Taco won't start!!! no Juice??!
Discussion in '1st Gen. Tacomas (1995-2004)' started by BigSurTaco, Jul 6, 2011.
  1. Jul 6, 2011 at 6:17 PM
    BigSurTaco
    BigSurTaco [OP] Member
    Torre
    Big Sur, CA
    03 sr5 4cyl 4x4 2" lift
    K&N, 2" suspension lift
    Like the title says, i 'm not getting any power from my battery in my 03 taco. The clock won't even come on. I tried jump starting it and bump starting it, checked all the fuses. nothing worked. I don't have a voltmeter, but i'm borrowing one from a buddy soon. I don't think it's the battery as i have an 2 year old optima in there. anyways, wondering if anyone has had a similar occurrence or any idea of what it could be. I appreciate any help. Thanks
    -Torre
  2. Jul 6, 2011 at 7:11 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Drop your "good" borrowed battery in & see if it changes anything, get back with us with results...(good or bad) ;)
  3. Jul 6, 2011 at 7:15 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    +1 most likely battery related!
  4. Jul 6, 2011 at 9:38 PM
    BigSurTaco
    Torre
    Big Sur, CA
    i'll give it a shot tomorrow. prolly should of done that first thing. be back with result tomorrow. thanks.
  5. Jul 6, 2011 at 9:53 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    check your alternator too.
  6. Jul 8, 2011 at 7:06 PM
    BigSurTaco
    Torre
    Big Sur, CA
    crap... battery and alternator are fine. i'm thinking it has something to do with the ignition maybe.
  7. Jul 8, 2011 at 9:16 PM
    makinhole
    makinhole New Member
    Ground? take the cables off and clean them with a wire brush then put them back on and try it again.
  8. Jul 9, 2011 at 1:49 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Its probably the ground...mines did something werid like that the other day...all I did was add an extra (good) ground to the frame and it didn't happen again
  9. Jul 9, 2011 at 9:37 PM
    BigSurTaco
    Torre
    Big Sur, CA
    thanks for the advice. i'll give that a shot tomorrow.
  10. Jul 11, 2011 at 6:59 PM
    BigSurTaco
    Torre
    Big Sur, CA
    hmmm... cleaned the cables and ground... that didn't work. i'm having a mechanic friend come and take a look at on weds. hopefully he can figure it out.
  11. Jul 11, 2011 at 9:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Did you check the master fuse?
  12. Jul 12, 2011 at 10:58 AM
    BigSurTaco
    Torre
    Big Sur, CA
    i checked all the fuses. is the master fuse under the hood or in the cab? i lost the back plate in the cab that tells you what's what.
  13. Jul 12, 2011 at 11:40 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Under the hood. It will be one of the grande fuses. Looks something like this
  14. Jul 12, 2011 at 3:27 PM
    BigSurTaco
    Torre
    Big Sur, CA
    thanks. i'll inspect this closer
  15. Jul 12, 2011 at 4:02 PM
    BigSurTaco
    Torre
    Big Sur, CA
    all the fuses are fine. damn!
