Tacoma 2007 rusty frame out of warranty
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matossan, Mar 25, 2021.
  1. Mar 25, 2021 at 5:33 PM
    Matossan
    Matossan [OP] New Member
    2007 Tacoma 4X4
    None
    Hi there
    today was a very stressful day for me ..I was told by a Toyota dealer that my chassis has holes and is basically completely rusty..the extended warranty on this type of issue ( massive recall) has just expired (june 2019) .. I called Toyota headquarter but they stand firm on their legal ground and told me to F... off ..so here you have it ..a 122k miles Tacoma cosmetically pristine but a wreck after owning it only fir 15 months ..I am dumbfounded by the lack of empathy by Toyota..my first time with the brand and quite an underwhelming I must say ..any suggestions out there ? Cheers
  2. Mar 25, 2021 at 5:37 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Toyota extended that warranty twice that I know of. How long have you had the truck? I expect you got it used - sorry to be blunt - but you probably should have inspected it before buying. It was a long time known issue, and should have surfaced in service records (or inspections for same). Best of luck.
    ace96 and JdevTac like this.
  3. Mar 25, 2021 at 5:55 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    If it gets to the point that the dealer is the one to tell you your frame is dead, then that’s telling enough to me.
    To the OP, I sympathize with you, sure the rust is an issue, but there have been set parameters to qualify, with many frames replaced, but it’s a two way street and as things go Toyota is only required to fix it up to the expected lifespan of the vehicle, which regardless of it being a Toyota, is not indefinite.
    Get a look at it yourself since apparently this came as a shock being told by the dealer, and see if you can have it patched. Otherwise a diy frame swap or paying out of pocket is usually out of the question for 99.9% of people.
    Oldie2007[QUOTED] likes this.
  4. Mar 25, 2021 at 6:29 PM
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    Take your 14 year old Ford or Chevy truck to the dealer and tell them your frame is rusted out and you want them to give you a new one. I guarantee you will be laughed off the premises. Toyota replaced frames up to 12 years from date of first service. By the way, I have owned Ford and Chevy trucks, and none of them lasted more than 11 years. (I live in northern New England, where the salt flows free in snow season.) Frames rust, trucks rust, and as much as it sucks, there it is.
    Lack of empathy? What are they supposed to do? Just replace frames into perpetuity? They made a well-publicized settlement - it was for 12 years. Seems more than reasonable to me. I know it hurts to miss the deadline, but there was a deadline. I feel for you, I really do (I have all kinds of empathy) but I'm afraid you've had a spot of bad luck :-(
    Just for accuracy in terms, the original factory recall for this issue ended in 2016. The 12 year deal is neither an extended warranty nor a factory recall - it is the settlement terms of a class action lawsuit.
    Vishnevian likes this.
  5. Mar 26, 2021 at 5:04 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    This company makes fab sections you can have welded on, new for 2nd Gens. You have to call them, apparently the new items are not on their site yet.
    https://www.autorust.com/product-category/toyota/tacoma-2005-2014-2nd-gen/
    mabepossibly likes this.
  6. Mar 26, 2021 at 6:00 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    reg0928 and Grossomotto[QUOTED] like this.
  7. Mar 26, 2021 at 6:49 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    This. As long as there is good metal to weld to, if you hunt long enough you'll be able to find a shop to give it a go. It took me a while to find a shop that was willing to weld a crossmember back in so I could ditch my DB lift, but after calling several of them I found one that was redneck enough
    Hyperbarics likes this.
  8. Mar 26, 2021 at 6:52 AM
    BigRed94510
    BigRed94510 New Member
    Joe
    2006 Tacoma 4dr Long bed
    3” lift on 33s
    Really sorry you’re experiencing this. Toyota has given me hell about this warranty recall, literally to the point I had to block the dealership number. They wanted to do the replacement, even though they told me my truck didn’t need it, but they’d have to remove my lift, and I’d have to get it to another city to the shop and pay to reinstall it. Umm... No thx.
  9. Mar 26, 2021 at 6:57 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    If you live anywhere rust is an issue and your frame may be worse in the future, I would happily get my frame recall done at the dealership and pay someone else to reinstall my lift. Small amount to pay for a new frame for the peace of mind I won't have to do with a rusted frame no one can fix in the future. Just my opinion
    What lift do you have installed?
  10. Mar 26, 2021 at 7:12 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP. Sorry, but you are SOL
    Your truck is 14+ years old. Rust happens as a result of nature. Yes, it is hastened by salt & brine in the snow belt.
    This has been a known issue for many years. Its based on the age of the truck, not how long you have owned it. Toyota complied with the settlement for many years. Each frame Toyota replaced cost them roughly $13,000+. I understand why they take a hard stance on the deadline date.
    You do have options. Sell it. Replace frame. Repair/patch frame. Ignore it and drive.
    Realize rust happens, it not a "brand" targeted phenomenon.
    You should've seen the US made cars from the 60's when they were 14 years old........
