Taco towing capacity
Discussion in 'Towing' started by runrob1, Jul 25, 2017.
  1. Jul 25, 2017 at 6:00 PM
    runrob1
    runrob1 [OP] Member
    Rob
    Tacoma 2014 Black
    Hey Everybody,
    Rob here. purchased a 2014 Tacoma double cab V6. Do all the 4x4 V6 double cab Tacoma's pull 6,200 pounds.
    Love my truck. So much.
    Thanks
    Rob
  2. Jul 25, 2017 at 6:18 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    6500 lbs only with oil and tranny coolers (part of the official towing package) - and as far as I can tell on auto transmissions only for the 16/17 models (as per the 6-speed owners manual).
  3. Jul 25, 2017 at 6:20 PM
    medic2230
    Murph
    Bama! Roll Tide
    6500 with factory tow package. Minus the yellow sticker in the driver's door if you have one.
    runrob1[QUOTED][OP] likes this.
  4. Jul 25, 2017 at 10:54 PM
    runrob1
    runrob1 [OP] Member
    Rob
    Tacoma 2014 Black
    Can I add the tow package to my Tacoma?
  5. Jul 25, 2017 at 11:01 PM
    OnHartung'sRoad
    There are after market tranny and engine oil coolers and such- that would be the hardest part of the upgrade I would think. Mechanically it's the same engine- right? You just wouldn't be getting the Sway control, but a good weight distribution hitch would take care of it.
  6. Jul 25, 2017 at 11:02 PM
    medic2230
    Murph
    Bama! Roll Tide
    I'm sure you could but it's a good deal of stuff to add. Oil and tranny coolers, receiver hitch, 7 pin connector, wiring into the cab for brake controller, relays under the hood, 130 amp alternator and a larger battery. It won't be cheap. This is assuming you have a auto.
    What are you looking to tow?
    TireFire likes this.
  7. Jul 25, 2017 at 11:04 PM
    OnHartung'sRoad
    I'm not sure of the engine compression and torque for yours, is it the same as the 16/17's?
    Is yours automatic? If so, you could add a second tranny oil cooler as it has one in the radiator already. The manual tacos do not obviously have it and are rated at 3500 Lbs.
  8. Jul 25, 2017 at 11:05 PM
    medic2230
    Murph
    Bama! Roll Tide
    He has the 4.0 v6.
  9. Jul 25, 2017 at 11:09 PM
    runrob1
    runrob1 [OP] Member
    Rob
    Tacoma 2014 Black
    I have found a thread where it pretty much states better to a Taco with the tow package installed. Expensive to add everything after the fact. Oil cooler etc
    medic2230 likes this.
  10. Jul 25, 2017 at 11:11 PM
    runrob1
    runrob1 [OP] Member
    Rob
    Tacoma 2014 Black
    I wanted to tow my 5500 lb boat.
  11. Jul 25, 2017 at 11:14 PM
    OnHartung'sRoad
    There's a 4.0? I'm curious how that compares in compression/torque to the newer 3.7's...
  12. Jul 25, 2017 at 11:17 PM
    runrob1
    runrob1 [OP] Member
    Rob
    Tacoma 2014 Black
    Me too it drives like a bat out of hell. But I'm pulling in oregon up over the Cascade Range. So it's hard on transmissions.
    I need a truck big enough to tow the boat over the mountains but still fit in a downtown parking garage
  13. Jul 25, 2017 at 11:17 PM
    medic2230
    Murph
    Bama! Roll Tide
    Toyko Joe and TireFire like this.
  14. Jul 25, 2017 at 11:18 PM
    medic2230
    Murph
    Bama! Roll Tide
    Pics?
  15. Jul 25, 2017 at 11:23 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    The 4.0 is much better for towing than the 3.5 because it has more torque lower in the rpm range
  16. Jul 25, 2017 at 11:23 PM
    medic2230
    Murph
    Bama! Roll Tide
    Compression is 10:1 Torque is 266 lb-ft.
  17. Jul 25, 2017 at 11:23 PM
    TireFire
    Olympic Peninsula
    What 3.7?
    verynearlypure and Toyko Joe like this.
  18. Jul 25, 2017 at 11:26 PM
    TireFire
    Olympic Peninsula
    This is false. Manual tacos can tow as much as the automatic ones. Those just didn't get the tranny cooler because they don't need it. I have a 2010 manual and added the tow package myself, wasn't a big deal
  19. Jul 25, 2017 at 11:28 PM
    runrob1
    runrob1 [OP] Member
    Rob
    Tacoma 2014 Black
    I have the 4.0 automatic
  20. Jul 25, 2017 at 11:31 PM
    medic2230
    Murph
    Bama! Roll Tide
