Tacoma 2.7 idler pulley bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by ELMO67, Dec 26, 2019.
  1. Dec 26, 2019 at 8:37 PM
    ELMO67
    ELMO67 [OP] Well-Known Member
    Ct.
    04 Tacoma 4wd reg. cab
    Ok, so I have an ‘04 Tacoma 4wd with the 2.7, 3rz engine, 274,000 miles. Both of the idler pulleys - a/c and alt.- wobble and have play in the bearings. I’ve read that people have replaced just the bearings and not the overpriced assemblies. I haven’t been able to find any info on the bearings used. Can anyone help with this info?
    ToyotaJim likes this.
  2. Dec 26, 2019 at 10:25 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    NAPA has pn TEM 900466 for the bearing, around $15
    ELMO67[OP] likes this.
  3. Dec 27, 2019 at 12:32 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The bearings should have a number on them.
  4. Dec 27, 2019 at 8:31 AM
    ELMO67
    Ct.
    Hmm, there may be a number on them, but I don’t have it apart yet and I’d like to have the bearings on hand to save some down time.
  5. Dec 27, 2019 at 8:34 AM
    ELMO67
    Ct.
    Thanks for the reply! Are both bearings the same? I know that bearings have different quality grades, I wonder how good the NAPA bearings really are, and if there is a better grade available elsewhere?
  6. Dec 27, 2019 at 9:24 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    6301 2NSE is the part number I have in my notes. I've never had luck with a parts store finding these. I usually get them off Amazon. Both are the same. Nachi, Timken and SKF are quality bearings.
    cruiserguy likes this.
  7. Dec 28, 2019 at 9:16 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I used bearing #6301 in my idler pulley. Cost me around $4 from a motorcycle shop, but that was four or five years ago.
  8. Dec 28, 2019 at 11:07 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am sure you can buy the same bearing for lots more money if you shop around.
    Just try and avoid made in China ones they are still having quality control issues
    Big debate they can`t decide if quality control means every passes or there is a limit to how bad things can be.
    Quality control inspectors have been shot for both
    ELMO67[QUOTED][OP] likes this.
  9. Jan 4, 2020 at 6:01 PM
    ELMO67
    Ct.
    Well I stopped by the local electric motor repair/ supply business and got two 6301 FAG bearings this was the # on the bearings and they fit perfectly. Such a simple job, I wish I did it two years ago. $11.00 each
  10. Jan 4, 2020 at 6:58 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I noticed mine sounds a bit noisy, so I ordered one of the Nachi bearings from Amazon. I don't have a press, but I figure I could do it with a socket and a bottle jack.
  11. Jan 4, 2020 at 7:33 PM
    Reh5108
    Idaho
    Only need a hammer and some sockets.
  12. Jan 5, 2020 at 7:06 AM
    ELMO67
    Ct.
    Yep, just a small hammer and two appropriately sized sockets. Remove the snap ring, tap out the bearing from behind. Clean the pulley, apply a small amount of never seize to the bearing, and either use a vise to squeeze the bearing in, or use a block of wood and tap the bearing in. You’ll then need a socket almost the same od. as the bearing to finish driving it in so the snap ring can be replaced. Simple job.
    Kiloyard likes this.
