taco seat height
Discussion in 'Product Reviews' started by hotrod45, Jul 23, 2011.
  1. Jul 23, 2011 at 5:29 PM
    hotrod45
    hotrod45 [OP] Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    has anyone raised the height of their seat? i am 5'6" and it seems like the seat is a bit low for me. an additional 1" or so would help a lot. any ideas?
  2. Jul 24, 2011 at 9:48 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245HP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Haven't done it because I'm 6'3" and it works fine for me. You could probably unbolt seat rails and put some square stock aluminum under them and rebolt with longer bolts.
  3. Jul 24, 2011 at 9:57 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Beaverton, OR
    SWB 05 Double Cab 4x4 TRD Off Road
    5'6"?? Wtf? You must be asian!!!! Short ass!!! J/k I'm asian and 5'6"..I don't have complaints on the seat height but then again you have just the basic SR5 model seats, no? Or TRD seats? I got the TRD and they seem fine for me.
    The block under the seat rail is a good idea.
  4. Jul 24, 2011 at 9:59 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    5'5"
    I was thinking phone book for me. But for now I just stretch my neck and imitate a giraffe.
  5. Jul 24, 2011 at 10:08 AM
    4Wheelin4Banger
    Randy
    I ment to say under the whole length of the seat rail not just blocks under bolts. You can get it at Home Depot or Lowes
  6. Jul 24, 2011 at 2:29 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Get some 1" square tubing from Home Depot..you can cut it yourself with alot of hacksaw use, a 4 1/2" angle grinder, or if you have a chop saw..buy a metal blade for it.
    Just do it across each rail..and for extra strength..if you have a welder, tack a square base together for rigidity.
    No welder?..drill holes and use good quality hardware plus epoxy the corners for extra strength:D
  7. Jul 24, 2011 at 2:38 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    what model do you have? i’m 5’6 and can see out of the taco better than dads 2000 tundra. i can’t even see the hood at all on the tundra. i can on my taco tho.
    edit: i do have the TRD OR.
  8. Jul 24, 2011 at 7:11 PM
    hotrod45
    paul
    sarasota fl
    16 sr 5 access cab
    i'll get some blocks and longer bolts.
  9. Jul 26, 2011 at 10:47 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I don't think modifying the seat to be higher is a good idea safety wise. I'm 6'0'' and I don't like the sporty feel of the seat. What I did to help though, put the seat closer to the wheel, raised the steering wheel far up and in (telescopic) as possible. Makes it "feel" higher.
  10. Oct 16, 2011 at 4:33 PM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Any updates on this?
  11. Oct 16, 2011 at 4:51 PM
    4Wheelin4Banger
    Randy
  12. Oct 16, 2011 at 4:51 PM
    waggoner.42
    waggoner.42 Well-Known Member
    Josh
    C-bus OH
    05 TRD Sport DC 4x4- SOLD
    3" Lift
    I raised the seat in my truck using longer bolts and "post standoffs" from Home Depot. They are 4x4x1" plastic pieces used to put 4x4 post on and they already have a hole in the center. I used two under each side of the rear rails for about 2" of lift and it worked great for my wife.
  13. Oct 16, 2011 at 4:53 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    the older customers sit on pads from their dining room chairs. but phone books work too.
  14. Oct 16, 2011 at 4:55 PM
    waggoner.42
    Josh
    C-bus OH
    3" Lift
  15. Oct 16, 2011 at 4:57 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    I'm 6'2" and can see pretty good. But I will agree that it is a low seating position. It's about like driving the F-350 at work, as far as seeing over the hood. I'm used to it now though. The thing that annoys me is the windows. I like to ride with the windows down when the weather is nice like this. But the window is up so high that it's an awkward and uncomfortable position to prop your arm on the window.
  16. Oct 16, 2011 at 5:12 PM
    2chains
    Calgary, Alberta
  17. Oct 16, 2011 at 5:33 PM
    waggoner.42
    Josh
    C-bus OH
    3" Lift
    Nope. I'm 5'9" and I prefer to drive it with the spacers in also as it gives a better vantage point. My 6'2" friend however could drive it, but said it felt awkward at his height.
