tacoma…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LeoR11, May 12, 2022.
  1. May 12, 2022 at 3:31 PM
    #61
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    The manifold bearings are a joke, so don't run with that one. I'm guessing the noise is normal in these engines. I've heard a few since owning a tacoma with the same engine. Seems every once in awhile theres a noisier one you come across. Doesn't mean their bad.
    9516toyota[QUOTED] likes this.
  2. May 12, 2022 at 3:33 PM
    #62
    9516toyota
    9516toyota Member
    Thats good to know. I've had it for two years and never heard a noise like it. I figured somebody on here may recognize the noise from a problem they've had and might be able to shed a light on it. The ticking is really clear on my phone, maybe not so much online.
  3. May 12, 2022 at 3:34 PM
    #63
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    No it wasn't, but your video sure was. Listen to the damn mechanic. You came in asking for a mechanic's help.
  4. May 12, 2022 at 3:40 PM
    #64
    9516toyota
    9516toyota Member
    Why so hostile? Goodness. That was my video, and the comment was already addressed by others way earlier... We've moved on... It's my truck, so I'm addressing the new comments that are giving new input.
  5. May 12, 2022 at 4:23 PM
    #65
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    xxTacocaTxx, SR-71A and Rock Lobster like this.
  6. May 12, 2022 at 7:13 PM
    #66
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    My ears aren't what they used to be...
    Without some way of getting a directional idea of where the noise is coming from, it's hard to make a guess. What I'm hearing sounds like an idler pulley or maybe even an exhaust gasket leak, but my ears aren't what they were. Both of those could come on suddenly, though the exhaust gasket leak wouldn't go away when warm whereas an idler pulley could get better when warm.
    What the hell do I know? A person would need to crawl around with an open hood to get a better idea where the sound is coming from.
    SR-71A likes this.
  7. May 12, 2022 at 7:23 PM
    #67
    OldSchlPunk
    Rich
    East Central Wisco
    You seem to like to call names, so how bout this: Snowflake. (I'm a Boomer, BTW. In my years on this rock I've learned a few things.)
    People here mostly were trying to help, it's what we do here on TW (well, a couple were dicking around). I guess the brutal honesty was a bit much for your sensibilities. Brutal honesty, though, can cut through the bullshit and get closer to a resolution quicker. It works better than butthurt.
    Ah, what the hell, today has been a sh$tshow since I crawled out of bed, what was I expecting?
  8. May 13, 2022 at 6:15 AM
    #68
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i could have sworn we dont have exhaust gaskets on this truck but machined surface to machined surface. Does sound exhaust like
  9. May 13, 2022 at 7:57 AM
    #69
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    Again, check the rotator splint, it needs to be repaired asap. Yes reusing this.
    So you work at Toyota and are not even familiar with the general warranty terms that have been in place for a very long time. No wonder you joined a web forum looking for answers and to complain.
    3-years or 36,000-miles whichever occurs first. Your vehicle is also covered by a powertrain warranty lasting 5-year or 60,000-miles.
  10. May 13, 2022 at 8:00 AM
    #70
    9516toyota
    9516toyota Member
    It has 68k on it, and it's a 2016. So, both of those have passed. The complimentary Toyota care maintenance was up before I bought it.
  11. May 13, 2022 at 8:02 AM
    #71
    Xtremsiege2
    Norwalk CT
    Ahh okay, thought you said it had 50k miles on it. All good.
  12. May 13, 2022 at 8:04 AM
    #72
    9516toyota
    9516toyota Member
    I could have, so my apologies. This morning when I started it, it sounded normal. So, it could have been the injector cleaner like others have said, but hearing it for the first time, it sounds really rough. I appreciate all of you guys who helped!
  13. Jun 7, 2022 at 12:48 PM
    #73
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    My 2 cents (and worth every penny) IMO: For me: that recording you made is fine; it is close enough to the truck, clear enough, loud enough, and distinctive enough that if it was my truck making that noise after I just started it , I prob would have panic-shut it down immediately and called AAA to tow it to my trusted mechanic for diagnosis. I don't think I would crawl under my truck if it was making that kind of noise. FWIW: it doesn't sound like an early-warning rod knock and if it is indeed the "injector cleaning cycle": It sounds like it's broken. :eek:
    :spending:
    Maybe
    a spun bearing and it's about to throw a rod through the block? But to me more like like valves hitting pistons...at least metal-to-metal somewhere anyway...still very bad of course.
    YMMV Good luck, and welcome to Tacoma World! :pccoffee:
  14. Jun 7, 2022 at 2:09 PM
    #74
    Williston
    New England
    a wise decision
  15. Jun 7, 2022 at 2:24 PM
    #75
    Williston
    New England
    :rofl:
  16. Jun 7, 2022 at 2:31 PM
    #76
    Williston
    New England
    IMO: Sound decision. I wouldn't get under that truck making that noise either: or my own for that matter.
  17. Jun 7, 2022 at 2:57 PM
    #77
    Williston
    New England
    That is relevant, (if it's true) how? 4,592 "likes". Folks here seem to be listening. Must be doing something right.
