Tacoma 2.5" x 12-14" Shock Relocation 2005-2023 2nd 3rd gen Archive Garage
Discussion in 'Archive Garage' started by ARCHIVE, Nov 8, 2017.
  1. Jan 11, 2021 at 8:59 AM
    #641
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
  2. Jan 11, 2021 at 9:01 AM
    #642
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    2 questions.
    Is a limit strap needed for this? Ive got dakar HD and HH with poly bushings.
    Also if so whats the best mounting location for a strap?
  3. Jan 11, 2021 at 9:39 AM
    #643
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
  4. Jan 11, 2021 at 9:42 AM
    #644
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Limit straps never hurt, they’re cheap insurance. On the axle, weld on a double shear tap. Up top, you can just drill a hole in your frame and bolt it on. I like the camburg limit straps.
    Brian422[QUOTED] likes this.
  5. Jan 11, 2021 at 9:46 AM
    #645
    AccuTune Offroad
    El Cajon, CA
    What ever is the smoothest/easiest and clears the tire under articulation.
  6. Jan 11, 2021 at 9:51 AM
    #646
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    thanks
  7. Jan 11, 2021 at 9:52 AM
    #647
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yea i think ill do a strap just for insurance. 2 month lead time for shocks i want so that sucks lol. May be a while before i can get setup haha.
    EatSleepTacos[QUOTED] likes this.
  8. Jan 11, 2021 at 11:19 AM
    #648
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Archive Kit comes with limit tabs and bolts, you need to source 2 straps
  9. Jan 11, 2021 at 1:24 PM
    #649
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Got a clunk in the rear after relocation.. I got good at working the front out.. only happens on droop, coming out/in driveway, i jump a curb and replicated it. Any suggestions.
  10. Jan 12, 2021 at 9:44 AM
    #650
    ARCHIVE
    Eric
    Could be the shocks knocking to one side if the bolts are not tightened. Did you bolt the top of the towers to the bed?
  11. Jan 12, 2021 at 9:56 AM
    #651
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I did.. is there a torque spec.. factory
  12. Jan 17, 2021 at 10:13 AM
    #652
    YotaGyoza
    YotaGyoza Member
    2021 TRD OR 4x4
    Waiting on my Fox 2.5 DSC shocks before teardown and assembly. I'll be installing 16x8 -20 with 285's. Back spacing is about 3.75 (3.75 is for a -18 offset wheel). Will I be needing any spacers for this setup?
    I'm gonna be running stocks for a couple months until my wheels arrive, so I know I'll need spacers for those..
  13. Jan 17, 2021 at 10:32 AM
    #653
    ARCHIVE
    Eric
    That will be really close but you might need a spacer for no rub when fully articulating
  14. Jan 17, 2021 at 10:36 AM
    #654
    YotaGyoza
    YotaGyoza Member
    2021 TRD OR 4x4
    Based on the specs, what size spacers would you recommend? I'd have to do the same up front to keep things uniform, which means more modification to clear for for rubbing in turns.
    Btw, its an AccuTune 5A mid travel kit install..
  15. Jan 17, 2021 at 3:16 PM
    #655
    ARCHIVE
    Eric
    I heard there is a 3/4" spacer out there by Bora, that should eliminate any rubbing. Consider just running 3/4" spacers out back.
  16. Jan 17, 2021 at 3:26 PM
    #656
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Right now it's getting hard to find Bora spacers I had to order direct from the manufacturer. You can get them from .25" to 4" if you order direct there is a bit of a delay but not horrible. Not like King shocks wait
    Here's the link
    https://www.motorsport-tech.com/4DCGI/switchtruckmodel
  17. Jan 18, 2021 at 1:19 PM
    #657
    YotaGyoza
    YotaGyoza Member
    2021 TRD OR 4x4
    Thank you!
    ovrlndkull[QUOTED] likes this.
  18. Jan 18, 2021 at 5:03 PM
    #658
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    :hattip:I just ran into it. Typically toytec carries them but not right now they are down to one size.
  19. Jan 18, 2021 at 5:09 PM
    #659
    YotaGyoza
    YotaGyoza Member
    2021 TRD OR 4x4
    Ordered 0.875" (7/8") Bora spacers at motorsport-tech... talked to and ordered from Lenny (I think that's what he said his name was). He stated that with the 7/8" spacers, I wouldn't have to shave the stock studs - as the 3/4" I would have to in order for them to be flush with the mounting face.
    They would have it built and sent out next week:thumbsup:
  20. Jan 18, 2021 at 5:13 PM
    #660
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    For future reference if you look at the back of the wheel and there are hollowed out spots in between the stud holes of the wheels you may not have to shave studs down as most of the times those recesses are deep enough and big enough to accommodate the stud protruding past the spacer.
    Wheel on left one that you'd have to shave studs wheel on the right is what I am referring to (these are just examples, you'd have to verify with your wheels).
    SUMOTNK and whatstcp like this.
