Tacoma 2005
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yeye3674, Dec 14, 2019.
  1. Dec 14, 2019 at 10:20 PM
    yeye3674
    yeye3674 [OP] Member
    yeye3674
    florida
    PreRunner SR5
    Hello everybody. I have on my tacoma right now 245/75/rim 16 helo 878
    Does anybody no if 265/70/rim 16. I order Mickey Thompson tires. Do you think rim will work fine.
    My truck lift 2"inch. Rear Block 2"inch. I have front fab fours front bumper and rear fabfours bumper.
  2. Dec 14, 2019 at 10:24 PM
    yeye3674
    yeye3674
    florida
    PreRunner SR5
  3. Dec 14, 2019 at 10:25 PM
    yeye3674
    yeye3674
    florida
    PreRunner SR5
    2005 tacoma adding 265/70/16rim. Helo 878 fit fine
    My truck as 245/75/rim 16
  4. Dec 14, 2019 at 10:26 PM
    yeye3674
    yeye3674
    florida
    PreRunner SR5
    Thank you so much answer back to me
  5. Dec 14, 2019 at 10:27 PM
    Bishop84
    Bishop84 Well-Known Member
    265's are still too small if its a 9" rim, I'd want a 275 or 285 on 9" or the sidewalls will stretch. It will fit, just not well.
    If its 8" 265 at least, you can see your 245s are stretched.
    Lifted 2" I'd want 265/75R16 to fill out better.
  6. Dec 14, 2019 at 11:02 PM
    yeye3674
    yeye3674
    florida
    PreRunner SR5
    So it will not fit my rim 16 rim. 265/70/16. I need 265/75/16.
    Helo 878.
  7. Dec 14, 2019 at 11:04 PM
    yeye3674
    yeye3674
    florida
    PreRunner SR5
    I don't like stretch out.
  8. Dec 15, 2019 at 12:30 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    265/70/16 is a factory size and what came on my truck. They are the same diameter as the 245/75/16's, just about 1" wider. With a lift they will look a little small IMO. A 265/75/16 is both 1" taller, and 1" wider than 245/75/16's and the smallest tire I'd put on that truck. You could probably use 285/75/16's.
