Tacoma 2000 V6 Having Trouble Catching
Discussion in '1st Gen. Tacomas (1995-2004)' started by FireSavage, Jun 22, 2016.
  1. Jun 22, 2016 at 10:52 AM
    FireSavage
    FireSavage [OP] Salvage Tile Beater - Fixer Up!
    Paul
    Oakland
    2000 Tacoma V6
    My truck won't catch when I turn the key right away. It was starting on the second and third trys for awhile but the problems getting worse, this morning it took 15+ trys. After I let her run for while she starts easier but then over night it takes forever.
    I had a ground issue last year that I resolved and she was working fine till this weekend. The starters new and I checked all the grounds. Battery is fine as all the lights come on when I toggle their switches. I don't know what else it could be unless I got a trash starter that has already burned out. Please help!
  2. Jun 22, 2016 at 10:55 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Check the actual power wire and ground wire, even though they are tight and grounded if the wire has corroded it won't work for shit. Pull the starter out and get it check at autozone
  3. Jun 22, 2016 at 10:56 AM
    eon_blue
    Azusa, CA
    Plugs and wires? How old are they? 3.4l copper plugs needs to be changed every 30k
  4. Jun 22, 2016 at 11:48 AM
    FireSavage
    Paul
    Oakland
    2000 Tacoma V6
    Just checked the power and ground wires and cleaned the terminals to the battery. Didn't help much. I'm looking to try everything before pulling that starter out again...
    Could it be the ignition switch?
    I changed the spark plugs around 25k or so ago... does it seem like compression could be the issue? When I turn the key it just makes a clicking wretching sound.
  5. Jun 22, 2016 at 12:08 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    The clicking sounds like a battery but odd it works after keep trying or bumping the starter
  6. Jun 22, 2016 at 12:08 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    No codes?
  7. Jun 22, 2016 at 12:24 PM
    FireSavage
    Paul
    Oakland
    2000 Tacoma V6
    The check engine light isn't on and I don't have my own code reader. Just walked over to autozone and will return when they're back from their lunch break.
  8. Jun 22, 2016 at 12:50 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Next time it's not catching...jerk the key around in the ign. switch. That sounds pretty likely, especially if high miles or you have a heavy keyring.
  9. Jun 22, 2016 at 1:49 PM
    GutsRage
    GutsRage Active Member
    Kansas City, MO
    2000 Tacoma 4x4 V6 manual
    Once it's running does it run with no issues? I'm having a similar problem and someone else on here, "zer0" I believe, responded to one of my posts saying he had some good similar to my problem, which sort of sounds like yours, and he fixed it with new plugs and plug wires. I ordered new coils and plug wires and just put new plugs in yesterday. Got the wires today and the coils should be here tomorrow. Once I get them in I'll let you know if it fixes my problem. Good luck.
  10. Jun 22, 2016 at 10:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It could just be me, but I am not quite clear on what "not catching" means. When you turn the key, does the starter engage and start yo crank the motor? Or does it does it do a series of clicks (not engaging) or is it just a single click til you release the key and try again?
    It's the 15+ tries that is getting me. I can't imagine it is actually engaging and cranking over.
  11. Jun 22, 2016 at 10:48 PM
    FireSavage
    Paul
    Oakland
    2000 Tacoma V6
    Once its running then it has no issues. I'd appreciate that.
  12. Jun 22, 2016 at 10:49 PM
    FireSavage
    Paul
    Oakland
    2000 Tacoma V6
    It won't turn over. Just a click. I went for an easy fix tonight and tried changing out the ignition switch and ignition cylinder but neither worked. No its not engaging or cranking, just a click. So yeah 15 clicks... but now it will still start after more than 15 but after I run it the truck will start after 4 or 5 key turns.
    Its getting worse and I'm getting closer to pulling the starter.
  13. Jun 23, 2016 at 8:03 AM
    GutsRage
    Kansas City, MO
    So you turn the key and just get a click with no starter turning at all then eventually the starter starts to turn and then the motor cranks and starts? If that's the case I think it'll be a different problem than I'm having.
    My issue is that the motor cranks every time, it just doesn't want to actually fire up. But when it does fire up there isn't any major issues that are noticeable. The coils are out for delivery today so once I get home I'll be throwing them in and seeing if it fixes my problem.
  14. Jun 23, 2016 at 8:21 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    When I had that problem a few years ago I replaced the starter's contacts in the starter solenoid and that solved the problem.
    Ugly Betty likes this.
  15. Jun 23, 2016 at 8:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    That is not a battery test.
    Have someone read a DVM across the terminals when you are trying to start the truck. It should not go below 9V.
    However, my money is on the starter solenoid.
    thumper72 likes this.
  16. Jun 23, 2016 at 6:36 PM
    GutsRage
    Kansas City, MO
    Put the new coils and plug wires in and I'm still having my same issue. Everything turns and cranks but just wont catch. It did start the first try after installing them and I drove around fine like all the others time. Did a few tests of shutting it off and back on and at first it was fine then after about 30 minutes of waiting I tried it again and it wont catch now. I have no idea now.
  17. Jun 24, 2016 at 11:39 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    A new battery solved this issue for me a year ago. I would imagine an auto parts store could test the battery for you.
  18. Jun 25, 2016 at 4:16 PM
    FireSavage
    Paul
    Oakland
    2000 Tacoma V6
    So I pulled the skid plate to get at the starter and I banged on it with a little hammer then a bit more w a screwdriver handle. 10 minutes later she started up fine and has been starting fine since.
  19. Jun 26, 2016 at 9:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I know you said the starter is new, but it sure doesn't sound like it.
    Now that you can get at it, may want to replace it with OEM or if it is OEM, rebuild it, replace the contacts and brushes.
