tacoma 2010 alternator diodes fail.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airframeabe, Jul 5, 2015.
  1. Jul 5, 2015 at 10:43 AM
    airframeabe
    airframeabe [OP] Member
    2010 tacoma prerunner v6 sr5
    Hi guys, I'm a new member.
    I have a 2010 Tacoma pre runner sr5.
    Yesterday morning the truck did not start.It wouldn't even click.I checked the battery and had 12.6v I jump started it and auto zone checked it.They said the alternator rectifier failed.I've read
    somewhere that batteries even though they show good voltage can be bad....any comments.
    thanks in advance. airframeabe
  2. Jul 5, 2015 at 10:57 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It can read 12 VDC and up with no load, but when when you try to start it it drops to near zero and you get nothing. Diodes do fail, get a new or rebuilt OEM Alternator and call it good. These diodes can be replaced if you are good at disassembly of an alternator.
  3. Jul 5, 2015 at 11:03 AM
    airframeabe
    I think I posted in the wrong forum. but anyway,i installed a new batt and the diode failure went away. I think the old batt triggered the diode fail.the old batt was three years old this month.everything is ok now.
  4. Jul 5, 2015 at 9:21 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I've seen batteries read 12.7V and flunk a load test. The Open Circuit Voltage test is meaningless unless you are reading low.
    The only real test is a load test.
  5. Jul 5, 2015 at 10:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If you truely do have a shorted diode the new battery will also fail eventually. Did you ever get a Battery Light on the dash? Battery Light on with the ignition on running indicates a shorted Negative Diode. Battery light on with the ignition off ( key removed ) indicates a shorted positive diode.
  6. Jul 6, 2015 at 12:18 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I would not hesitate to take the car to an alternator/starter shop to test the charging system. Most will not charge for a quick check. If you have a voltmeter, you can perform a simple test; look it up on youtube. Look up a mom/pop shop - the messier the shop the better!
  7. Jul 6, 2015 at 6:30 AM
    marshall765
    marshall765 Well-Known Member
    Shreveport Louisiana
    13 DCSB TRD Offroad 4x4
    I have had several situations were an auto parts store informed me my charging system was to blame, only to replace the battery and be just fine.
    Changing a battery is quick and easy. I would change the battery, drive it for a day, take it back and have them check it again.
  8. Jul 6, 2015 at 7:43 AM
    airframeabe
    That's what I did.I replaced the batt and went back to autozone to have it checked.The alt diode failure went away.It's weird that the old batt triggered the alt diode failure.I'm glad I didn't have to replace the alternator.Btw the old batt was three years old this month,
