Tacoma 2.5" x 12-14" Shock Relocation 2005-2023 2nd 3rd gen Archive Garage
Discussion in 'Archive Garage' started by ARCHIVE, Nov 8, 2017.
  1. Jan 2, 2024 at 5:50 PM
    #1081
    TacoTuesday1
    SD CA
    oh crap. I was hoping due to them seeming to stick out wider a bit more than stock it might be fine but I guess not. Looks like I’ve got some math to do on figuring out which spacers are needed.
  2. Jan 2, 2024 at 6:07 PM
    #1082
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Just search this thread, discussed about 200 times :thumbsup:
  3. Jan 3, 2024 at 4:54 PM
    #1083
    Hami0528
    Hami0528 Well-Known Member
    Brayden
    Tulsa, Oklahoma
    2011 Timberland Mica Tacoma TRD Off Road
    Dobinson IMS shocks and coils, SPC upper control arms. Archive garage rear shock relocation kit with king 2.5x12 smoothies with adjusters and archive medium duty leaf pack.
    I have 255/85/16s what’s the minimum wheel spacer width I can use with stock 2nd gen wheels. I believe it’s a 30mm offset rim. Or what type of wheel offset could I get to not have to use spacers?
  4. Jan 3, 2024 at 5:29 PM
    #1084
    ARCHIVE
    Eric
    Stock Taco wheels +30 probably have about 5.25" BS.
    255s give a little better clearance than a 285, not much.
    I ran 255/80-17 Cooper ST Maxx on FJ Cruiser 17x7.5 et 15 4.75" BS with 1.25" spacers
  5. Jan 19, 2024 at 10:25 AM
    #1085
    tacoman_13
    tacoman_13 Well-Known Member
    Triston
    San Diego
    2007 TRD Off-Road
    JD Fab LT, Archive Garage Hammer Hangers, soon to be on 35's
    Hey Eric, I know its been mentioned a ton in this thread here, but im curious if you think ill need spacers for my setup. I have SCS Ray10 with -10 offset and 4.30 BS. I currently am at 265/70/17 but soon plan on going and staying at 33s. Ill be doing your 2.5 relocation kit, a 2.5x12 smooth body. In your experience, for the 33s will I need spacers? Thanks for any help.
  6. Jan 19, 2024 at 11:25 AM
    #1086
    ARCHIVE
    Eric
    Yeah, 1.25" for 285s
  7. Jan 23, 2024 at 10:31 PM
    #1087
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    For those running 14" shocks with this relocation, what size limit straps do y'all run? Curious so I can order everything at once
  8. Jan 24, 2024 at 12:24 AM
    #1088
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I wouldnt pre-order straps based on someone else's setup. Every truck is different. Way too many variables between different leaf springs, shocks, hangers and shackles, and then there is variability in installation from one truck to the next, including the limit strap mounts themselves.
    I ordered the limit strap mounts ahead of time and had them welded up during install, but waited till I brought it home and drooped everything to order the straps themselves based on my measurements. It's nice to have everything on hand, but sometimes you just can't until you put it together.
  9. Jan 24, 2024 at 8:45 AM
    #1089
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    Im looking into a more DIY approach to my relocation kit and i want to know if you all think that its possible to do hammer hangers and the relocation at home with no lift and amateur welding skills. i really dont have it in my best interest to spend around 2k for installation (in socal)
  10. Jan 24, 2024 at 9:54 AM
    #1090
    ARCHIVE
    Eric
    Measure for straps after
  11. Jan 24, 2024 at 9:59 AM
    #1091
    ARCHIVE
    Eric
    You do need to know how to weld vertically, considerably harder than welding on a table.
    Maybe start with Hammer Hangers install, no welding, get them on and get your confidence up with that, and get your ride quality reward
  12. Jan 24, 2024 at 10:04 AM
    #1092
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    no lift needed tho? just a jack , jackstand, and welder?
  13. Jan 24, 2024 at 10:06 AM
    #1093
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Nope, A lift just makes it easier. Having an air hammer and a ball joint press is very handy for the hammer hangers though. Use the air hammer on the rivets in the side of the frame then the BJ press in the bottom
  14. Jan 24, 2024 at 10:08 AM
    #1094
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    unfortunatly i dont have the ball joint press, maybe ill invest in one.
  15. Jan 24, 2024 at 10:12 AM
    #1095
    ARCHIVE
    Eric
    I tried the ball joint press, I liked the drilling method better
    TacoFMS likes this.
  16. Jan 24, 2024 at 10:19 AM
    #1096
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Maybe put this in this thread. Probably dont want to muddy up Erics thread here too much.
    https://www.tacomaworld.com/threads/anything-welding.113957/
  17. Jan 24, 2024 at 10:20 AM
    #1097
    ARCHIVE
    Eric
    I would try to find a skilled welder
  18. Jan 24, 2024 at 10:20 AM
    #1098
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    np, my mistake
  19. Jan 24, 2024 at 10:23 AM
    #1099
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    yeah, i would but labor costs are so high.
  20. Feb 7, 2024 at 12:16 AM
    #1100
    beardo1_0
    beardo1_0 Well-Known Member
    Fremont, CA
    2023 Tacoma TRD Off Road
    Hey @ARCHIVE sorry if this question has been asked before, I just flipped through 50+ pages and gained a lot of knowledge but also wanted to double check before pulling the trigger on this. I have a DCSB 3rd gen currently running 2.5x12inch King on the rear with Deaver U402 Stage 3 and running 35s . My bed carries fridge, RTT, etc. I am thinking about getting your shock tower and hammer hanger. I want to keep my Deaver Stage III U402 so would you recommend King 2.5 12" or 14" triple bypass? Also any comments on my SCS 17x9 wheels with -38mm offset and 3.50" BS? Do you think I would need wheel spacer?
