Taco with bad frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cesar Garmendia, Oct 8, 2024.
  1. Oct 8, 2024 at 2:11 PM
    Cesar Garmendia
    Cesar Garmendia [OP] New Member
    Cesar
    Red 2007 Tacoma standard cab
    Hi everybody,
    I have 2007 Toyota Tacoma standard cab 4WD 32,800 miles
    The problem it’s the frame, Toyota dealership asking for 20k to replace it,
    Someone it’s selling me a frame 2012 model
    Do you think
    2007-2012 use the same frame ? thank you.
  2. Oct 14, 2024 at 5:30 AM
    jwarr
    jwarr Well-Known Member
    yes, the frame is the same as long as it is the same engine, cab configuration, and bed length...
    Who will do the change? it is a significant amount of work... and be prepared to replace alot of other stuff that is also too far gone to move over...
    Sometimes frames can be repaired by a good weld shop. if you post pictures of your frame, you will get some guidance on how far gone it is...
