tacoma 2002 trd double cab takes tundra 2005 rear springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cheeko, Jun 21, 2016.
  1. Jun 21, 2016 at 8:06 PM
    cheeko
    cheeko [OP] Active Member
    victoria
    Tacoma
    3" sus lift
    as the tiltle says, would the tundra 2005 springs fit my tacoma 2002 trd? thanks
  2. Jun 21, 2016 at 9:06 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    sure, with enough welding
  3. Jun 21, 2016 at 9:31 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    Don't quote me on this as I haven't tried it myself, but I believe you'll run into some issues:
    1: While the Tundra springs are the same width, they are a good bit longer. 55"ish compared to 60"ish, I believe. Much longer shackles and/or new hangers would be required.
    2: With that longer spring, I'm willing to bet that the centering pin is further back as well. This would overextend the driveshaft to the point of falling apart.
    3: With the increased wheelbase, the tires would be pushed into the rear of the fenderwell.
    4: I also think the Tundy's used a reverse shackle outboard the frame, thus requiring more arch compared to the tacomes convention under-frame shackle. Not sure how much lift that would equate to.
    All surmountable issues if you have the time/willingness/money, but seems like a lot of trouble for whatever possible improvements...
  4. Jun 22, 2016 at 1:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Why ??
    What is the end result your looking for??
  5. Jun 22, 2016 at 10:23 PM
    cheeko
    victoria
    Tacoma
    3" sus lift
    thanks guys, i wont do it, just my neightbour giving me a pair of his spring from his old truck. I was nt sure they will fit.
