Taco PRO Owners: Interested in a spring upgrade for front?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryan at Eibach, Dec 17, 2019.
  1. Mar 30, 2022 at 7:46 AM
    #1681
    mark@eibach
    mark@eibach Well-Known Member Vendor
    see above.
    2014 DCSB TRD OR
    Eibach Pro-Truck Coilover 2.5 w/ Resi Dirtking UCAs Magnuson Supercharger HP Tuners MVI2 Pelferybilt Front / Rear Armor DeMello Sliders Fifteen52 Tarmac HD Nitto Ridge Grappler 265/75/16
    There are many things that can cause a squeak, but it sounds like you're on the right path to diagnosing the issue. Squeaks can come from various sources, but I've found the best way to diagnose a squeak is to start with what you can see.
    * If you haven't had a friend with you to replicate and pin-point the squeak even further, I would start here. If you don't have some one to help, move on.
    * Visually inspect the top-hat area for witness marks (places where you can see irregular wear, usually metal to metal contact)
    * Look around the isolator pad, and confirm part of the coil isn't making direct contact with the perch or mount. If there is no visible witness marks, you can move on to hardware.
    * Check the torque on all the nuts related to the install. Did you get new UCA's? (the pics look OE which is one less thing to squeak) UCA fasteners (bushings and ball joint), Upper mount fasteners (check the three mount bolts AND the shaft nut) LCA Fasteners, etc.
  2. Mar 30, 2022 at 7:53 AM
    #1682
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    My money is on the isolator pad. I had a hell of a time keeping that thing in the hat and aligned right while installing my springs with the death trap spring compressor I used.
    mark@eibach[QUOTED] likes this.
  3. Mar 30, 2022 at 8:09 AM
    #1683
    mark@eibach
    see above.
    2014 DCSB TRD OR
    same, same. All it takes is the tiniest bit of spring rubbing on the mount.
  4. Apr 1, 2022 at 10:14 AM
    #1684
    VegasVic
    VegasVic Well-Known Member
    SinCity
    2017 Cement TRD Pro
    BAMF Recessed Grille 17" Ray10's 305/70/17 Nitto Ridge Grapplers Lots O' MESO
    So went to order springs today and they are out of stock? :annoyed:
  5. Apr 1, 2022 at 10:16 AM
    #1685
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    Just place your order by calling. They won't charge until they ship.
    mark@eibach likes this.
  6. Apr 1, 2022 at 10:19 AM
    #1686
    mark@eibach
    see above.
    2014 DCSB TRD OR
    This is correct! You can place a back-order via phone and pricing is honored.
    We do still have good inventory of the 20-21 springs, which doesn't help this scenario, but good for other subscribers to know.
    RTweet[QUOTED] likes this.
  7. Apr 1, 2022 at 10:20 AM
    #1687
    RTweet
    Oregon
    Well worth the wait.
  8. Apr 1, 2022 at 10:22 AM
    #1688
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Damn sold out already?? I'm glad I went ahead and got some when they finally came out
  9. Apr 2, 2022 at 4:01 AM
    #1689
    3TMaverick
    3TMaverick Member
    Dan
    Dallas, TX
    2020 White TRD Pro
    Did you keep the overload in with your AAL?
  10. Apr 2, 2022 at 3:00 PM
    #1690
    evo3gsx
    evo3gsx Member
    No, I removed the overload. The Headstrong AAL is designed to be used without the factory overload -- if you want additional lift, people have been adding a 1/2 spacer at the bottom of the leaf pack.
  11. Apr 6, 2022 at 6:41 AM
    #1691
    frankybones
    frankybones Well-Known Member
    Frank
    Summerville SC
    2017 TRD PRO - CEMENT
    Considerding this on my 2017 Tacoma Pro with approx 60k miles on it. Not sure if I should swap out the entire suspension or do springs and blocks or AAL. Currenty have have a Leer Cap and trailer hitch mounted on the front if that matters. Anyone install with Eibach block vs. AAL? Also in my last truck I had to install shims are we doing this on the pro? Thanks in advance.
  12. Apr 6, 2022 at 7:32 AM
    #1692
    RTweet
    Oregon
    I used the block. Eibach will tell you to go ALL if you’re carrying anything with weight back there regularly.
    frankybones[QUOTED] likes this.
  13. Apr 6, 2022 at 4:46 PM
    #1693
    seank13
    seank13 Member
    Sean
    Olympia, WA
    2020 Magnetic Grey Tacoma TRD PRO
    Stock-ish
    OK so I've gone from wanting a lift, to needing a lift. I'm getting a GFC and will be adding additional gear to go along with existing sliders and armor, and my butt is sagging bad already with just some gear and a Diamondback SE cover. So I'm going to be getting some Deaver springs which will be adding rear lift, and rake without a front lift. I do NOT want to change the TRD PRO Fox shocks/struts out, so here we are.
    Since I'm not going to go back and read 70+ pages of posts (decided I was "in" on page 13), does anyone know what the lb rating is on these springs? I checked the Eibach site and couldn't find any info. My front end is currently stock, but I'll be adding a hidden winch soon and possibly a battery later. So immediately adding around 80? 90? lbs, and possibly 50 more. Will these handle that OK?
    Edit: I have a 2020 MY TRD PRO
  14. Apr 6, 2022 at 4:53 PM
    #1694
    RTweet
    Oregon
    How dare you come in here touting all that laziness with demands! jkjk
    They're rated 650 pounds. In deciding whether I want to add a steel or aluminum bumper, I put 100 pound dumbells above my wheels (50 lbs each wheel) and saw maybe a 1/16" drop. Not sure if that would create a worse nose dive or anything like that, but it's the best I can do for you right now. I'm certain others will have more objective input @skeletron?
    5nahalf likes this.
  15. Apr 6, 2022 at 6:14 PM
    #1695
    seank13
    seank13 Member
    Sean
    Olympia, WA
    Stock-ish
    Thank you! Both for the rating, and the results of your dumbbell test! Exactly what I needed.
    Also, yeah, sorry for coming off douchey. I could have and should have phrased my request differently. Been a looong day.
  16. Apr 6, 2022 at 7:25 PM
    #1696
    RTweet
    Oregon
    Not douchey at all. Unfortunately, the TW bullies have created a culture that engenders anxiety when it comes to help seeking.
    5nahalf likes this.
  17. Apr 6, 2022 at 9:07 PM
    #1697
    5nahalf
    Erik
    Minnesota
    I had to google engenders, never heard it before
  18. Apr 7, 2022 at 4:55 AM
    #1698
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Anyone here use the LCA compression method to install these springs? Any issues?
  19. Apr 7, 2022 at 6:01 AM
    #1699
    frankybones
    Frank
    Summerville SC
    oredered mine yesterday and the HS AAL. Anyone running 285's on stock 17 TRD PRO wheels?
  20. Apr 7, 2022 at 7:53 AM
    #1700
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    For a 21 Tacoma Pro, any reason not to run the new springs AND a westcott lift (front) + a 1.5 AAL in the rear? Maybe even the adjustable icon pack in the rear?
