Taco42's '12 Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Taco42, Oct 25, 2012.
  1. Nov 15, 2012 at 5:30 AM
    Taco42
    Taco42 [OP] Well-Known Member
    Jeff
    St. Louis Area
    '12 TRD DCSB Off Road 4x4
    OME lift w/Nitrocharger Sports, 885 coils, Dakar leaf pack, carrier bearing drop, 5mm driver side spacer (no more Taco Lean), Light Racing UCAs, TRD Beadlock 16" wheels, Cooper S/T Maxx 265/75R16s, TRD Exhaust, TRD skid plate, AntennaX shorty, AFE Drop-In dry filter, Custom Axleboy light bar w/PIAA 520 fogs, Custom black leather seats
    Honestly, I didn't look at 33s because of the rubbing issues folks on here have with them. Didn't want to have to cut/trim/bend/etc to run a tire that's going to make my gas milage even worse. Besides, I've got a JK on 35" MTs if I need to get somewhere my Taco won't go :D
    The pic with my Carve was taken on the Katy Trail just west of St. Charles in MO. To be honest, I'm just getting back into riding as an attempt to get my fat ass back into some semblance of shape. Right now if I do 15mi of trail riding at 13MPH, I'm done for the day. Still working on building my stamina and strength. Greatly appreciate the offer for a ride tho! PM me if you're in this area again.
  2. Nov 15, 2012 at 5:32 AM
    Leonel
    Leonel Well-Known Member
    San Francisco,CA.
    2017 Super White DCSB TRDOR/6MT
    TC,Ext Kings,U402's,4:88's.Elocker rear,ARB front,etc..
    Truck looks great!
    I want those wheels also but the dealer won't sell them to me, how did you go about getting them?
    thanks
  3. Nov 15, 2012 at 5:58 AM
    Taco42
    Jeff
    St. Louis Area
    Thanks Leonel. Had the same problem with my local dealer. Ended up ordering the wheels from Sparks Toyota in NC. Not sure why they can get them, but not sure I want to know ;)
    http://www.trdsparks.com/
  4. Nov 15, 2012 at 8:14 AM
    Leonel
    San Francisco,CA.
    Thank you so much for the link ! Greatly appreciated
  5. Dec 5, 2012 at 7:04 PM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Man I'm so leery about plasti dip. What did you think?
  6. Dec 5, 2012 at 7:43 PM
    Taco42
    Jeff
    St. Louis Area
    It was actually really easy to do. I started with just one door emblem and ended up redoing it a second time before I got it right. The first time around I didn't put heavy enough coats on, so even after 4 coats it was thin. Second time around I did moderately heavy coats and it came out much better. I let it dry for a couple hours and just peeled the overspray away and it peeled around the letters perfectly. It was seriously a bit like magic :D Then I used a pair of tweezers to get the dip out of the centers of the letters (O and A). It's held up to a couple car washes and a decent number of highway miles.
    Still got at least half a can left. You're welcome to it if you want to try it out!
  7. Feb 9, 2013 at 6:10 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Good looking truck!
  8. Feb 10, 2013 at 7:49 AM
    Taco42
    Jeff
    St. Louis Area
    Thanks! Had a chance to get all the road grime and salt off her yesterday - almost forgot there was a darn good lookin truck under all that muck!
  9. Dec 30, 2013 at 4:54 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Quick question or two for you, if you can please help me out.
    I want to run nearly the same suspension setup as you (maybe the 886 instead of the 885 for use with a ARB bumper) and have the same wheel/tire setup.
    1. What is your center hub to fender measurement for your truck.
    2. Any issues with the beadlocks rubbing the aftermarket UCAs without spacers? I don't like the idea of using a spacer if I don't have to.
  10. Dec 31, 2013 at 7:21 AM
    Taco42
    Jeff
    St. Louis Area
    I'll get out today and get the measurements for you. No rubbing whatsoever with 265/75s on the TRD beadlocks.
  11. Dec 31, 2013 at 8:03 AM
    Taco42
    Jeff
    St. Louis Area
    Hub center to fender measurements:
    Front: 23.5"
    Rear: 24"
    Give or take a quarter inch, I wasn't real precise with the center of the hub. Also keep in mind that's with the overload leaf removed from the Dakar pack.
    BTW - the ride is soooooo much better than stock. You'll really like the OME setup!
  12. Jan 1, 2014 at 8:33 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    No worries. I was at:
    Front: 20 1/4"
    Rear: 22"
    So I am looking at just over 3 inches. Time to measure the garage!
    Thanks again.
  13. Jan 5, 2014 at 9:35 PM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Nice truck! Looks pretty familiar haha.
  14. Apr 11, 2014 at 11:52 AM
    Taco42
    Jeff
    St. Louis Area
    Thanks man! The Coopers are awesome in the snow. I've got all grip I want when I drive respectably, and not too hard to break loose when I want to play. Great mix between the traction of an AT and the look of a MT. Would definitely pick them again.
  15. Apr 24, 2014 at 7:46 PM
    #35
    Mujtaballa
    Mujtaballa Well-Known Member
    Missouri
    2001 and 2004 Tacoma TRD off road 4x4
    Stock: Light bar!
    Bro im digging the set up! How you like ur shocks so far?
  16. Apr 25, 2014 at 7:07 AM
    #36
    Taco42
    Jeff
    St. Louis Area
    Thanks man. The OMEs have been great. Much better ride than stock, and very capable. I get much less rear wheel hop on washboard with the new setup.
  17. Jan 15, 2015 at 10:24 AM
    #37
    XwXRYANXwX
    XwXRYANXwX Well-Known Member
    Louisville, CO
    2010 Access Cab TRD Sport w/ TRD Supercharger
    Did you remove any of the leafs on the dakars? And did you run into any vibe issues?
  18. Jan 16, 2015 at 5:48 AM
    #38
    Taco42
    Jeff
    St. Louis Area
    Yep, I removed the overload leaf. I don't tow or haul much and I wanted to get rid of as much of the rake as possible.
    Absolutely no vibrations. The OME kit has performed amazingly well and, to me, rides far better than the stock TRD OR setup.
  19. Jan 16, 2015 at 7:38 AM
    #39
    XwXRYANXwX
    Louisville, CO
    hmmmmm I have an access cab and am going to do the same lift. But I also have a shell with racks, and tow a trailer with dirtbikes every now and again....
    Do you think I would benefit leaving that leaf in, or would it get by still removing the overload leaf? I dont want to end up with the rake look.
  20. Jan 16, 2015 at 11:03 AM
    #40
    Taco42
    Jeff
    St. Louis Area
    Sounds like you've got a lot more variables than I had. I would think if you're regularly towing or hauling, you'd want the overload leaf, but I'm honestly not sure. Sounds like a great question for an experienced 4x4 shop. Sorry I'm not more help :cheers:
