Tacoma 2.5" x 12-14" Shock Relocation 2005-2023 2nd 3rd gen Archive Garage
Discussion in 'Archive Garage' started by ARCHIVE, Nov 8, 2017.
  1. Jun 8, 2020 at 8:58 AM
    #481
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Doh, I'm so used to that other relocate where 12's are around 35-45 as well.
  2. Jun 8, 2020 at 10:03 AM
    #482
    Gsingh916
    Gsingh916 Well-Known Member
    2019 Toyota Tacoma trd Offroad
    Would radflo 2.5 12 inch shocks work with your shock relocation?
  3. Jun 8, 2020 at 12:25 PM
    #483
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Yes, It's been done, but note that Radflo has a potential interference because their top cap hose outlet has an unusual upturned angle
    Also, they have an unnecessarily long lower rod end, see if they have a short version like standard on King/ optional on Fox
  4. Jun 8, 2020 at 12:32 PM
    #484
    Gsingh916
    Can I run 2.0 shocks with your shock relocation kit
  5. Jun 8, 2020 at 1:01 PM
    #485
    ARCHIVE
    Eric
    Yes, axle tabs get set off bump height. Reservoir cannot mount to the shock body.
  6. Jun 9, 2020 at 4:15 PM
    #486
    Jabib
    Jabib Well-Known Member
    Garry
    Westminster
    2020 DCSB OR 4WD 6MT
    Getting ready to install soon and have 2 questions.
    1) Is there a specific post in this thread with clear direction on setting up the angle of the lower shock mounts based on bump stop?
    2) I have a Decked system in my bed. Anyone done the relo towers with a Decked system? Seems like the bolts for the Decked system will be really close to the tower.
    TIA
  7. Jun 9, 2020 at 5:55 PM
    #487
    ARCHIVE
    Eric
    1. Post #500 gives approximate location, I can email instructions if you didn't receive them. Regardless, axle tabs are to be set off your specific setup full compression bump height
    2. No one has contacted me with interference to Decked system, but if you want to send pics I can review and give you my impression
    Jabib[QUOTED] likes this.
  8. Jun 9, 2020 at 6:11 PM
    #488
    Jabib
    Garry
    Westminster
    Thanks!
    As far as the Decked goes I guess it depends on how close the back of the relo tower is the the bed wall. The bolts can obviously be turned around or even 2 of them possibly drilled through the tower (worst case).
    Thanks Eric. I'm really looking forward to getting my HHs, Relo tower and u bolt flip kit in. My truck is like that guy at the gym that never does leg day :D
  9. Jun 9, 2020 at 6:29 PM
    #489
    ARCHIVE
    Eric
    From the pic, I think you might be ok with no interference, the rear of the tower falls right near that 7/16" round hole in frame, and leans a few degrees forward towards engine at the top
  10. Jun 10, 2020 at 12:52 PM
    #490
    Radflo Shocks
    Radflo Shocks Member
    Radflo does offer a shorter rod end for applications like this.
    Brian422 and ARCHIVE[QUOTED][OP] like this.
  11. Jun 10, 2020 at 4:04 PM
    #491
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  12. Jun 15, 2020 at 5:54 PM
    #492
    Chief_Reign
    Chief_Reign Member
    2018 MGM Tacoma TRD Off-Road
    I'm looking at getting the relocation done with the king 12' smoothie shocks and I was wondering if 1.25 spacers will be enough. I'll be running the stock TRD Off-road set of wheels and tires until the tread wears a little more.
  13. Jun 18, 2020 at 9:36 AM
    #493
    ARCHIVE
    Eric
    Sorry for delay in answering, that would be a bit to close and might rub as I figure, do you have the wheel specs?
    I think they would be about 5.25" backspacing
  14. Jun 18, 2020 at 1:37 PM
    #494
    Khonception
    Khonception Well-Known Member
    Khon
    Ft worth Tx
    17 DC OR/13 DC/08 DC OR
    If I was to go with King triple bypass, should I go with 12 or 14”? Currently have Allpro expo leaves and later on might go to Deaver Soa stage 3.
  15. Jun 18, 2020 at 1:53 PM
    #495
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    For spring over, I’d say go with a 14” short body, welded lower rod end, the lot. The important part since you’re going bypass is making sure to cycle your travel fully and determine where you want your ride height to be in the tube zones with how much bump travel you will have. That will also determine where you burn in your lower axle tabs. If you less than 6” of bump travel, It might be better to go with a 12”.
    Khonception[QUOTED] likes this.
  16. Jun 18, 2020 at 3:01 PM
    #496
    ARCHIVE
    Eric
    If you want bypasses, I feel you're more focused on bump travel and controlling it, therefore I think the droop is less important.
    You would already get a bunch of droop with 12", and the springs you mentioned are tapped out around 12".
    I don't know if King builds bypasses on the 14" "short body", I know they offer the SB for smoothy. If they do offer bypass in 14" SB, then that is a good move
  17. Jun 18, 2020 at 3:28 PM
    #497
    Khonception
    Khon
    Ft worth Tx
    Ordered!
    Yea i didn’t see a short body for bypasses either. So looks like I’ll be going with the 12”. But thanks for the response, as well as @Supra4x4 preciate it!
    ARCHIVE[QUOTED][OP] likes this.
  18. Jun 29, 2020 at 9:42 AM
    #498
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Anyone know this guy? Don’t have IG and wondering if he’s on here. Curious what size spacer he had to run with these wheels. Shock relocation is purchased and have these same wheels at the moment.
  19. Jun 29, 2020 at 10:03 AM
    #499
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Whats the backspacing on those wheels? You want around 3” BS to clear a 2.5 rear shock with these towers.
    AY_ARONTRD[QUOTED] likes this.
  20. Jun 29, 2020 at 10:07 AM
    #500
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    4.5
