taco will not run please help
Discussion in '4 Cylinder' started by dooredtaco, Mar 29, 2012.
  1. Mar 29, 2012 at 10:05 AM
    dooredtaco
    dooredtaco [OP] Well-Known Member
    97 doored xtracab, 02 double cab
    hi ok everybody first i will tell you what all i have replaced in the past month:
    spark plugs and wires from the factory, mobile1 high mile full syn. oil with factory oil filter, PCV valve, front o2 sensor, fuel pump, fuel filter, ran seafoam through the vac. line
    a few days ago the truck ran hot and was running bad so i seen that it was my alternater belt pretty much had no teeth/groves anymore and figured that was why the truck overheated cause the water pump wasnt being able to spin right so i fixed that and it fixed the overheating but truck was running like crap then two days after that truck broke down so now i have tried another fuel pump- no results, i have swapped the fuel rail and injectors from my other truck but still no results. i have good compression 160 psi on each cylinder i have cheaked for spark with a screw driver sticking out of the end of wire but had good spark. all fusses are good. oil still looks great and coolent looks great.
    ok so here is what the truck is doing after sitting for a long time truck will start and run very bad and die when put into gear. then it wont start back up and it just soakes down the spark plugs and the crazy part is i can unplug the MAF sensor and the truck will crank back up and idle perfect and rev up perfect but
    will spit and sputter if try to drive it over 2000 RPM (still while having MAF unplugged) and then as soon as try to plug MAF back in truck will instantly die. WTF
    i have cleaned the MAF- no result and i have checked with starter fluid many times and cant find any vacume leaks. there are five wires that go to the MAF harness and 4 out of the 5 ohm out with the ground and the one that doesnt is the gray with red strip wire.
    thanks for any help i am about to go crazy here
    also the truck is a 98 2.4L auto
    __________________
  2. Mar 29, 2012 at 10:05 AM
    dooredtaco
    also could it have jumped timing from the belt not grabbing the pulley?
  3. Mar 29, 2012 at 10:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    You have a chain and they typically won't jump teeth unless they are damaged. You showing any codes?
  4. Mar 29, 2012 at 10:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You dont have a timming belt. It has a chain. So the likelyhood of it jumping a tooth or so is unlikely. What engine codes are you throwing?
  5. Mar 29, 2012 at 10:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mere seconds Ben.....mere seconds.....:cool:
  6. Mar 29, 2012 at 10:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Still quicker............:cool:
  7. Mar 29, 2012 at 10:28 AM
    dooredtaco
    yeah i thought that was not very likley to happen to a chain also but hey i just been trying to think of any possible thing it could be. on the codes dont have any as of now cause i cleared them and can only get it to run with the MAF unplugged so of course then it popped up the MAF malfuntion codes and a TPS malfuntion code but when i had it running the night before last with the MAF plugged in it only had the system bank 1 running too lean codes which has been popping up the whole time i have ever had this truck (over a year)
  8. Mar 29, 2012 at 10:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    You should stop unplugging the MAF. You can damage it and or blow the EFI fuse. I would suggest looking at the EFI fuse right now.
  9. Mar 29, 2012 at 10:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    Here's the basic list to look at regarding that code, which I assume is a P0171.
    It sounds like you're not getting enough gas.
     Air induction system
     Injector blockage
     Mass air flow meter
     Engine coolant temp. sensor
     Fuel pressure
     Gas leakage in exhaust system
     Open or short in A/F sensor (bank 1 sensor 1) circuit
     PCV valve and hose
     PCV hose connection
     EFI main relay
     A/F sensor heater and relay circuit
    But what troubles me is that it was overheating. Have you pulled the plugs and inspected them since it over heated?
  10. Mar 29, 2012 at 10:43 AM
    dooredtaco
    yes i have looked at plugs there new but you know from getting soaked from trying to crank so i have cleaned them best i could and gonna get new ones o nce figure this out the overheating was from the water pump not being able to spin efficiently but now it dont overheat
  11. Mar 29, 2012 at 10:45 AM
    dooredtaco
    could the Engine coolant temp. sensor cause it to run bad the other day i remember a code that popped up and said Engine coolant temp. sensor malfunction
  12. Mar 29, 2012 at 10:47 AM
    dooredtaco
    im on my way to my shop now and i will try a new EFI main relay from my other truck its the green one under the dash right?
  13. Mar 29, 2012 at 10:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    I had the ECT sensor code on my first gen before and it never ran like you described. The panel cover should tell which relay is which. I forget which is which. Double check that EFI fuse too.
  14. Mar 29, 2012 at 10:53 AM
    dooredtaco
    ok thanks i will let you know as soon as i get there
  15. Mar 29, 2012 at 10:58 AM
    dooredtaco
    im gonna stop and get a engine coolant temp. sensor on the way also
  16. Mar 29, 2012 at 10:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    Definitely won't hurt.
  17. Mar 29, 2012 at 2:38 PM
    dooredtaco
    Hey good news the old engine temperature sensor was melted new one in and she is singing lol thanks so much for the replies
  18. Mar 29, 2012 at 2:52 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Good job.
