Tacoma 2" lift question
Discussion in 'Suspension' started by 2005tacoma, Jul 4, 2011.
  1. Jul 4, 2011 at 5:45 PM
    2005tacoma
    2005tacoma [OP] Member
    I have a stock 2005 double cab that im looking to lift. if i go with the bilsteins can i adjust it to a 2" lift in the front? and if i do that will i still need UCAs and the diff drop?
    Thanks
  2. Jul 4, 2011 at 5:49 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    bilstein levels are only .85, 1.75 or 2.5. There is no 2" option.
    No UCA's are not needed until 2.5+
  3. Jul 4, 2011 at 5:54 PM
    2005tacoma
    so if i set them at 1.75 would i need to drop the differential down also? what about at 2.5?
  4. Jul 4, 2011 at 5:56 PM
    08pretaco
    az
    No you would not need the diff drop. Actually there are quiet a few threads on here that recommend NOT using the diff drop even if you are lifted 3" due to bad design or bad characteristics with our trucks.
  5. Jul 4, 2011 at 5:57 PM
    08pretaco
    az
    Oh and if you do want 2", you can set the shocks to 1.75" and get the toytec top plates which will give you a little over 2", if your wanting more of a 2" lift.
  6. Jul 4, 2011 at 6:20 PM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    call me stupid, What bilsteins do I need to buy to get the different lift options, I have a 2011 tacoma with bilsteins on it now stock from factory, not the same thing I'm guessing?????????
  7. Jul 4, 2011 at 6:22 PM
    08pretaco
    az
  8. Jul 4, 2011 at 7:40 PM
    08pretaco
    az
    Any other questions I can help you out with? :) Id be more than happy to help, you can also shoot me a PM :D
  9. Jul 4, 2011 at 7:47 PM
    rpking
    Roger
    Ohio
    looks like an easy way to get some lift I might have to invest in a set Thanks for the info
  10. Jul 4, 2011 at 7:49 PM
    08pretaco
    az
    Its the best and most effective way. A much better way to go than spacers, not only a better ride but also safer.
  11. Jul 4, 2011 at 8:41 PM
    2005tacoma
    thanks a lot for the help. ill definitely let you know if i have any other questions
  12. Jul 4, 2011 at 8:48 PM
    08pretaco
    az
    For sure!
  13. Jul 4, 2011 at 10:23 PM
    Dilley
    Dilley Well-Known Member
    WA
    06 2.7L
    KN Cold air intake, Dynomax exaust, Husky liners
    1.75 should make your truck almost perfectly level and you might not even need an alignment, but I would take it in to get it checked anyway. That is what I have on my truck
  14. Jul 5, 2011 at 8:34 AM
    2005tacoma
    what would be the disadvantages of keeping the stock springs in the front instead of replacing them with the ones that come with the Bilstein kit?
  15. Jul 5, 2011 at 9:59 AM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    Those springs are a little more stiff and will give you about 1.6 inches lift on the 0 setting and about 2.5 inches at the .85 setting. The advantage being that you don't have to preload the springs as much. Both good options, but the eibach springs that you linked are just more money to spend and you will go under or over your desired 2".
  16. Jul 5, 2011 at 10:06 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    But they ride sooo nice!! The Bilstein 5100's at 0 with the Eibach coils pushes the 2" mark (just under) and when coupled with a 1.5" AAL in the rear, rides very nice!
  17. Jul 5, 2011 at 10:09 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What about Eibachs with Billies at 0 and a 1/4" top spacer on both sides ?
  18. Jul 5, 2011 at 10:30 AM
    trdtaco10
    trdtaco10 Well-Known Member
    Fayetteville, NC
    '10 TRD OR 4X4
    UWS toolbox, window tint, Bilstein 5100s on all four corners, black 16" TRD FJ wheels, 14" Shorty Antenna, Weathertech all weather floor liners, Satoshi Grill Mod, Rear leaf TSB, OME 885x's, Desert Racing UCAs, Icon 3 leaf AAL
    What about some OME 884s? They should give the 2" without preloading anything and without top plate spacers except for a small 1/4 inch one to go on the drivers side for the taco lean.
  19. Jul 5, 2011 at 11:21 AM
    OZ-T
    Peter North
    British Columbia
    Win
  20. Jul 5, 2011 at 11:35 AM
    2005tacoma
    would i gain more suspension travel with the Eibach springs or just a more comfortable ride? And what causes the driver's side lean?
