taco tick noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by jacobbryant421, Sep 25, 2016.
  1. Sep 25, 2016 at 4:23 PM
    jacobbryant421
    jacobbryant421 [OP] Member
    Jacob
    1998 grey tacoma TRD
    Hey all, new to the forum. Just wanted to ask if this sounds like normal taco tick or if i have a valve or injector noise. My truck is a 98 5 speed 3.4l v6 with 268,000. It's most noticeable at warm idle, and either stops or engine drowns it out above 1500 rpms.
  2. Sep 25, 2016 at 4:26 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sounds like the normal tick to me
  3. Sep 25, 2016 at 4:31 PM
    jacobbryant421
    Jacob
    Really? I thought it was a little excessive. Sounds a bit like a deisel. What causes it to tick like that? Btw thanks for the reply
  4. Sep 25, 2016 at 4:43 PM
    Speedytech7
    Pretty sure it is injectors, even my four cyl just ticks away at idle. Can't hear it at any other time
  5. Sep 25, 2016 at 5:58 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    They all do that man
  6. Sep 25, 2016 at 6:15 PM
    jacobbryant421
    Jacob
    Thanks for the reply. Its nice to know I'm not the only one:D
  7. Sep 26, 2016 at 10:11 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Maybe the valves are a bit loose???
  8. Sep 26, 2016 at 10:16 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Could be you need an oil change...the lifters seem to quiet down when you get your oil changed.
  9. Sep 26, 2016 at 10:39 AM
    aaryns09
    aaryns09 New Member
    aaryn
    95 tacoma 2.7l 4x4
    my 95 has done that for a while, ran some sea foam through the system and it helped but it's back again
  10. Sep 26, 2016 at 11:37 AM
    yodataco
    yodataco Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    Mine does it too. Seems to go away for a while after an oil change.
  11. Sep 26, 2016 at 12:46 PM
    jacobbryant421
    Jacob
    Crank case or gas tank
  12. Sep 26, 2016 at 12:47 PM
    jacobbryant421
    Jacob
    I actually just changed it :notsure:
  13. Sep 26, 2016 at 1:04 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah, the posts suggesting the oil change seem correct. I changed my oil yesterday and noticed this morning when I started it, it sure was quiet. Was my first change, so wasn't sure if it was the weight of the oil or quality of it or what. I'll know more by next change, in spring hopefully.
  14. Sep 26, 2016 at 1:33 PM
    jacobbryant421
    Jacob
    What kind of oil (weight and synthetic/dino)?
  15. Sep 26, 2016 at 2:18 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Your injectors do make a very faint ticking noise, but what you're likely hearing is the EVAP VSV. It's located on your EVAP box on the driver side and ticks at low rpms. Put your ear up to your EVAP box and I'll bet that's the source.
  16. Sep 26, 2016 at 2:19 PM
    cruiserguy
    Elijah
    SEKS
    Ummmmm, ummmmm.... You should follow the manufacturer's recommendations on oil weight and I like Mobil 1. It's inexpensive at Walmart.
  17. Sep 26, 2016 at 2:55 PM
    jacobbryant421
    Jacob
    Ok guys thanks alot. Just one more question. Why is it so audible from the wheel well and from under the truck?
  18. Sep 26, 2016 at 2:56 PM
    cruiserguy
    Elijah
    SEKS
    If is what he mentions :
    It's located right by the wheel well under the hood.
  19. Sep 26, 2016 at 3:06 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    no lifters to be heard
  20. Sep 26, 2016 at 3:06 PM
    jacobbryant421
    Jacob
    Ok I will check it later. I remember hearing like a vacuum type suck noise from the charcoal canister but it might be it
