Taco Tailgate Theft Deterance
Discussion in 'Technical Chat' started by Rickochet, Oct 18, 2008.
  1. Oct 3, 2011 at 3:07 PM
    #41
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
  2. Oct 3, 2011 at 3:17 PM
    #42
    creeper
    creeper Well-Known Member
    I don't know how you can be serious, it literally takes <10 seconds...
  3. Oct 3, 2011 at 3:22 PM
    #43
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    You can always do this in addition to the other.
    JD Hog likes this.
  4. Oct 3, 2011 at 3:27 PM
    #44
    aznutx
    DFW Texas
    2011 White TRD
    k i recommend NOT buying this, as i responded to this thread i went back out and "tested" the lock, i find that it's simply too loose, and if i slid it to the left too much, i coulda removed the tailgate, FAIL product at least get the sizing better...
  5. Oct 3, 2011 at 3:30 PM
    #45
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    Well, if you can't get it off then thieves can't either. Problem solved.
  6. Oct 3, 2011 at 3:34 PM
    #46
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You can also get the gatekeepr thing and put it over the hose clamp while using the washer on the cables & the popnlock whenever you can get it. Someone will have to jonesin bigtime to jack with it......
  7. Oct 3, 2011 at 7:11 PM
    #47
    aznutx
    DFW Texas
    2011 White TRD
    back to the the thing , i basically added rubber, and electrical taped the heck out of it, and now it's golden, and i did the washer mod.
  8. Oct 4, 2011 at 3:33 AM
    #48
    Rickochet
    Rickochet [OP] Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    Nice looking lock, but McGard doesn't list a model to fit the Taco. :(
    tacoguy88 likes this.
  9. Oct 4, 2011 at 3:47 AM
    #49
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Now all u need is the popnlock .........:D
  10. Oct 4, 2011 at 12:54 PM
    #50
    aznutx
    DFW Texas
    2011 White TRD
    Ya pop n lock in the mail today gonna install later heard some troubles with the cam though we'll see
  11. Oct 4, 2011 at 2:32 PM
    #51
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    I've had mine for over a year. Works great IMO No rust yet (I thought it was made of stainless...) but I wrapped my loop in electrical tape to make sure it didn't leave any scratches.
  12. Oct 6, 2011 at 10:22 AM
    #52
    aznutx
    DFW Texas
    2011 White TRD
    installed the pop n lock today, took longer then expected with the camera removal and install taking the most time because i didnt want to damage it, otherwise im satisfied, like many of the others with it,
    1. it's fairly hard to open 2. toyota's oem seems constructed better 3. fitment on the lower part is a tiny gap, also the gasket doesnt line up 100%, but otherwise.. im satisfied that my tailgate is locked up.
  13. Oct 6, 2011 at 11:04 AM
    #53
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine seemed to fit and function perfectly and has had no issues for coupla years now. Even moved it from the 05 to the 08 when that swap happened a few months back. It is the plain one tho, no camera.
  14. Oct 7, 2011 at 8:11 PM
    #54
    aznutx
    DFW Texas
    2011 White TRD
    mine was just a little too big, if you moved it all the way to the left, the tailgate would still slide out, but after all that rubber/electrical tape it's good to go, but for a 19$ product i just wish it was plug and go
  15. Nov 15, 2011 at 10:05 PM
    #55
    Markcape
    Markcape Old as Dirt
    Mark
    Cape Cod,Ma.
    11 Tacoma A/C Debadged
    Ionic S/S 4in. Oval Running boards Sound Shocker/Stereo radio Aux. input mod. "new" Blower motor Installed/TSB WeatherTech mats Pro Cargo net in bed Console net Tailgate anti-theft mod. ImMrYo Mirror Lift bracket u RainX Wiper Blades
    :p:cool::cool:Thank You for the tip. I got my #20 EZ Clamp at local Autozone. Easy to install. Remove handle with channel lock plyers, pull straight back. Shape of screw was more square than triangular, but still Great anti-theft tip!!
    2011 Taco
    2 per pack for $2.99
  16. Jan 3, 2012 at 2:05 PM
    #56
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    Just wrapped the tailgate end in electrical tape, cut the notch out so it would fit back over the extension. Then used the clamp. Cut the clamp down. Then took a little more electrical tape and put over the clamp screw to prevent scratching (doesn't touch anyway) and a little weather proofing.
    Thanks for the good ideas and cheap.
  17. Mar 17, 2012 at 7:26 AM
    #57
    Honey Badger1
    Honey Badger1 Well-Known Member
    Trip
    New Hampshire
    2011 Tacoma TRD Sport
    Fuzzy Dice, Fighter pilot mod, power ports always on, GPS wired to come on as key is turned, LED Map/dome lights, all weather mats, bed liner, tool box on rail system, Tinted tail lights, repainted badges, Home made grill, Light mounting bracket with two 6 inch. PIAA Drive lights, Stealth mod DTRL on/ off, leather arm rests, door and center.
    I just hose clamped mine, I take my tail gate off every once and awhile, liked the idea of annoying / slowing the baddies down. Some times if I really afraid some one will steal my tail gate I leave my 80lb german shepherd in the bed, which I feel is the best protection! :)
  18. Jun 11, 2012 at 9:16 AM
    #58
    nilla
    nilla Member
    matt
    virginia
    06 Sport DBL Cab 4X4
    leather seats, rocker pannels painted
    the hose clamps i had were too small (looks like you need a 2-inch clamp) so i just did put some washers and spacers on the cable bolts. what thief carries around a T-40 anyhow?
    hinmo24t likes this.
  19. Jun 29, 2012 at 2:43 PM
    #59
    RadSurfTaco
    RadSurfTaco Well-Known Member
    In Ocean or My Taco...trolling up & down Hwy 1
    09 PreRunner MGM DC SB
  20. Jun 29, 2012 at 3:07 PM
    #60
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    Viper 5709 with motion sensor inside tailgate. Plus house clamp, ain't going anywhere I hope
