    #1021
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I am still fine with that date, I would rather do this right with springs that went through a full engineering process and not just slapped together spacers or all in one options. I still have tread left on my OE tires, so no point in lifting yet either.
  2. May 19, 2021 at 9:39 AM
    #1022
    Grindstone
    Grindstone Requires Adult Supervision
    Damn, was hoping to have them by October.
    doublethebass likes this.
  3. May 19, 2021 at 9:50 AM
    #1023
    JTacoNJ
    JTacoNJ Runa Lock Pro
    2021 LR TRD Pro
    Xpel PPF and ceramic tint; DD SS3 Pro fogs; Hitch pod reverse light; Meso Customs dual color dome light; Gas hole; Lomax tonneau cover.
    Can someone help explain what the differences between the Eibach spring upgrade to the Westcott lift? I’m trying understand the pro’s and cons of these two options for us TRD Pro owners.
  4. May 19, 2021 at 9:54 AM
    #1024
    5nahalf
    Erik
    Minnesota
    The westcott kit provides its lift in 2 ways. It replaces the bottom spring perch with one that sits a little higher (this preloads the spring a bit more) then it uses a strut top spacer to get the rest of the lift (this pushes the whole strut down providing lift)
    Generally spacer lifts are frowned upon due them making the strut become the bump stop. If you land hard, you can fold the struts over, or damage the piston inside the strut.
  5. May 19, 2021 at 10:52 AM
    #1025
    Grindstone
    Honest question; does that make this statement a lie?
    "This is not a spacer lift. This kit does not change the geometry of the factory suspension. This kit will not limit your factory travel or extend the travel pass factory."
    https://westcottdesigns.net/product/fox-trd-pro-lift-kit/
    RobP62 likes this.
  6. May 19, 2021 at 11:00 AM
    #1026
    5nahalf
    Erik
    Minnesota
    Its a partial lie yes. Since it uses both, its not considered a full spacer lift, but rather a partial spacer lift so they can say its not a spacer lift.
  7. May 19, 2021 at 11:20 AM
    #1027
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    So do we know how this Eibach upgrade works exactly? Does it just cram a bigger spring in there to "increase" preload, or is it just more stiffly sprung (higher spring weight, same length) to support heavier front ends?
    I'm looking to regain the clearance I would lose with a hidden winch and the skids/sliders I already have on the truck, not increase the lift over stock height or compromise the bypass zones of the Fox shocks.
  8. May 19, 2021 at 11:47 AM
    #1028
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    Eibach told us it's a longer spring, same spring rate.
    Ideally I want the same thing as you (same length spring, higher spring rate), but this is product that's closest to what we're looking for.
  9. May 19, 2021 at 12:25 PM
    #1029
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    You sound as frugal as me! I'm still running OEM GY Wranglers even with a set of the Eibach TRD Pro test springs installed. I did order a set of 17x8 Evo Course DakarZeros in Matte Black from Main Line Overland. They won't be until August, so my stock tires should just about be wore out by then.
    5nahalf[QUOTED] likes this.
  10. May 19, 2021 at 12:35 PM
    #1030
    Grindstone
    So would the Toytec lift provide a higher spring rate? Assuming also longer?
  11. May 19, 2021 at 12:40 PM
    #1031
    79CHKCHK
    SoCal no mo
    They are rated at 700#s, stock TRD Pro are 650#s. Not sure on length it doesn't say on Toytecs website.
    RobP62 and Grindstone[QUOTED] like this.
  12. May 19, 2021 at 12:42 PM
    #1032
    Grindstone
    I thought as much. I would guess they're longer if they don't use a spacer, to provide the claimed lift.
    I wish the Eibachs were 700#s.
  13. May 19, 2021 at 6:08 PM
    #1033
    ayobreezie
    ayobreezie Well-Known Member
    Cav Blue TRD Pro
    "Full engineering process.." sounds like they just made a longer spring. Which is basically the same thing as the westcott/toytec kit, except it's in the form of just a spring.. so they will preload a longer spring.. unless that spring has less coils, I don't get how it's going to be engineered any better than either kit.
  14. May 19, 2021 at 7:06 PM
    #1034
    5nahalf
    Erik
    Minnesota
    Well, westcott uses a top spacer in addition to spring perches. So already better than the westcott kit.
    But, the comment was more related to the toytec where they just pushed out a spring with a universal spring perch on the bottom, nothing listed for the top to make up for the different spring designs between 17-19 and 20-21. Them just putting out a single design shows me that they either didnt do the research needed, didnt bring in trucks from each version of the suspension, or consult the user base to see that 1 spring version is not going to be universal for 2 different spring mounting types. Eibach has been here with us, getting our feedback so they know that there are multiple versions of the pro suspension that have different needs. We have several members on here currently running on prototype springs to give them feedback, we have a full view of the design and implementation of the spring. Toytec just appeared with a spring one day.
    JTacoNJ likes this.
  15. May 20, 2021 at 4:48 AM
    #1035
    huckfin
    huckfin Well-Known Member
    sounds exhausting...
  16. May 20, 2021 at 6:31 AM
    #1036
    TurboFire10
    TurboFire10 Well-Known Member
    Erik
    2018 TRD Pro
    ARE Revo, RCI rock sliders
    We could just buy the Toytec springs and cut them a bit lol. Half joking, half seriously considering it..
  17. May 27, 2021 at 9:44 AM
    #1037
    Jo_Swayzee
    Jo_Swayzee Active Member
    2020 Tacoma TRD Pro MBM 6MT
    Just talked to Eibach. Was for sure a glitch in the matrix. I was told I should never have been able to order or pay for the purchase, nor should it have shown as being available. I was told by the person I spoke with that we are looking at potentially August according to the engineering guy he spoke with while we were on the phone. Back to debating the wescott lift again or just gutting the whole thing for a new suspension.
    RobP62 and Grindstone like this.
  18. May 27, 2021 at 9:50 AM
    #1038
    Grindstone
    August is better than November
    Da_TAKOma and RobP62 like this.
  19. May 27, 2021 at 9:53 AM
    #1039
    5nahalf
    Erik
    Minnesota
    Ask your self, do you really need 1.5 more inches right now? or can you wait a little longer? Do you have new wheels and tires already picked out and ready to buy? Is the stock suspension still doing what you need it to do?
    HighSpeedDirt, Grindstone and perkj like this.
  20. May 27, 2021 at 11:11 AM
    #1040
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    I got the same answer when I called them last week. August it is.
    Grindstone likes this.
