Taco to 4runner?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mnewman03, Nov 9, 2018.
  1. Nov 18, 2018 at 7:55 PM
    #181
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I understand KDSS, know the details. It's a hydraulic system that moves the front and rear swaybars via hydraulics. Theoretically, that seems good, but anything hydraulic fails.
    Nice system initially, then when it wears out KDSS is godawful expensive to replace. You'll rip it out and put a traditional suspension in. Same thing people did with the XREAS.
    oconnor likes this.
  2. Nov 18, 2018 at 8:23 PM
    #182
    YellowSnow
    YellowSnow Chasing Pink Taco
    San Diego
    19 TRDOR
    KING/YOKOHAMA/RLD/RRW/RCI/BAJA/ROOFNEST
    It’s funny....haven’t read one story on the forums of KDSS “wearing out”...care to elaborate?
  3. Nov 18, 2018 at 8:24 PM
    #183
    YellowSnow
    San Diego
    19 TRDOR
    Freaking legit spec rig brother! Any advice for someone looking to upgrade the same King lift as this?
    Lord Helmet[QUOTED] likes this.
  4. Nov 18, 2018 at 9:34 PM
    #184
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Thanks! I did upgrade to 650 front springs from 550 spring rates. Rear springs are Metal Tech 2" lift. Advice wise it's super easy to install the Kings w/KDSS up front and rear. Just make sure you either rent or buy a spring compressor for the rear spring install. It makes the job easier for a one man job :thumbsup:
  5. Nov 18, 2018 at 10:07 PM
    #185
    COOutlaw
    COOutlaw Old Guy-fan of: Shotguns,Birddogs,Flyrods,Whiskey.
    Colorado
    2019 DCLB TRD OR CEMENT
    None yet
    X-REAS was part of the actual suspension system (physical shocks and spring dampening)...hydraulically linked, controlled dampening. KDSS is (like you said) a sway bar control system. When X-REAS failed it left a vehicle listing to one side and was no longer equalized in dampening, people often pulled the system out and went to "a traditional system" as you stated, because of the expense of replacing an entire "suspension" system. It also caused issues with lifting and required removal or extreme modification to do so. KDSS being only swaybar related....already uses a "traditional suspension" and supports that system with engineered swaybar control. All hydraulics do fail...you've replaced your shocks on some vehicle right? The difference...KDSS works with any suspension modifications up to about 3", and does not require anything if it fails, except replacement of hydraulic cylinders supporting the swaybar control IF you wish to maintain it....otherwise rigid mount the swaybars, remove them, or simply replace the cylinders. On a KDSS system the "traditional suspension" stays in place whether the sway control is active or not. KDSS is different from X-REAS in almost all ways other than the design purpose. Apples to Oranges. IMO. FWIW. YMMV. Outlaw out.
  6. Nov 19, 2018 at 10:58 AM
    #186
    monkeyface
    Colorado
    My fault. Carry on, KDSS men.
  7. Nov 19, 2018 at 1:24 PM
    #187
    MTSN
    MTSN Well-Known Member
    Denver
    17 Tacoma TRD Off Road
    Why not a Land Cruiser? They're slightly bigger, but totally manageable and ridiculously capable on the trail while giving you a nice V8 with close to 400 horsepower and FAR nicer than virtually anything Toyota makes (standard 4 zone climate control with rear heated seats standard starting in 2008 for example). They're expensive when new, but you can find an 08-11 with decent miles for mid $20-35k range, a 13-15 (no 2012 model year) for $35-55k or a 16+ for $55k+. The only major differences in the "gens" is that in 13 the electronics got updated, cooled seats added, radar cruise, couple little things like HIDs, and then in 16 they got an 8 speed tranny, LEDs everywhere and the Toyota safety tech package. The Land Cruiser is the pinnacle IMO, and I've had 4 including 2 we currently own. The only downsides are (1) they're expensive - but depreciate slowly (2) they're thirsty at ~12-15mpg combined depending on build - what modern gas Toyota truck gets good mpg anyway (3) mods are expensive - few manufacturers support the platform and all parts are heavy and $$$. If you don't need a bed in a truck, there are few better all around vehicles in the world than a 200 series Land Cruiser. If you want to spend less, the 100 series Land Cruiser is incredibly good too and far easier to find since they made many more than 200 series.
    qJuurBNaOtpwlJPhzTCc7oKEqG84igdRU-qEsvG5_fd99e83239bf8085cb576ed05004f4bf9299bcff.jpg
    GDMfV4iVwW3uKIqVT5K8ayvQkQKjwjoSt3Cp2Ayo_b937e9b005206c4c71e870861dcf8371b171fb30.jpg
    GSDLVR123, 13txtaco and Riding Dirty like this.
  8. Nov 19, 2018 at 1:44 PM
    #188
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    I also vote for Land Cruiser. You can also go with a LC200 2013 for about $40k.
    MTSN[QUOTED] likes this.
  9. Nov 19, 2018 at 2:24 PM
    #189
    monkeyface
    Colorado
    LC200, 5800lbs curb weight, only 9" stock ground clearance, 5.7l V8. 5th Gen 4Runner seems better.
    Sure would be nice if Toyota slapped that sweet 4.6l V8 into the 4Runner. The 4.6l is the base engine now for the Tundra. The 4.6 can fit into the 4Runner engine bay, hell they put a 4.7L V8 into the 4th Gen 4Runner and it's pretty easy to work on, good enough room in the engine bay to do maintenance.
  10. Nov 19, 2018 at 5:45 PM
    #190
    MTSN
    Denver
    Lol - 4runner is better in what way exactly? Very insightful post there.
  11. Nov 19, 2018 at 5:48 PM
    #191
    phsycle
    phsycle Well-Known Member
    CA
    They do. It’s called a GX460.
  12. Nov 20, 2018 at 12:09 AM
    #192
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I agree with @Lord Helmet but I prefer red.
  13. Nov 20, 2018 at 9:41 AM
    #193
    jimbro
    jimbro Well-Known Member
    Jim
    Manoa, Hawaii
    2016 Magnetic Grey DCLB TRD sport
    6” Fabtech lift, Fox reservoir coilovers and shocks, Detroit locker, 5.29 front and rear, 35x12.50x17 Falken AT3W on SCS Ray 10, rock lights, ditch lights, CB
    I got black last time...probably going black again but Fox this time on the Taco
  14. Nov 20, 2018 at 9:43 AM
    #194
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Be wary of fox in Hawaii. The salt air eats the shit of those for some reason.
    Lord Helmet likes this.
  15. Nov 20, 2018 at 9:52 AM
    #195
    jimbro
    Jim
    Manoa, Hawaii
    Oh really?! Shit maybe i'll be going Blue instead. Or maybe just go Icon again.
    El Duderino[QUOTED] likes this.
  16. Nov 20, 2018 at 9:56 AM
    #196
    El Duderino
    Jeremy
    HI->PNW
    Yea ask some of the guys in our Oahu thread they tell you the same. I wanted go fox until the told me what’s up.
    jimbro[QUOTED] likes this.
  17. Nov 27, 2018 at 5:55 PM
    #197
    monkeyface
    Colorado
    Yeah, sure would be nice if Toyota allowed the 4.6 into the 4Runner, not gonna happen though. I looked at the GX460, I think they had standard rear air suspension, not a simple vehicle like the 4Runner with a manual T-case.
  18. Nov 29, 2018 at 1:13 PM
    #198
    jb.
    jb. Well-Known Member
    Justin
    Southern Colorado
    2013 Lexus GX460
    I think the air suspension is only standard on the "GX Luxury." I believe they call it "Adaptive Variable Suspension."
  19. Sep 7, 2019 at 10:02 AM
    #199
    jdeestoneman
    jdeestoneman Member
    2017 MGM Tacoma TRD Sport
    Hey Meso! Nice pair of toyota’s, if you have a Runner why don’t you have more mods available for them?
  20. Sep 7, 2019 at 1:19 PM
    #200
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    I looked at the 5th generation (N280) 4Runner before I bought my Pro. I liked the old school drivetrain but was turned off by the dated interior, KDSS (Kinetic Dynamic Suspension System), nearly 11-year old platform, lack of push button start, etc.
