tacofeaver's build
Discussion in '2nd Gen. Builds (2005-2015)' started by TACOFEAVER, Sep 25, 2009.
  1. Sep 25, 2009 at 6:20 PM
    TACOFEAVER
    TACOFEAVER [OP] Well-Known Member
    Newfoundland, Canada
    09 SR5
    3" lift, and 265 75 R16 Trxus M/T's enroute. (to be installed in about 2 weeks)
    2009 Access Cab 4x4 SR5, Pyrite
    It all started with the Bug Deflector which was installed 2 days after I got the truck. About a week after that, I got the Toyota 3 fold soft Tonneau Cover. And about 2 weeks after that I installed the Toyota Class III hitch and wire harness.
    Here, I towed my damn 05 Jetta 1.8t 700km, or 440mi to the nearest VW dealer to get the turbo/tranny replaced under warranty.
    Next, the Interco Trxus M/T's were installed. Had to go take a few poser shots with the new tires!:D
    The rims are getting painted black (by the body shop) in the spring!
    I then put in the Procomp 3" leveling kit. This had the spacers for the front, the front differential drop, and the AAL's for the rear end.:cool:
    This weekend I will be doing my Satoshi Grille... Think I have everything I need - but I guess I'll find out! Also installing the Pop & Lock tomorrow too!
    Cut the centre out of the grille... and got it taped up from the inside, applied the fiberglass, and once it had started to harden, I trimmed the excess off. (I made sure the top line of the tape was where I wanted the fiberglass to end!
    While waiting for the glass to dry, I relocated the horn behind the battery, and painted the rad area with high heat paint!
    Used Bondo next to fill in, and sanded off - ended up doing 2 coats. Covered chrome in painters tape, and did 4 coats of Sandable primer - sanding between coats. Did 3 coats of flat black - and then did a wet sand, followed by 3 more coats.
    Attached grille with zip ties, and installed the Emblem. Bolted everything back to the truck!
    DSCN1570.jpg (its a little dark - so I'll see about getting some better shots tomorrow!)
    I've got a set of FJ predator bars getting modified to fit the truck, and they should be installed next weekend. And I've ordered the fog lights for the front bumper...
    Trying to decide between a bull bar, or the nfab bar... Concerned that the nfab with 4 700's may cover up too much of my satoshi...:eek: and we can't have that!
    I do have a Cobra Cb, and 1.5' mag mount cobra antenna... have the cb wired up to an old 12v cell charger as I havent found the right spot to mount the cb yet. Also need to mock up an aluminum mount somewhere on the dash for my Garmin Gps.
    We're currently sold out of Tacomas again at the dealership - so as soon as we have another pyrite sr5 in stock, I hope to get some comparison shots as well!!
    Any thoughts, comments or suggestions are welcome! :D
    Cheers,
    Dave
  2. Sep 26, 2009 at 9:38 AM
    Tbird
    Tbird Well-Known Member
    Tom
    Santa Teresa, NM
    05 4X4 TRD Sport Access cab (white)
    ICON Ext.trav coilovers, rear ICON w/res. TC UCAs. All-pro 3" leafpac & U-bolt flip kit. Konig Countersteer offroad wheels. Goodyear Durtracs 260/75/16. Blacked-out badging, BHLM, Extra D-rings, Satoshi grill, SockMonkey "All Terrain" decals, Avid Off-road light bar and rock rails, Wet Okey seat covers. Weathertech digital fit floor mats. GROM ipod interface.
    Looking great Dave!
    Can't wait to see how your grille turns out. Where did you get the emblem? Part Number?
    Thanks!
  3. Sep 26, 2009 at 4:11 PM
    TACOFEAVER
    09 SR5
    Thanks!
    UPDATE: Satoshi now complete and installed
    Tbird, the part number for the emblem is 75311-90K00
    from an FJ62 landcruiser.
  4. Sep 26, 2009 at 4:14 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  5. Sep 26, 2009 at 4:24 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    looks good man
  6. Sep 29, 2009 at 12:49 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Looks even better in person. Good job Dave! Pictures don't do it justice
  7. Jun 19, 2010 at 6:49 AM
    TACOFEAVER
    09 SR5
    ok - so the truck sold back in February - as my wife needed a vehicle to car-pool with. Since then I've picked up a 94MR2 that I brought in from Japan.
    The newest project hit the driveway a week ago... a 93 toyota pick-up
    I've since cut out all of the rust from the box!
