Taco won't start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacodru, Apr 1, 2017.
  1. Apr 1, 2017 at 10:00 AM
    tacodru
    tacodru [OP] Active Member
    Hi
    wanted to see if anyone has experienced this before...Taco was running fine last night, parked it in the garage, came out this morning to run and errand and it won't start.
    Checked to see if there was a light left on and it doesn't appear so. The dash lights are flickering, and the car won't turn over nor will it make a clicking sound. Checked the voltage of the battery and it seems good as it is reading -12.65vDC. Checked the battery connections and they appear to be tight, ground is also tight. Also, went under the truck to see if any connectors had come loose and I don't see anything dangling.
    Any other ideas of what I can check?
    Thanks
    probably should have mentioned that it's a 2012 TRD Sport v6
  2. Apr 1, 2017 at 10:02 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Try unhooking the battery for half an hour and then plug everything back in. The system may just need to be reset.
  3. Apr 1, 2017 at 10:09 AM
    tacodru
    I'll give it a shot...thanks
    ZachPrerunner likes this.
  4. Apr 1, 2017 at 10:10 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Checking the battery with a voltmeter won't give you the whole story. The battery has to have a load in it.... Turn the lights on and try to start it, if the lights die out, your battery is most likely junk.
  5. Apr 1, 2017 at 10:12 AM
    tacodru
    Thanks File IFR, didn't realize that about testing the battery...then this may very well be the battery, cause the interior lights are very dim and the power locks will only unlock the main door when I click the key fob.
  6. Apr 1, 2017 at 10:13 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Time to get a battery bud.
  7. Apr 1, 2017 at 10:36 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Need a new battery.... easy peezy
  8. Apr 1, 2017 at 10:42 AM
    tacodru
    any suggestions on the brand of battery?
  9. Apr 1, 2017 at 11:27 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    If you want something cheaper that will still work fine for everyday use I might recommend an Everstart from wally world or a Duralast gold from autozone. The Everstart batteries actually get surprisingly high ratings in consumer reports. I've had good luck with both brands (have one in both my other vehicles) in the hot Tucson summers both have lasted 5 years or more for me.
    A lot of guys go with optimas if they really wanna spend some money.
  10. Apr 1, 2017 at 12:02 PM
    ZachPrerunner
    Southeast TN
    Interstate ftw!
  11. Apr 1, 2017 at 1:02 PM
    tacodru
    Thanks for all the help...it was the battery, picked one up at AutoZone that matched the current ratings and the truck is running great again.
